Revision as of 15:32, 11 April 2019 by R4002 (Talk | contribs)
During band openings, music and what sound like religious services have been noted on other 26-28 MHz frequencies, including those in the "low band" 26.515 MHz to 26.955 MHz and/or the German CB band 26.565 MHz to 26.955 MHz. Religious services church broadcasts have been monitored on 26.785 MHz, 26.825 MHz and other frequencies in addition to the more heavily used frequencies discussed in this article.
Frequencies
CB Channel Frequency
CADS operates on the 80 UK CB channels (standard CB channels 1-40 and UK FM CB channels 1-40) so 26965-27405 and 27601.25-27991.25 FM mode only. Ireland's WPAS service operates on two sets of 40 interleaved channels for a total of 80 channels. Although not technically authorized in Ireland, Churches often use the standard 40 "mid band CB" or "CEPT CB" channels as well. Ireland allows use of AM and FM on all 80 channels as part of the WPAS system, while FM is the only mode allowed in the UK. Most CADS and WPAS transmissions are in FM, AM is the exception. When added to the 40 mid band CB channels 26.965 to 27.405 a total of 120 channels becomes available. In practice, several churches will share frequencies or use offset channels and/or channels in between the 26.965-27.405 MHz range and the 27.60125-27.99125 MHz / 27.605-27.995 MHz range. FM mode with 5 kHz deviation (wideband in land mobile two-way radio parlance) is the standard, with some variation in deviation depending on the manufacturer and model of the radio transmitter used and when the radio was manufactured. AM mode is the standard 8 kHz A3E emission 8K00A3E.
Note that the UK FM CB channels and LW01-LW40 WPAS channels are often offset, for example, instead of 27.60125 MHz, a church using an "export radio" with frequency agility will transmit on 27.601 MHz or even 27.600 MHz. With the local audience of these transmissions, a difference of 1 kHz or so makes very little, if any, difference...as the intended listeners are rarely more than a couple miles away from the transmitter and most Churches on 27 MHz use regular "wide" 5 kHz (or more) deviation on FM. A small minority of churches broadcast outside the 26.965 MHz to 27.405 MHz and 27.6 MHz to 27.995 MHz regions, including the area below CB channel 1 (generally the "low band" frequencies of 26.515 MHz to 26.955 MHz, including the German CB extra channel allocation 26.565 MHz to 26.955 MHz) and the "freeband" frequency space between 27.405 MHz and 27.600 MHz.
[1]
Channel 01 26.965 MHz
Channel 02 26.975 MHz
Channel 03 26.985 MHz
Channel 04 27.005 MHz
Channel 05 27.015 MHz
Channel 06 27.025 MHz
Channel 07 27.035 MHz
Channel 08 27.055 MHz
Channel 09 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.185 MHz
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
Channel 28 27.285 MHz
Channel 29 27.295 MHz
Channel 30 27.305 MHz
Channel 31 27.315 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 35 27.355 MHz
Channel 36 27.365 MHz
Channel 37 27.375 MHz
Channel 38 27.385 MHz
Channel 39 27.395 MHz
Channel 40 27.405 MHz
