During band openings, music and what sound like religious services have been noted on other 26-28 MHz frequencies, including those in the "low band" 26.515 MHz to 26.955 MHz and/or the German CB band 26.565 MHz to 26.955 MHz. Religious services church broadcasts have been monitored on 26.785 MHz, 26.825 MHz and other frequencies in addition to the more heavily used frequencies discussed in this article.
Frequencies
| CB Channel | Frequency |
CADS operates on the 80 UK CB channels (standard CB channels 1-40 and UK FM CB channels 1-40) so 26965-27405 and 27601.25-27991.25 FM mode only. UK law defines the 27/81 UK FM CB band as 27.59625 MHz to 27.99625 MHz (5 kHz down from UK CB channel 1 and 5 kHz up from UK CB channel 40). The mid band CEPT/EU band is defined as 26.960 MHz to 27.410 MHz. Ireland's WPAS service operates on two sets of 40 interleaved channels for a total of 80 channels. Although not technically authorized in Ireland, Churches often use the standard 40 "mid band CB" or "CEPT CB" channels as well. Ireland allows use of AM and FM on all 80 channels as part of the WPAS system, while FM is the only mode allowed in the UK. Most CADS and WPAS transmissions are in FM, AM is the exception. When added to the 40 mid band CB channels 26.965 to 27.405 a total of 120 channels becomes available. In practice, several churches will share frequencies or use offset channels and/or channels in between the 26.965-27.405 MHz range and the 27.60125-27.99125 MHz / 27.605-27.995 MHz range. FM mode with 5 kHz deviation (wideband in land mobile two-way radio parlance) is the standard, with some variation in deviation depending on the manufacturer and model of the radio transmitter used and when the radio was manufactured. AM mode is the standard 8 kHz A3E emission 8K00A3E.
Note that the UK FM CB channels and LW01-LW40 WPAS channels are often offset, for example, instead of 27.60125 MHz, a church using an "export radio" with frequency agility will transmit on 27.601 MHz or even 27.600 MHz. With the local audience of these transmissions, a difference of 1 kHz or so makes very little, if any, difference...as the intended listeners are rarely more than a couple miles away from the transmitter and most Churches on 27 MHz use regular "wide" 5 kHz (or more) deviation on FM. A small minority of churches broadcast outside the 26.965 MHz to 27.405 MHz and 27.6 MHz to 27.995 MHz regions, including the area below CB channel 1 (generally the "low band" frequencies of 26.515 MHz to 26.955 MHz, including the German CB extra channel allocation 26.565 MHz to 26.955 MHz) and the "freeband" frequency space between 27.405 MHz and 27.600 MHz.
| Channel 01 | 26.965 MHz |
| Channel 02 | 26.975 MHz |
| Channel 03 | 26.985 MHz |
| Channel 04 | 27.005 MHz |
| Channel 05 | 27.015 MHz |
| Channel 06 | 27.025 MHz |
| Channel 07 | 27.035 MHz |
| Channel 08 | 27.055 MHz |
| Channel 09 | 27.065 MHz |
| Channel 10 | 27.075 MHz |
| Channel 11 | 27.085 MHz |
| Channel 12 | 27.105 MHz |
| Channel 13 | 27.115 MHz |
| Channel 14 | 27.125 MHz |
| Channel 15 | 27.135 MHz |
| Channel 16 | 27.155 MHz |
| Channel 17 | 27.165 MHz |
| Channel 18 | 27.185 MHz |
| Channel 19 | 27.185 MHz |
| Channel 20 | 27.205 MHz |
| Channel 21 | 27.215 MHz |
| Channel 22 | 27.225 MHz |
| Channel 23 | 27.255 MHz |
| Channel 24 | 27.235 MHz |
| Channel 25 | 27.245 MHz |
| Channel 26 | 27.265 MHz |
| Channel 27 | 27.275 MHz |
| Channel 28 | 27.285 MHz |
| Channel 29 | 27.295 MHz |
| Channel 30 | 27.305 MHz |
| Channel 31 | 27.315 MHz |
| Channel 32 | 27.325 MHz |
| Channel 33 | 27.335 MHz |
| Channel 34 | 27.345 MHz |
| Channel 35 | 27.355 MHz |
| Channel 36 | 27.365 MHz |
| Channel 37 | 27.375 MHz |
| Channel 38 | 27.385 MHz |
| Channel 39 | 27.395 MHz |
| Channel 40 | 27.405 MHz |
