HF marine
Revision as of 13:41, 17 July 2019 by R4002 (Talk | contribs)
See also: VHF marine band
Band Frequency Range
2450-2850 kHz MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-3 MHz)
16460-17360 kHz HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz
25070-25121 kHz HF 25 MHz marine band
26145-26175 kHz HF 26 MHz marine band
26175-30000 kHz Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz)
Simplex Frequencies
2003.0 kHz 2065.0 kHz 2079.0 kHz 2082.5 kHz 2086.0 kHz 2093.0 kHz 2096.5 kHz 2142.0 kHz 2203.0 kHz 2214.0 kHz 2635.0 kHz 2638.0 kHz 2738.0 kHz 2782.0 kHz 2830.0 kHz
4 MHz (4000 kHz - 4438 kHz) marine band:
4146.0 kHz 4149.0 kHz 4417.0 kHz
[i]4000 kHz to 4060 kHz are also designed for simplex maritime radio use, in 3 kHz steps (4000 kHz, 4003 kHz, 4006 kHz, etc.), shared with fixed/mobile service [/i]
6 MHz (6200 kHz - 6525 kHz) marine band:
6224.0 kHz 6227.0 kHz 6230.0 kHz 6516.0 kHz
8 MHz (8000 kHz - 8815 kHz) marine band:
8294.0 kHz 8297.0 kHz
[i]8101 kHz to 8191 kHz are also designed for simplex maritime radio use, in 3 kHz steps (8101 kHz, 8104 kHz, 8107 kHz, etc.), shared with fixed/mobile service [/i]
12 MHz / 13 MHz (12330 kHz - 13200 kHz) marine band:
12353.0 kHz 12356.0 kHz 12359.0 kHz 12362.0 kHz 12365.0 kHz
16 MHz / 17 MHz (16460 kHz - 17360 kHz) marine band:
16528.0 kHz 16531.0 kHz 16534.0 kHz 16537.0 kHz 16540.0 kHz 16543.0 kHz 16546.0 kHz
18 MHz (18780 kHz - 18900 kHz) marine band:
18825.0 kHz 18828.0 kHz 18831.0 kHz 18834.0 kHz 18837.0 kHz 18840.0 kHz 18843.0 kHz
22 MHz (22000 kHz - 22855 kHz) marine band:
22159.0 kHz 22162.0 kHz 22165.0 kHz 22168.0 kHz 22171.0 kHz 22174.0 kHz 22177.0 kHz
25 MHz (25070 kHz - 25121 kHz)
25100.0 kHz 25103.0 kHz 25106.0 kHz 25109.0 kHz 25112.0 kHz 25115.0 kHz 25118.0 kHz
I put together the list above as these frequencies are also likely to be pre-programmed in MF / HF SSB marine radios, in addition to the dual-use duplex/simplex channeling (3 kHz steps for SSB voice, except odd steps on 2 MHz band). It should also be noted that many older-generation SSB marine radios do not cover the higher bands. Many radios only cover up to 12 MHz / 13 MHz or 16 MHz / 17 MHz.
See also:
