HF marine
See also: VHF marine band
Band | Frequency Range |
405-525 kHz | MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz or 500 kc (600 meters) was the original CW Morse code calling frequency |
1600-2000 kHz | MF band, used in Europe and elsewhere (also used heavily for fishnet beacons) - overlaps with 1800-2000 kHz 160 meter amateur band |
2000-2300 kHz | MF 2 MHz marine band - USB voice calling/distress 2182 kHz, DSC calling/distress 2187.5 kHz - USCG no longer monitors 2182 kHz USB |
2450-2850 kHz | MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-3 MHz) |
4000-4063 kHz | 4 MHz fixed/mobile band, shared with marine for simplex purposes, can be paired cross-band with 8 MHz |
4063-4438 kHz | HF 4 MHz marine band - USB voice calling/distress 4125 kHz, DSC calling/distress 4207.5 kHz |
6200-6525 kHz | HF 6 MHz marine band - USB voice calling/distress 6215 kHz, DSC calling/distress 6312 kHz |
8000-8195 kHz | 8 MHz fixed/mobile band, shared with marine for simplex purposes, can be paired cross-band with 4 MHz |
8195-8815 kHz | HF 8 MHz marine band - USB voice calling/distress 8291 kHz, DSC calling/distress 8414.5 kHz |
12330-13200 kHz | HF 12 MHz marine band - USB voice calling/distress 12290 kHz, DSC calling/distress 12577 kHz |
16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
18780-18900 kHz | HF 18 MHz marine band |
19680-19800 kHz | HF 19 MHz marine band |
22000-22855 kHz | HF 22 MHz marine band |
25070-25121 kHz | HF 25 MHz marine band |
26145-26175 kHz | HF 26 MHz marine band |
26175-30000 kHz | Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz) |
These frequencies are specifically designated for simplex use (ship-to-ship and/or ship-to-shore comms). Any frequency in the MF and HF marine bands may be used for simplex purposes, including the duplex channelized frequencies. Often the "ship TX" or "ship transmit" frequency is used for ship-to-ship communications.
- 2003.0 kHz
- 2065.0 kHz
- 2079.0 kHz
- 2082.5 kHz
- 2086.0 kHz
- 2093.0 kHz
- 2096.5 kHz
- 2142.0 kHz
- 2203.0 kHz
- 2214.0 kHz
- 2635.0 kHz
- 2638.0 kHz
- 2738.0 kHz
- 2782.0 kHz
- 2830.0 kHz
- 4146.0 kHz
- 4149.0 kHz
- 4417.0 kHz
- 6224.0 kHz
- 6227.0 kHz
- 6230.0 kHz
- 6516.0 kHz
- 8294.0 kHz
- 8297.0 kHz
- 12353.0 kHz
- 12356.0 kHz
- 12359.0 kHz
- 12362.0 kHz
- 12365.0 kHz
- 16528.0 kHz
- 16531.0 kHz
- 16534.0 kHz
- 16537.0 kHz
- 16540.0 kHz
- 16543.0 kHz
- 16546.0 kHz
- 18825.0 kHz
- 18828.0 kHz
- 18831.0 kHz
- 18834.0 kHz
- 18837.0 kHz
- 18840.0 kHz
- 18843.0 kHz
- 22159.0 kHz
- 22162.0 kHz
- 22165.0 kHz
- 22168.0 kHz
- 22171.0 kHz
- 22174.0 kHz
- 22177.0 kHz
- 25100.0 kHz
- 25103.0 kHz
- 25106.0 kHz
- 25109.0 kHz
- 25112.0 kHz
- 25115.0 kHz
- 25118.0 kHz
These frequencies are specifically designated for duplex use (generally ship-to-shore or shore-to-ship comms). Any frequency in the MF and HF marine bands may be used for simplex purposes, including the duplex channelized frequencies. Often the "ship TX" or "ship transmit" frequency is used for ship-to-ship communications.
See also:
- VHF marine band
- Maritime Fax Transmissions
