File:PLUTO 25Hz.mp3
PLUTO_25Hz.mp3(file size: 117 KB, MIME type: audio/mp3)
PLUTO radar in its less often used 25 Hz rep rate. In this case the swpet wdith is still 20 kHz, but the sweep repetition rate is only 25 Hz, so the chirp rate is halved. The audio in this recording is only 3 kHz wide, and represents how the signal might sound in a standard receiver in USB mode.
Date/TimeDimensionsUserComment
current00:09, 15 December 2014 (117 KB)Token (Talk | contribs) (PLUTO radar in its less often used 25 Hz rep rate. In this case the swpet wdith is still 20 kHz, but the sweep repetition rate is only 25 Hz, so the chirp rate is halved. The audio in this recording is only 3 kHz wide, and represents how the signal migh)
