Links associated with frequencies (such as 5000 kHz) will take you to an online receiver that is tuned so you have a chance to hear it live. Be sure to visit KiwiSDR Operating Information to learn more about how to operate these online receivers. There is a list and map or receivers available to use worldwide. Using an online receiver allows you to try HF monitoring before investing in your own equipment. They are also helpful if you have limited capabilities to erect a large antenna or if your location has a lot of radio frequency interference.
What Can I Hear?
There are a wide variety of things to listen to on HF and it would be impossible to cover them all here. To get a taste for what is available see the examples below to get you started. Much of what is presented here is from a North American perspective but can be helpful to new hobbyists located elsewhere.
Patience is one of your most important tools. Unlike radio stations on your FM dial, many, if not most, stations broadcast on a limited basis and are not on the air continuously. There are many factors that can help and impede your chances of reception so if you are not successful on your first attempt, keep trying!
Understanding radio propagation will help you determine what stations you can hear and when you can hear them. Shortwave radio signals can arrive at your receiver from the transmitter in two ways. If you are very close to the transmitter the radio waves will travel across the ground to your receiver (ground wave propagation). If you are farther away the radio waves will bounce off the ionosphere in the atmosphere (sometimes multiple times) before arriving at your receiver (ionospheric propagation or "skip"). Watch this short Youtube video to get a basic understanding of this process.
Understanding Shortwave Propagation for the Beginner
Some key factors to remember are:
- Radio propagation can be forecasted but you can never be 100% certain.
- The presence of sunspots will significantly enhance radio propagation especially at higher frequencies. The lack of sunspots will reduce propagation.
- Your location is also important. The propagation at the transmitter site may be completely different from the propagation at the receiver.
- Time of day is very important. The ionosphere changes during the day and reflects signals of different frequencies at different times.
Since radio propagation is a natural phenomenon it can be unpredictable. It can also change very quickly. Sometimes propagation is excellent. Sometimes it is very, very poor. The pursuit of the elusive radio signal is the thrill of HF radio monitoring. As you get started in this hobby, start with the easier stations to hear and work upward toward the harder ones. This will hone your listening skills and improve your chances.
Easy to hear
WWV WWVH(US) - 2500 kHz, 5000 kHz, 10000 kHz, 15000 kHz, 20000 kHz (WWV only), 25000 kHz (WWV only) [Show receivers on east coast vs. west coast to emphasize propagation at different locations]
Shortwave Broadcasters
Amateur (Ham) Radio
Amateur radio operators are people who are licensed to use parts of the HF radio spectrum. Their interests span from technical, emergency communications, or to just having conversations with other stations. There are many amateur radio bands on HF. Operators also operate many different modes - voice (AM, LSB, USB), digital, Morse Code, etc. Many of these modes can be monitored on online receivers without any special equipment. Some modes require special decoding hardware or software. The easiest to listen to would be voice communications. Here are a couple of examples of frequencies that have regular activity or nets. Again, propagation can affect whether or not stations can be heard or not.
75 meter band - 3875 kHz, 3885 kHz (AM voice activity)
40 meter band - 7253 kHz, 7255 kHz (LSB nets)
20 meter band - Slow Scan TV (SSTV) - 14230 kHz (with SSTV decoder on)
Moderately easy to hear
More difficult to hear
Rare, exotic stations are hunted by groups of listeners called DXers. Often they listen for days, weeks, months, or years in the hope of receiving a specific station. A combination of patience, luck, equipment, and propagation can determine whether the elusive station will be heard. These stations can be low power stations that are target a local audience, political clandestine stations that are short lived and operating illegally in their country, or stations that have a very restricted on the air schedule. Sometimes propagation cooperates and allows easier reception of these stations. Hobbyists operating "out of band" above and below the amateur radio bands, especially around 6600-7000 kHz and around the CB band (11 meters) and 10 meter amateur band 25-30 MHz (freebanding, usually from roughly 25600 kHz to 28000 kHz, during band openings).
Where to Listen Online
Other Resources
Propagation, Time of Day, and Location
