VHF low band VHF-low
Since the input and output frequencies are reversed for LLAW1/LLAW3 and for LFIRE2/LFIRE4, only one set repeaters should operate in a given geographical area. If all four frequencies are used for simplex purposes, then all four frequencies 39.46 MHz, 39.48 MHz, 45.86 MHz and 45.88 MHz may be used in the same geographical area. 39.460 MHz and 45.880 MHz are considerably more likely to be used nationwide. Many states will use these frequencies in conjunction with their own statewide interoperability frequency (for states that still maintain and use lowband radio systems). The lowband frequencies should be programmed with regular 20K0F3E or 16K0F3E emission (regular 20 kHz / 25 kHz bandwidth FM), not narrow band FM (11K3F3E, 11K2F3E, 11K0F3E, etc.).
VHF high band VHF band
- 155.3700 MHz - INTERCITY Law Enforcement Point-to-Point Interop (only used in some areas)
UHF band
*UHF MED Channels - UHF EMS Channels *Original Channel Plan (25 kHz channels, 12.5 kHz bandwidth)
- 462.9625 MHz - MED-92 - Calling/Dispatch, repeater paired with X MHz
- 462.9875 MHz - MED-102 - Calling/Dispatch, repeater paired with X MHz
- 463.0125 MHz - MED-12 - EMS Operations, repeater paired with X MHz
- 463.0375 MHz - MED-22 - EMS Operations, repeater paired with X MHz
- 463.0625 MHz - MED-32 - EMS Operations, repeater paired with X MHz
- 463.0875 MHz - MED-42 - EMS Operations, repeater paired with X MHz
- 463.1125 MHz - MED-52 - EMS Operations, repeater paired with X MHz
- 463.1375 MHz - MED-62 - EMS Operations, repeater paired with X MHz
- 463.1625 MHz - MED-72 - EMS Operations, repeater paired with X MHz
- 463.1875 MHz - MED-82 - EMS Operations, repeater paired with X MHz
*Narrow Band Channel Plan (6.25 kHz channels, 6.25 kHz bandwidth)
- 462.95625 MHz - MED-91 - EMS Operations, repeater paired with X MHz
- 462.96875 MHz - MED-93 - EMS Operations, repeater paired with X MHz
- 462.98125 MHz - MED-101 - EMS Operations, repeater paired with X MHz
- 462.99375 MHz - MED-103 - EMS Operations, repeater paired with X MHz
- 463.00625 MHz - MED-11 - EMS Operations, repeater paired with X MHz
- 463.01875 MHz - MED-13 - EMS Operations, repeater paired with X MHz
- 463.03125 MHz - MED-21 - EMS Operations, repeater paired with X MHz
- 463.04375 MHz - MED-23 - EMS Operations, repeater paired with X MHz
- 463.05625 MHz - MED-31 - EMS Operations, repeater paired with X MHz
- 463.06875 MHz - MED-33 - EMS Operations, repeater paired with X MHz
- 463.08125 MHz - MED-41 - EMS Operations, repeater paired with X MHz
- 463.09375 MHz - MED-43 - EMS Operations, repeater paired with X MHz
- 463.10625 MHz - MED-51 - EMS Operations, repeater paired with X MHz
- 463.11875 MHz - MED-53 - EMS Operations, repeater paired with X MHz
- 463.13125 MHz - MED-61 - EMS Operations, repeater paired with X MHz
- 463.14375 MHz - MED-63 - EMS Operations, repeater paired with X MHz
- 463.15625 MHz - MED-71 - EMS Operations, repeater paired with X MHz
- 463.16875 MHz - MED-73 - EMS Operations, repeater paired with X MHz
- 463.18125 MHz - MED-81 - EMS Operations, repeater paired with X MHz
- 463.19375 MHz - MED-83 - EMS Operations, repeater paired with X MHz
700 MHz / 800 MHz band
- 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 807.5125 MHz) both with 156.7 Hz CTCSS
- 47.8000 MHz - Military NATO Combat Scene of Action Common
UHF band
Oil Spill Cleanup
