Contents[hide] |
VHF low band VHF-low
VHF high band VHF band
- 155.3700 MHz - INTERCITY Law Enforcement Point-to-Point Interop (only used in some areas)
UHF band
*UHF MED Channels - UHF EMS Channels *Original Channel Plan (25 kHz channels, 12.5 kHz bandwidth)
*Narrow Band Channel Plan (6.25 kHz channels, 6.25 kHz bandwidth)
700 MHz / 800 MHz band
- 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 807.5125 MHz) both with 156.7 Hz CTCSS
UHF band
- 5680 kHz - USB voice - SAR operations
- 8364 kHz - USB voice - SAR operations
- 853.0125 MHz - 8TAC94 - SAR Command interop simplex - 156.7 Hz CTCSS
Oil Spill Cleanup
