SINCGARS
Revision as of 18:30, 30 March 2021 by R4002 (Talk | contribs)
Military tactical radio - FM tactical radio system Single Channel Air-Ground Radio System, commonly known as SINCGARS "sink-gars", FM or Fox Mike radio. SINCGARS and FM are used in conjunction with HF-SSB systems, UHF/SHF/EHF SATCOM and other communications systems for tactical military communications purposes. See also: militia radio frequencies.
Single channel mode, also known as fixed frequency, is referred to as VULOS, or VHF UHF Line Of Sight (LOS). It is a catch-all term for VHF-FM 30-88 MHz, VHF-AM 108-150 MHz, VHF-FM 136-174 MHz, UHF-AM 225-399.975 MHz and UHF-FM 400-512 MHz fixed frequency clear (plaintext, or PT) or encrypted (ciphertext, or CT) simplex communications nets. Duplex or half-duplex repeaters (relay, retrans) or retransmission facilities may be used for VULOS nets. Frequencies in the 30.000 to 87.975 MHz range may be used for these nets in conjunction with SINCGARS, UHF SATCOM and UHF aircraft HAVE QUICK nets. PRC-148, PRC-152 and similar radios make reference to the VULOS radio net type. See also: PRC-150 HF/VHF radio (1.5-30 MHz SSB and various digital modes, 30-60 MHz [59.999 MHz] FM only. FM radios often have a "deviation" (bandwidth) setting. SINCGARS and fixed channel mode is generally set to 8 kHz deviation (36 kHz bandwidth) at 25 kHz steps. Land mobile settings include 5 kHz deviation (20 kHz bandwidth) and 2.5 kHz deviation (10 kHz bandwidth, regular narrow FM).
For example:
  • Relay Operation:
  • Repeater Operation:
Background and History
60.000 MHz to 80.000 MHz TBS Series "Talk Between Ships" - Ship-to-Ship voice radio 60-80 MC radio - US Navy Crystal controlled 20 kHz steps - TBS crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) 100 kHz (channels 380-549), PRC-10, PRC-10A
40.000 MHz to 48.000 MHz American Infantry Band - portable tactical radios - WWII vintage 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) 50 kHz channels - AM voice, close air support and tank command nets
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
  • 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
