High Frequency Beacon
Contents[hide] |
Description
Freq (kHz) | Station ID | Location | Operation Notes | Last reported |
1654.95 | PRV | Preveza, Greece | Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: ndblist). | April 15, 2012 |
2008.4 | Dits | Nevada USA | (CW ditter 130 mW) N/S dipole, battery power, night only. Approximate CW timing: 191 millisecond dit duration, 1.55 second repetition, 1.5 minute ON cycle, 3 minute OFF cycle [1] | December 27, 2018 |
2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 10 second repetition, 24/7 [2] | September 14, 2018 |
3450 | OK | OK | (Source: HF Underground Forum [3]) (Youtube video) | January 5, 2012 |
3579.7 | "HPY NEW YEAR 2010 DE PIRATE BEACON” & dashes. December 28, 2010. (4) | 2010 | ||
3810 | SV1TEST | Athens, Greece (KM18VB) | no further info. (Source: UDXF) | |
4056 | dasher | Reported on March 11, 2011 by bryan24230 | ||
4062 | C | SW, probably CA | Very drifty, but slow drift, logged form 4052 to 4063. Its morse is not timed correcctly, it is probably sending a C with a short first dah (longer than dit, shorter than dah), but it could be an ER with a long dit, or a TR with a short dah. 24/7 | |
4078.14 | WW | Colorado | 300-400 mW Inverted L night time only | |
4077.27 | MO | Oklahoma | Solar 200 mW 118ft end fed wire 24/7 (Youtube video) | |
4079.7 | TMPnnn | SW Arizona | The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [4] | March 4, 2012 |
4089 | . | Death Valley N.P. | About 80 dits/minute, 24/7, 500 mW to inv. vee. dipole | |
4091 | DM | N. America | No further info (Source: HF Underground Forum) | August 11, 2011 |
4094.2 | PA | Arkansas | Solar power 200 mW Dipole 24/7 | |
| WV | | ||
4096 | ......_ | VA | 6 dots 1 dash | March 24, 2012 |
4096.1 | Dasher | Joshua Tree N.P. | 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 | March 24, 2012 |
4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [5] [6] | April 6, 2013 |
4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [7] | March 24, 2012 |
4097.2 | Dasher | Inyo County, CA near DVNP | 55 dashes per minute with chirp when sun is low; day-only, at 5300 ft. elevation ('Inyo-whooper'), inv. vee., 0.5w | |
4097.4 | KX | "KX" ten times, then "TEMP IN F", then the temp (three times) inside the enclosure, then "TEMP OUT F", and the outside temp, again three times. | ||
4098.2 ~ 4104+ | ZN | Western USA | Drifts up to 4104+ kHz during daylight hours, drifts down to 4098 kHz just after sunset, ZN sometimes heard run together like a prosign with an extra dash between the Z and N: "dah-dah-di-di-dah-dah-dit" or --..--. | September 08, 2018 |
4100.1 | H | Unknown | "H" repeated ID only, Source: HF Underground, 4 MHz Western USA Beacons | September 10, 2018 |
4102.8 | W... | southeast California desert | Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 | September 12, 2018 |
4194 | MX | Europe | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. | |
4608 | MXC | Europe | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX. | |
5157.6 | Dasher | Florida | BLINKY 200 mW Dipole 24/7 | |
5484 | SD | San Diego, CA | ||
5499.13 | Dasher | WA | ||
5678.4 | Dasher | Colorado | PIKE solar/battery 100 mW Dipole 24/7 "Honker" | |
6,375.00 | Common and Precious 4 | Berlin, Germany | CW only. Solar powered with Battery backup. 1,5W into a short vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 17, 2018 |
6,398.5 | Common and Precious 2 | Berlin, Germany | CW only. Grid powered. 25W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
6547.0 | PRV | Preveza, Greece | Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: UDXF). Also reported on 6852.1 | January 22, 2012 |
6549.3 | FL | Florida | 300 mW Dipole 24/7 | |
6626.2 | S | Inyo County, CA, near DVNP | About 60-200 dashes per min., sun-only, ~200 mW ('Rocky') | |
6626.4 | Dits | Mojave N.P. | Fast 'drippy' sounding dits about 100/min., sun-only, 1.5 watts ('Rainy') | |
6700.4 | Dasher | Joshua N.P. | About 62 dashes per min., 24/7 (Hexy2k) | |
6815 | SV1TEST | Athens, Greece (KM18VB) | Active 2010-2011, no further info. (Source: UDXF) (Youtube video) | |
X9Q | S.E. Europe or Middle East | Sporadic operation, no further info. (Source: UDXF) | April 2012 | |
6816 | FU | N. America | Active June 2011, no further info. (Source: A*C*E [8], [9]) (MP3 audio recording) | January 20, 2012 |
HA | N. America | Active July 2011, no further info. (Source: A*C*E [10], HF Underground Forum [11]) . Sometimes the frequency is reported as "6815 kHz USB". (MP3 audio recording) | July 9, 2011 | |
6852.1 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via sw6hmu@yahoo.gr Former website [12] closed. Reported also on 6547.0 and 1654.95 kHz | April 24, 2012 |
6900 | Beeper | 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [13]) | October 12, 2011 | |
6947.1 | 13 dits and 1 dah | No further info (Source: HF Underground Forum [14]) | October 24, 2011 | |
6961 | TR | Mojave desert, CA | (Source: HF Underground Forum [15]) | October 23, 2011 |
6994.8 | - | Norfolk, UK (JO02) | "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS RRR RRR RRR REPORTS TO UKBEACON _ GMAIL.COM" (Source: UDXF) | 2011 |
7542 | 55555 | W Europe or NE USA | (Source: [16], N&O-173(5), UDXF) | March 1, 2012 |
7998.1 | HI | Western USA | Morse CW beacon. Approximate timing: 9.64 seconds repetition, dit duration 128 milliseconds | 27 December, 2018 |
8000.0 | QRP | W. Europe | reported on UDXF by european monitors | February 9, 2014 |
8001.5 | S | S.W. Arizona | sun-only, 1 watt. strong signal daytimes. Recently reported on 8000.6 kHz (Source: UDXF). | 2011 |
8003 | Dasher | Colorado | Solar/battery dipole 24/7 "Pike 78" 78 dashes/min | |
8191.7 | Dasher | Southwestern USA | 4 second dash (somewhat variable), likely 2nd harmonic of Viking on 4095.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
8192.7 | Dasher | Southwestern USA | 2.3 second dash, likely 2nd harmonic of Haystack on 4096.38 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
8193.7 | Ditter | Western USA | 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
8193.8 | (Source: HF Underground Forum [17]) | October 23, 2011 | ||
8200.1 | D | Unknown | (Source: HF Underground Forum) | September 08, 2018 |
8211.7 | OR | |||
8261 | F | Western Canada | 250mW into a 1/2 wave inverted vee, 1400-0500 | |
8350 | Dasher | North Carolina | (Source: HF Underground Forum [18]) | December 31, 2011 |
8497.7 | Dasher | Pike 26 26 dashes/min | ||
8519.7 | (dasher) | N. America | Active August 2011, no further info. (Source: HF Underground Forum) | August 10, 2011 |
10236.7 | Dasher | FL | ||
10,237.74 | Common and Precious | Berlin, Germany | Grid powered. 5W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
11002.7 | CO | Colorado | Solar battery 300 mW dipole 24/7 | |
11009.9 | S | ? | Discovered at 1032 UTC on 2011-03-26 in Australia (1) | |
11428 | CZ | ? | (Source: HF Underground Forum [19]) | January 3, 2012 |
13168.1 | dasher | N. America | No further info. (Source: UDXF, June 2011) | |
26510 | Common and Precious 3 | Berlin, Germany | Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
26598 | Dasher | SW US | ~1/2 second dash every 29-31 seconds. 24/7. | |
27125 | AOH | California | 16mW QRP 11m beacon CW ID "AOH" CB Channel 14 27.125 MHz Beacon | |
27140.8 | 50RS497 | Russia | 27.141 MHz 27.140 MHz USB 27.142 MHz LSB CW ID 50RS497 | |
27141.6 | 14RS000 | France | 200 mW power 27.1416 MHz 27.142 MHz beacon CW ID 14RS000 + long tone burst 27.140 MHz USB 27.143 MHz LSB | |
27175 | 153SD101 | Thailand | CB Channel 18 CW ID 153SD101 | |
27185 | CW ID in FM mode | Poland | Morse code modulated FM CB Channel 19 | |
27205 | FM voice 11m CB repeater beacon | Sweden | simplex repeater - DTMF mid band CB channel 20 | |
27255 | CW | Switzerland | CB Channel 23 - 10w power CW ID : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN | |
27405 | 1 dot/minute | Germany | 1 watt power 1 pip per minute CB Channel 40- 27.405 MHz | |
27499.6 | 50KS00 | Moscow, Russia | 2 watt power beacon 27.500 MHz LSB CW ID 50KS00 | |
27500 | 69BY | Costa Rica | CW ID 69BY [also on 27550 and 27610] | |
27500 | Pips | Mexico City | CW pips (unknown TX power) | |
27500 | 38 Voice | Greenland | USB voice ID "38 voice beacon" | |
27500 | 153RT007 | Thailand | CW QRP Beacon 27.5 MHz 27.500 MHz | |
27501 | 2KP | Kansas | 25 watt power CW ID 2KP | |
27550 | 69BY | Costa Rica | CW ID 69BY [also on 27500 and 27610] | |
27596 | Pips | UNID | One beep every second - 27600 LSB 27598 USB 27.600 MHz 27.595 MHz | |
27610 | 69BY | Costa Rica | CW ID 69BY [also on 27500 and 27550] |
Telemetry Pirate Beacon
Windy Beacon
- HiFER
