HF pagers
Frequency List
Note: This list is a dynamic list and will never be complete. Many of these systems - especially the paging systems and telemetry or data link systems, act as de facto 11 meter beacons and de facto high frequency beacons. Included FSK data signals and pager signals - 25 to 30 MHz, included 29.7 MHz to 30 MHz portion above the 10 meter ham radio allocation 28 to 29.7 MHz but below the official beginning of VHF at 30.000 MHz
| Frequency | Remarks |
| 25.775 MHz | On-site and hospital paging, FM voice and data (Western Europe) - confirmed active July 2022 |
| 26.100 MHz | Hospital pagers - Europe FM mode |
| 26.115 MHz | FSK data link |
| 26.150 MHz | Hospital pagers - Europe - FM mode - confirmed active October 2021 |
| 26.160 MHz | Marine Instruments Radio Buoys |
| 26.165 MHz | Marine Instruments Radio Buoys |
| 26.170 MHz | Marine Instruments Radio Buoys |
| 26.175 MHz | Marine Instruments Radio Buoys |
| 26.200 MHz | On site paging systems - UK |
| 26.250 MHz | UK Paging on-site pager - confirmed active October 2021 |
| 26.250 MHz | Hospital pagers (Holland) FM mode |
| 26.300 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.350 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.400 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.450 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland - FM mode - confirmed active June 2022 |
| 26.550 MHz | POCSAG pager - Europe and UK |
| 26.555 MHz | POCSAG pager - Europe |
| 26.605 MHz | POCSAG Pager - UK and Western Europe |
| 26.650 MHz | Hospital pagers - Europe and UK |
| 26.695 MHz | Offset frequency for 26.700 MHz, heard in Western Europe and UK - confirmed active June 2022 |
| 26.700 MHz | European on-site paging systems - confirmed active July 2022 |
| 26.703 MHz | Offset frequency for 26.7025 MHz, heard in Western Europe and UK |
| 26.707 MHz | UK Paging, often slightly offset (26.7065 MHz, etc.) |
| 26.710 MHz | UK Paging, often slightly offset (26.709 MHz, etc.) |
| 26.713 MHz | UK Paging, offset 26.7125 MHz |
| 26.720 MHz | Data link and telemetry systems, Latin America |
| 26.735 MHz | European paging systems, possibly also used in UK |
| 26.739 MHz | FSK data links (narrowband bursts) - dial frequency 26.737 MHz USB or 26.740 MHz LSB |
| 26.740 MHz | Data link and telemetry systems, Latin America |
| 26.750 MHz | Hospital pagers Europe - POCSAG - confirmed active July 2022 |
| 26.751 MHz | Pager - offset frequency 26.7505 or 26.751 MHz - Western Europe |
| 26.835 MHz | UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.8350 MHz |
| 26.850 MHz | Hospital pagers - Europe FM mode - FSK - confirmed active October 2021 |
| 26.855 MHz | Hospital pagers - Europe FM mode - FSK - confirmed active October 2021 |
| 26.859 MHz | FSK data links (narrowband bursts) - dial frequency 26.857 MHz USB or 26.860 MHz LSB |
| 26.885 MHz | POCSAG pager - Europe |
| 26.920 MHz | UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.9200 MHz |
| 26.935 MHz | Data link or telemetry system, unknown origin or source, possibly Middle East - FM mode |
| 26.935 MHz | POCSAG pager - Europe |
| 26.940 MHz | POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system |
| 26.945 MHz | Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK |
| 26.950 MHz | Hospital pagers on-site paging systems Europe - confirmed active October 2021 |
| 26.950 MHz | POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system |
| 26.955 MHz | Paging heard on several Russian SDRs, possible alternate to 26.945 MHz, 26.95 MHz and 26.96 MHz frequencies? |
| 26.960 MHz | Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK |
| 26.995 MHz | Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4 watt PTDFM FSK (FM) 27MHz transmitter |
| 26.995 MHz | Remote Control Technology Medium Range Wireless Switch System MRWSS model # 01214 2 watt FSK (FM) 27MHz transmitter |
| 27.000 MHz | Russian data link or telemetry system, 10-12 kHz, MFSK |
| 27.000 MHz | POCSAG Pager heard in UK and Europe - unknown source |
| 27.007 MHz | POCSAG paging signal, heard in Finland (unknown source), possibly offset 27.005 MHz or 27.0075 MHz |
| 27.050 MHz | POCSAG Pager heard in UK and Europe - unknown source |
| 27.069 MHz | FSK data links (narrowband bursts) - dial frequency 27.067 MHz USB or 27.070 MHz LSB |
| 27.070 MHz | POGSAG Pager FM - Russian origin - 27 MHz Russian paging system frequency |
| 27.090 MHz | European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz) |
| 27.095 MHz | European standardized Eurobalise train telemetry system 27,095 MHz +/- 500 kHz 26.695 MHz - 27.595 MHz |
| 27.100 MHz | European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz) |
| 27.100 MHz | FSK data links (narrowband bursts) - dial frequency 27.097 MHz USB or 27.103 MHz LSB |
| 27.100 MHz | POCSAG Pager heard in UK and Europe - unknown source |
| 27.120 MHz | POCSAG Pager Signals heard in UK - unknown origin |
| 27.129 MHz | FSK data links (narrowband bursts) |
| 27.141 MHz | FSK data links (narrowband bursts) - dial frequency 27.138 MHz USB or 27.144 MHz LSB |
| 27.143 MHz | FSK data links (narrowband bursts) - dial frequency 27.140 MHz USB or 27.146 MHz LSB |
| 27.145 MHz | THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 44 output version |
| 27.179 MHz | FSK data links (narrowband bursts) - dial frequency 27.177 MHz USB or 27.180 MHz LSB |
| 27.195 MHz | Remote Control Technology Short Range Wireless Switch System SRWSS model # 01215 1 watt PTDFM FSK (FM) 27MHz transmitter |
| 27.200 MHz | POCSAG Pager heard in UK and Europe - unknown source |
| 27.220 MHz | POCSAG Pager Signals heard in UK - unknown origin |
| 27.233 MHz | POCSAG Paging signals, narrowband (center frequency 27.233, tune 27.230 MHz USB) |
| 27.250 MHz | POCSAG pager - heard in UK, 8-10 kHz wide signal |
| 27.250 MHz | POCSAG Pager heard in UK and Europe - unknown source |
| 27.255 MHz | Radio Control RC Service Part 95 25 watt power limit, 8.5 kHz bandwidth limit in USA |
| 27.255 MHz | Multiple-site FSK 27 MHz data link system noted near Highland Falls, NY USA, nearly constant FSK data bursts - off the air? |
| 27.255 MHz | Multiple-site FSK 27 MHz data link system noted near Rockport, Maine - FSK data bursts identical to those seen on Highland Falls NY SDR |
| 27.255 MHz | Data link system located in rural Virginia, roughly 20 miles north of Richmond, VA (data bursts on 27.255 MHz) |
| 27.255 MHz | RadioShack 7 watt FSK paging transmitter on-site system model PG-99 17-6020 - 100 unique receiver (pager) IDs supported |
| 27.255 MHz | RadioShack 4 watt FSK paging transmitter on-site system model 17-6023 - 1000 unique receiver (pager) IDs supported |
| 27.255 MHz | Linear Controls XT-1 1-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D |
| 27.255 MHz | Linear Controls XT-4 4-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D |
| 27.255 MHz | Linear Controls XT-1H 1-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D |
| 27.255 MHz | Linear Controls XT-2H 2-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D |
| 27.255 MHz | THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 12w output version |
| 27.259 MHz | FSK data links (narrowband bursts) - dial frequency 27.257 MHz USB or 27.260 MHz LSB |
| 27.319 MHz | FSK data links (narrowband bursts) - dial frequency 27.317 MHz USB or 27.320 MHz LSB |
| 27.450 MHz | Paging, heard in several parts of Europe, sometimes an unmodulated FM carrier transmitted - 27.45 MHz |
| 27.450 MHz | Alarm system datalinks - UK - 500mW power limit (considered a SRD or RC device) |
| 27.505 MHz | POCSAG Paging Signals 8-12 kHz wide |
| 27.510 MHz | Paging, voice and data - possibly offset 27.5125 MHz or 27.513 MHz |
| 27.745 MHz | Data link, telemetry and short range wireless controls - Europe and elsewhere |
| 27.845 MHz | POCSAG Pager - UK and/or Europe |
| 27.850 MHz | POCSAG paging signals - Europe |
| 27.950 MHz | POCSAG Paging - Heard in UK (June 2022) |
| 27.970 MHz | FSK data links |
| 27.980 MHz | FSK data links |
| 27.990 MHz | FSK data links |
| 27.992 MHz | FSK data links - 27.992 MHz 27.993 MHz |
| 27.995 MHz | FSK data links |
| 29.700 MHz | Telemetry, datalink |
| 29.750 MHz | POCSAG Paging Pager - Heard in UK, likely European origin 29.75 MHz POCSAG |
| 29.800 MHz | POCSAG Paging Pager - Heard in UK, likely European origin 29.8 MHz POCSAG |
| 29.850 MHz | POCSAG Paging Pager - Heard in UK, likely European origin 29.85 MHz POCSAG |
| 29.875 MHz | Telemetry and data link systems, Latin America, Europe |
| 29.900 MHz | POCSAG Paging Pager - Heard in UK, likely European origin 29.9 MHz POCSAG |
| 29.950 MHz | POCSAG Paging Pager - Heard in UK, likely European origin 29.95 MHz POCAG |
Frequency List - Europe and UK
| 26.100 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.150 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.200 MHz | Hospital and on-site paging systems, Italy, Holland, UK and others - very active frequency |
| 26.220 MHz | UK Paging on-site pager |
| 26.225 MHz | UK Paging on-site pager |
| 26.250 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.300 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.350 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.400 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.450 MHz | European standard hospital and on-site on-campus paging - Europe and UK |
| 26.500 MHz | European standard hospital and on-site on-campus paging |
| 26.500 MHz | Italy Paging on-site pager (wide signal, 12-13 kHz bandwidth) |
| 26.510 MHz | European POCSAG paging signal |
| 26.550 MHz | European standard hospital and on-site on-campus paging |
| 26.600 MHz | European standard hospital and on-site on-campus paging |
| 26.605 MHz | UK Paging Frequency, also European systems |
| 26.635 MHz | UK Paging on-site systems |
| 26.650 MHz | European standard hospital and on-site on-campus paging |
| 26.750 MHz | European standard hospital and on-site on-campus paging |
| 26.800 MHz | European standard hospital and on-site on-campus paging |
| 26.835 MHz | POCSAG pager - Eastern Europe or Russia source |
| 26.850 MHz | European standard hospital and on-site on-campus paging |
| 26.855 MHz | Hospital pagers - European source |
| 26.900 MHz | European standard hospital and on-site on-campus paging - very active frequency |
| 26.938 MHz | POCSAG pager - Europe - offset frequency 26.937 MHz 26.9375 MHz |
| 26.950 MHz | European standard hospital and on-site on-campus paging |
| 26.950 MHz | International fixed service allocation |
| 26.955 MHz | International fixed service allocation |
| 27.150 MHz | POCSAG Pager heard in UK and Europe - unknown source |
| 27.500 MHz | Hospital pagers (Holland) FM mode - POCSAG signals noted on frequency |
| 27.847 MHz | POCSAG Pager - UK and/or Europe offset frequency 27.8465 MHz |
| 27.848 MHz | POCSAG Pager - UK and/or Europe offset frequency 27.8475 MHz |
Keywords:
