High Frequency Beacon
Revision as of 23:20, 4 August 2024 by R4002 (Talk | contribs)
Description
PRV (6852 kHz) under test
4096.85 "Marin Dit", 24/7 5-10 mW, harmonic of 8193.77 radiates better
2097 A Arizona - 15 watts max., 10 second repetition, 24/7 [2] July 18, 2023
4094 UFO unknown id's UFO TMP three times, after TMP two numbers are sent then back to dashes. On the air around Nov 2020 2021
4095.650 DW SW Desert Desert Whooper - (1 Watt) 30 Whoops & ID - After 6 cycles sends Bat-Outside Temp -Inside Temp - Solar Panel current 24/7/365 https://www.hfunderground.com/board/index.php?topic=85047.0 July 23, 2023
4096.1 Dasher Joshua Tree N.P. 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 2021
4096.2 Buddha -Calif Desert Slow dasher called Buddha, was "Phallaxy" was "Viking". About 30 mW, daytime only. On for 3 seconds, off for 3 seconds 2021
4096.85 "Marin Ditter" Marin County 24/7 5-10 mW, 2nd harmonic of 8193.77 radiates better 2021
4097.08 Dasher unknown Slow Dasher, 2secs on and 2 secs off. Discovered Nov. 2020, it does appear to be related to 7997.2 kHz. The two dashers appear to be in sync. 2021
4097.1 Dasher unknown Fast Ditter. New in 2021 2021
4102.8 W... southeast California desert Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 2021
6700.4 Dasher Joshua N.P. About 62 dashes per min., 24/7 (Hexy2k) 2021
8193.7 Ditter Western USA 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) July 23, 2023
27255 Pager Beacon II Richmond, Virginia “Pager Beacon II” 1.5 second burst / 4.5 second delay cycle, 5w RF output on CB Channel 23 frequency 27.255 MHz Currently Testing Antennas (Source and Transmitted Audio: [3]
1654.95 PRV Preveza, Greece Op: SW6HMU, QSL via [email protected] (Source: ndblist). April 15, 2012
3810 SV1TEST Athens, Greece
(KM18VB)
4095.4 Common and Precious 5 JO62, Germany CW + RTTY. Telemetry Data. Active
6375 Common and Precious 4 Berlin, Germany CW only. Solar powered with Battery backup. 1,5W into a short vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) Jule 17, 2018
6398.5 Common and Precious 2 Berlin, Germany CW only. Grid powered. 25W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) Jule 19, 2017
6547 PRV Preveza, Greece Op: SW6HMU, QSL via [email protected] (Source: UDXF). Also reported on 6852.1 January 22, 2012
6815 SV1TEST Athens, Greece
(KM18VB)
X9Q S.E. Europe or
Middle East
6852.1 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via [email protected] Former website [4] closed. Reported also on 6547.0 and 1654.95 kHz April 24, 2012
6994.8 - Norfolk, UK
(JO02)
2011
7542 55555 W Europe or NE USA (Source: [5], N&O-173(5), UDXF) March 1, 2012
10237.74 Common and Precious Berlin, Germany Grid powered. 5W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) Jule 19, 2017
26510 Common and Precious 3 Berlin, Germany 26.510 MHz Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) Jule 19, 2017
27141.6 14RS000 France JN38 200 mW power 27.1416 MHz 27.142 MHz beacon CW ID 14RS000 + long tone burst 27.140 MHz USB 27.143 MHz LSB
27175 153SD101 Thailand CB Channel 18 27.175 MHz CW ID 153SD101
27185 CW ID in FM mode Poland Morse code modulated FM CB Channel 19
27205 FM voice 11m CB repeater beacon Sweden simplex repeater - DTMF mid band CB channel 20 27.205 MHz
27245 siren-like "whoop" UK 1 watt power 1 pip per minute CB Channel 25 Solar Powered Beacon 27.245MHz 27MHz UK CB beacon
27255 CW Switzerland CB Channel 23 27.255 MHz - 10w power CW ID  : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN
27405 1 dot/minute Germany 1 watt power 1 pip per minute CB Channel 40- 27.405 MHz
27499.6 50KS00 Moscow, Russia 2 watt power beacon 27.500 MHz LSB 27.4996 MHz CW ID 50KS00
27500 153RT007 Thailand CW QRP Beacon 27.5 MHz 27.500 MHz 11m beacon frequency
27500 19/27MHZDX Netherlands CW ID VVV 19/27MHZDX JO21BU 20W 11MTRBEACONATGMAIL.COM
27550 69BY Costa Rica CW ID 69BY alternate freq
27610 69BY Costa Rica CW ID 69BY primary 27.610 MHz 27609.9 27.609.9 MHz Sept 8, 2021
Telemetry Pirate Beacon
Windy Beacon
Desert Whooper
This telemetry beacon broadcasts on 4095.70 and has been logged widely on the West Coast, up into Canada, as far west as Hawaii and as far east as Maryland. It sends a Morse Code ID of DW, then thirty upward 150 Hz sweeps (whoops), repeats 6 times then sends telemetry: BAT is in volts DC. oTMP is in degrees F with a calibrated outdoor thermistor, iTMP is in degrees F using a digital two wire sensor within the weathertight box and PV is in milliAmps to monitor solar panel performance.
QSL Card
