HF pagers
Revision as of 18:20, 5 January 2024 by R4002 (Talk | contribs)
List of known pager paging data link data systems using digital modes remote control radio control in the 26-28 MHz CB or 11-meter frequency range.
See also the Remote Control FCC Part 95 Class C Page - Remote Control Radio Service (RCRS), FCC Rules Part 95, Personal Radio Services, Subpart C—Radio Control Radio Service 95.701-95.899, previously 95.201-95.225
Frequency List
Note: This list is a dynamic list and will never be complete. Many of these systems - especially the paging systems and telemetry or data link systems, act as de facto 11 meter beacons and de facto high frequency beacons. Included FSK data signals and pager signals - 25 to 30 MHz, included 29.7 MHz to 30 MHz portion above the 10 meter ham radio allocation 28 to 29.7 MHz but below the official beginning of VHF at 30.000 MHz
Frequency Remarks
26.100 MHz Hospital pagers - Europe - FM voice and POCSAG
26.150 MHz Hospital pagers - Europe - FM voice and POCSAG
26.200 MHz On site paging systems - UK
26.250 MHz UK Paging on-site pager - confirmed active December 2023
26.300 MHz Hospital pagers (Holland) FM mode - confirmed active December 2023
26.350 MHz Hospital pagers (Holland) FM mode - confirmed active December 2023
26.400 MHz Hospital pagers (Holland) FM mode - confirmed active December 2023
26.450 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.500 MHz Paging, heard in Europe, noted use in Holland - FM mode - confirmed active December 2023
26.550 MHz POCSAG pager - Europe and UK
26.555 MHz POCSAG pager - Europe
26.605 MHz POCSAG Pager - UK and Western Europe
26.630 MHz POCSAG paging signals, unknown source
26.635 MHz POCSAG pager system, unknown origin
26.650 MHz Hospital pagers - Europe and UK
26.695 MHz Offset frequency for 26.700 MHz, heard in Western Europe and UK - confirmed active December 2023
26.700 MHz European on-site paging systems - confirmed active December 2023
26.703 MHz Offset frequency for 26.7025 MHz, heard in Western Europe and UK
26.707 MHz UK Paging, often slightly offset (26.7065 MHz, etc.)
26.710 MHz UK Paging, often slightly offset (26.709 MHz, etc.)
26.713 MHz UK Paging, offset 26.7125 MHz
26.720 MHz Data link and telemetry systems, Latin America
26.735 MHz European paging systems, possibly also used in UK
26.739 MHz FSK data links (narrowband bursts) - dial frequency 26.737 MHz USB or 26.740 MHz LSB
26.740 MHz Data link and telemetry systems, Latin America
26.750 MHz Hospital pagers Europe - POCSAG - confirmed active December 2023
26.751 MHz Pager - offset frequency 26.7505 or 26.751 MHz - Western Europe
26.835 MHz UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.8350 MHz
26.850 MHz Hospital pagers - Europe FM mode - FSK - confirmed active December 2023
26.855 MHz Hospital pagers - Europe FM mode - FSK - confirmed active December 2023
26.859 MHz FSK data links (narrowband bursts) - dial frequency 26.857 MHz USB or 26.860 MHz LSB
26.885 MHz POCSAG pager - Europe
26.920 MHz UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.9200 MHz
26.935 MHz Data link or telemetry system, unknown origin or source, possibly Middle East - FM mode
26.935 MHz POCSAG pager - Europe
26.940 MHz POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system
26.945 MHz Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK
26.950 MHz Hospital pagers on-site paging systems Europe - confirmed active December 2023
26.950 MHz POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system
26.955 MHz Paging heard on several Russian SDRs, possible alternate to 26.945 MHz, 26.95 MHz and 26.96 MHz frequencies?
26.960 MHz Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK
26.995 MHz Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4 watt PTDFM FSK (FM) 27MHz transmitter
26.995 MHz Remote Control Technology Medium Range Wireless Switch System MRWSS model # 01214 2 watt FSK (FM) 27MHz transmitter
27.000 MHz Russian data link or telemetry system, 10-12 kHz, MFSK
27.000 MHz POCSAG Pager heard in UK and Europe - unknown source
27.007 MHz POCSAG paging signal, heard in Finland (unknown source), possibly offset 27.005 MHz or 27.0075 MHz
27.050 MHz POCSAG Pager heard in UK and Europe - unknown source
27.069 MHz FSK data links (narrowband bursts) - dial frequency 27.067 MHz USB or 27.070 MHz LSB
27.070 MHz POGSAG Pager FM - Russian origin - 27 MHz Russian paging system frequency
27.080 MHz On site paging systems on premises pagers - Russia
27.080 MHz Data links, Eastern Europe, Russia
27.090 MHz European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz)
27.095 MHz European standardized Eurobalise train telemetry system 27,095 MHz +/- 500 kHz 26.695 MHz - 27.595 MHz
27.100 MHz European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz)
27.100 MHz FSK data links (narrowband bursts) - dial frequency 27.097 MHz USB or 27.103 MHz LSB
27.100 MHz POCSAG Pager heard in UK and Europe - unknown source
27.120 MHz POCSAG Pager Signals heard in UK - unknown origin
27.129 MHz FSK data links (narrowband bursts)
27.141 MHz FSK data links (narrowband bursts) - dial frequency 27.138 MHz USB or 27.144 MHz LSB
27.143 MHz FSK data links (narrowband bursts) - dial frequency 27.140 MHz USB or 27.146 MHz LSB
27.145 MHz THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 44 output version
27.179 MHz FSK data links (narrowband bursts) - dial frequency 27.177 MHz USB or 27.180 MHz LSB
27.195 MHz Remote Control Technology Short Range Wireless Switch System SRWSS model # 01215 1 watt PTDFM FSK (FM) 27MHz transmitter
27.195 MHz 4 watt paging systems - USA
27.200 MHz POCSAG Pager heard in UK and Europe - unknown source
27.220 MHz POCSAG Pager Signals heard in UK - unknown origin
27.233 MHz POCSAG Paging signals, narrowband (center frequency 27.233, tune 27.230 MHz USB)
27.235 MHz Digital modes (ROS, PSK31, etc) and paging found here - Europe CB Channel 24
27.245 MHz Digital modes (ROS, PSK31, etc) and paging found here - Europe CB Channel 25
27.250 MHz POCSAG pager - heard in UK, 8-10 kHz wide signal
27.250 MHz POCSAG Pager heard in UK and Europe - unknown source
27.255 MHz Radio Control RC Service Part 95 25 watt power limit, 8.5 kHz bandwidth limit in USA
27.255 MHz On-site paging systems 5 watt power limit - Finland
27.255 MHz Multiple-site FSK 27 MHz data link system noted near Highland Falls, NY USA, nearly constant FSK data bursts - off the air?
27.255 MHz Multiple-site FSK 27 MHz data link system noted near Rockport, Maine - FSK data bursts identical to those seen on Highland Falls NY SDR
27.255 MHz Data link system located in rural Virginia, roughly 20 miles north of Richmond, VA (data bursts on 27.255 MHz)
27.255 MHz RadioShack 7 watt FSK paging transmitter on-site system model PG-80 "8 channel" paging system - 8 different pager IDs supported
27.255 MHz RadioShack 7 watt FSK paging transmitter on-site system model PG-99 17-6020 - 100 unique receiver (pager) IDs supported
27.255 MHz RadioShack 4 watt FSK paging transmitter on-site system model 17-6023 - 1000 unique receiver (pager) IDs supported
27.255 MHz Linear Controls XT-1 1-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-4 4-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-1H 1-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-2H 2-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 12w output version
27.255 MHz Command Communications PS2000 PS2000AN PrivatePage On Premises Pager on-site hospital paging system
27.259 MHz FSK data links (narrowband bursts) - dial frequency 27.257 MHz USB or 27.260 MHz LSB
27.319 MHz FSK data links (narrowband bursts) - dial frequency 27.317 MHz USB or 27.320 MHz LSB
27.400 MHz On-site paging systems 5 watt power limit - Finland
27.430 MHz On-site paging systems 5 watt power limit - Finland
27.450 MHz Paging, heard in several parts of Europe, sometimes an unmodulated FM carrier transmitted - 27.45 MHz
27.450 MHz Alarm system datalinks - UK - 500mW power limit (considered a SRD or RC device)
27.450 MHz On-site paging systems 5 watt power limit - Finland
27.470 MHz On-site paging systems 5 watt power limit - Finland
27.490 MHz On-site paging systems 5 watt power limit - Finland
27.505 MHz POCSAG Paging Signals 8-12 kHz wide
27.510 MHz Paging, voice and data - possibly offset 27.5125 MHz or 27.513 MHz
27.575 MHz US Government Short-Distance Low-Power Service - data links, remote control, telecommand (or voice)
27.585 MHz US Government Short-Distance Low-Power Service - data links, remote control, telecommand (or voice)
27.650 MHz Data link/Carrier signal, FM/FSK, possible military, Norfolk, VA - confirmed active again December 2023
27.720 MHz On-site paging systems 5 watt power limit - Finland
27.740 MHz On-site paging systems 5 watt power limit - Finland
27.745 MHz Data link, telemetry and short range wireless controls - Europe and elsewhere
27.750 MHz On site paging - Turkey
27.760 MHz On-site paging systems 5 watt power limit - Finland - confirmed active December 2023
27.760 MHz MFSK datalink radio data link system, 10 kHz bandwidth - unknown location
27.775 MHz On site paging - Turkey
27.780 MHz On-site paging systems 5 watt power limit - Finland
27.800 MHz On-site paging systems 5 watt power limit - Finland
27.800 MHz On site paging - Turkey
27.820 MHz On-site paging systems 5 watt power limit - Finland
27.825 MHz On site paging - Turkey
27.840 MHz On-site paging systems 5 watt power limit - Finland
27.845 MHz POCSAG Pager - UK and/or Europe
27.850 MHz POCSAG paging signals - Europe
27.850 MHz On site paging - Turkey
27.860 MHz On-site paging systems 5 watt power limit - Finland
27.875 MHz On site paging - Turkey
27.880 MHz On-site paging systems 5 watt power limit - Finland
27.900 MHz On site paging - Turkey
27.900 MHz On-site paging systems 5 watt power limit - Finland
27.925 MHz On site paging - Turkey
27.940 MHz On-site paging systems 5 watt power limit - Finland - confirmed active December 2023
27.940 MHz Data link systems, Northern Europe, often on the air with Finnish pagers
27.950 MHz POCSAG Paging - Heard in UK (December 2023)
27.950 MHz On site paging - Turkey
27.970 MHz FSK data links
27.975 MHz On site paging - Turkey
27.980 MHz FSK data links
27.990 MHz FSK data links
27.992 MHz FSK data links - 27.992 MHz 27.993 MHz
27.995 MHz FSK data links
29.700 MHz Telemetry, datalink
29.750 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.75 MHz POCSAG
29.800 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.8 MHz POCSAG
29.850 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.85 MHz POCSAG
29.875 MHz Telemetry and data link systems, Latin America, Europe
29.900 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.9 MHz POCSAG
29.950 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.95 MHz POCAG
