VHF LADD
Trucking and Resource Roads Channels Canada Alaska
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth or 16K0F3E emission) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth - also known as 11K3F3E emission, 11K2F3E emission or 11K0F3E emission). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
Channel | Frequency | Remarks/Usage |
LADD 1 | 154.1000 MHz | LADD channel 1 - trucking and logging companies, natural resource agencies |
LADD 2 | 158.9400 MHz | LADD channel 2 - trucking and logging companies, natural resource agencies |
LADD 3 | 154.3250 MHz | LADD channel 3 - trucking and logging companies, natural resource agencies |
LADD 4 | 173.3700 MHz | LADD channel 4 - trucking and logging companies, natural resource agencies |
LD-1 | 151.7000 MHz | Loading Channel 1 |
LD-2 | 151.7450 MHz | Loading Channel 2 |
LD-3 | 151.7900 MHz | Loading Channel 3 |
LD-4 | 151.8050 MHz | Loading Channel 4 |
LD-5 | 151.8500 MHz | Loading Channel 5 |
RR-01 | 150.0800 MHz | Resource Road channel 1 |
RR-02 | 150.1100 MHz | Resource Road channel 2 |
RR-03 | 150.1400 MHz | Resource Road channel 3 |
RR-04 | 150.1850 MHz | Resource Road channel 4 |
RR-05 | 150.2000 MHz | Resource Road channel 5 |
RR-06 | 150.2450 MHz | Resource Road channel 6 |
RR-07 | 150.2600 MHz | Resource Road channel 7 |
RR-08 | 150.3200 MHz | Resource Road channel 8 |
RR-09 | 150.3650 MHz | Resource Road channel 9 |
RR-10 | 150.4100 MHz | Resource Road channel 10 |
RR-11 | 150.4400 MHz | Resource Road channel 11 |
RR-12 | 150.5000 MHz | Resource Road channel 12 |
RR-13 | 150.5300 MHz | Resource Road channel 13 |
RR-14 | 150.5450 MHz | Resource Road channel 14 |
RR-15 | 150.5600 MHz | Resource Road channel 15 |
RR-16 | 150.5900 MHz | Resource Road channel 16 |
RR-17 | 150.6800 MHz | Resource Road channel 17 |
RR-18 | 150.7100 MHz | Resource Road channel 18 |
RR-19 | 150.7700 MHz | Resource Road channel 19 |
RR-20 | 150.8300 MHz | Resource Road channel 20 |
RR-21 | 151.0100 MHz | Resource Road channel 21 |
RR-22 | 151.1300 MHz | Resource Road channel 22 |
RR-23 | 151.1900 MHz | Resource Road channel 23 |
RR-24 | 151.2200 MHz | Resource Road channel 24 |
RR-25 | 151.3100 MHz | Resource Road channel 25 |
RR-26 | 151.3400 MHz | Resource Road channel 26 |
RR-27 | 151.3700 MHz | Resource Road channel 27 |
RR-28 | 151.4300 MHz | Resource Road channel 28 |
RR-29 | 151.4600 MHz | Resource Road channel 29 |
RR-30 | 151.4900 MHz | Resource Road channel 30 |
RR-31 | 151.5200 MHz | Resource Road channel 31 |
RR-32 | 151.5800 MHz | Resource Road channel 32 |
RR-33 | 151.6100 MHz | Resource Road channel 33 |
RR-34 | 151.6400 MHz | Resource Road channel 34 |
RR-35 | 151.6400 MHz | Resource Road channel 35 |
