High Frequency Beacon
Description
| 2097 | A | Arizona | - 15 watts max., 10 second repetition, 24/7 [2] | July 18, 2023 |
| 4094 | UFO | unknown | id's UFO TMP three times, after TMP two numbers are sent then back to dashes. On the air around Nov 2020 | 2021 |
| 4095.650 | DW | SW Desert | Desert Whooper - (1 Watt) 30 Whoops & ID - After 6 cycles sends Bat-Outside Temp -Inside Temp - Solar Panel current 24/7/365 https://www.hfunderground.com/board/index.php?topic=85047.0 | July 23, 2023 |
| 4096.1 | Dasher | Joshua Tree N.P. | 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 | 2021 |
| 4096.2 | Buddha | -Calif Desert | Slow dasher called Buddha, was "Phallaxy" was "Viking". About 30 mW, daytime only. On for 3 seconds, off for 3 seconds | 2021 |
| 4096.85 | "Marin Ditter" | Marin County | 24/7 5-10 mW, 2nd harmonic of 8193.77 radiates better | 2021 |
| 4097.08 | Dasher | unknown | Slow Dasher, 2secs on and 2 secs off. Discovered Nov. 2020, it does appear to be related to 7997.2 kHz. The two dashers appear to be in sync. | 2021 |
| 4097.1 | Dasher | unknown | Fast Ditter. New in 2021 | 2021 |
| 4102.8 | W... | southeast California desert | Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 | 2021 |
| 6700.4 | Dasher | Joshua N.P. | About 62 dashes per min., 24/7 (Hexy2k) | 2021 |
| 8193.7 | Ditter | Western USA | 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | July 23, 2023 |
| 4095.4 | Common and Precious 5 | JO62, Germany | CW + RTTY. Telemetry Data. | Active |
| 6375 | Common and Precious 4 | Berlin, Germany | CW only. Solar powered with Battery backup. 1,5W into a short vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 17, 2018 |
| 6398.5 | Common and Precious 2 | Berlin, Germany | CW only. Grid powered. 25W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 6547 | PRV | Preveza, Greece | Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: UDXF). Also reported on 6852.1 | January 22, 2012 |
| 6852.1 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via sw6hmu@yahoo.gr Former website [3] closed. Reported also on 6547.0 and 1654.95 kHz | April 24, 2012 |
| 7542 | 55555 | W Europe or NE USA | (Source: [4], N&O-173(5), UDXF) | March 1, 2012 |
| 10237.74 | Common and Precious | Berlin, Germany | Grid powered. 5W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 26510 | Common and Precious 3 | Berlin, Germany | 26.510 MHz Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 27140.8 | 50RS497 | Russia | 27.141 MHz 27.140 MHz USB 27.142 MHz LSB CW ID 50RS497 | |
| 27141.6 | 14RS000 | France | JN38 200 mW power 27.1416 MHz 27.142 MHz beacon CW ID 14RS000 + long tone burst 27.140 MHz USB 27.143 MHz LSB | |
| 27175 | 153SD101 | Thailand | CB Channel 18 27.175 MHz CW ID 153SD101 | |
| 27185 | CW ID in FM mode | Poland | Morse code modulated FM CB [19] | |
| 27205 | FM voice 11m CB repeater beacon | Sweden | simplex repeater - DTMF mid band CB channel 20 FM 27,205 MHz voice ID in FM mode plus sound effects and multi-tone end of transmission burst | |
| 27245 | siren-like "whoop" | UK | 1 watt power 1 pip per minute CB Channel 25 Solar Powered Beacon 27.245MHz 27MHz UK CB beacon | |
| 27255 | CW | Switzerland | CB Channel 23 27.255 MHz - 10w power CW ID : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN | |
| 27405 | 1 dot/minute | Germany | 1 watt power 1 pip per minute CB Channel 40- 27.405 MHz | |
| 27499.6 | 50KS00 | Moscow, Russia | 2 watt power beacon 27.500 MHz LSB 27.4996 MHz CW ID 50KS00 | |
| 27500 | 153RT007 | Thailand | CW QRP Beacon 27.5 MHz 27.500 MHz 11m beacon frequency | |
| 27500 | 19/27MHZDX | Netherlands | CW ID VVV 19/27MHZDX JO21BU 20W 11MTRBEACONATGMAIL.COM | |
| 27550 | 69BY | Costa Rica | CW ID 69BY alternate freq | |
| 27610 | 69BY | Costa Rica | CW ID 69BY primary 27.610 MHz 27609.9 27.609.9 MHz | Sept 8, 2021 |
Telemetry Pirate Beacon
Windy Beacon
Desert Whooper
This telemetry beacon broadcasts on 4095.70 and has been logged widely on the West Coast, up into Canada, as far west as Hawaii and as far east as Maryland. It sends a Morse Code ID of DW, then thirty upward 150 Hz sweeps (whoops), repeats 6 times then sends telemetry: BAT is in volts DC. oTMP is in degrees F with a calibrated outdoor thermistor, iTMP is in degrees F using a digital two wire sensor within the weathertight box and PV is in milliAmps to monitor solar panel performance.
QSL Card
- HiFER 22 meter band 13.56 MHz 13560 kHz band Part 15 beacons
- 11m beacons 11 meter band/27 MHz CB beacons
