Letter beacon
Revision as of 20:34, 26 January 2010 by Strange Attractor (Talk | contribs)
  • Cluster beacons
  • MX — an ENIGMA and ENIGMA-2000 designation.
Location of letter beacons
These radio transmissions were discovered in the late 1960s. Their presence became known to the wider amateur radio community in 1978, when beacon “W” started transmitting on 3584 kHz, in the 80 meters band. There is indirect evidence that this particular transmitter was located in Cuba. <ref>Template:Cite book</ref>
In 1982 there were also reports, supposedly based on HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at Template:Coord, near the city of Khabarovsk in the USSR. <ref>Template:Cite book</ref><ref name="Schimmel">Template:Cite book</ref> A few years later, it was suggested that the “K” beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the “U” beacons were located at the Barents Sea coast, between Murmansk and Amderma. <ref name="Orr1984">Template:Cite journal</ref>
According to Schimmel, in 1986 the FCC released the following HF direction finding results for single letter beacons, all of which indicate locations in the USSR: <ref name="Schimmel"/>
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
The ENIGMA group also accepted these locations for cluster beacons "C", "D", "P" and "S", adding Vladivostok for beacon "F".<ref name="ENIGMA18">Template:Cite journal</ref>
A recent source (2006) regarding locations was published on the Web by Ary Boender.<ref>Template:Cite web</ref> This publication also contains an extensive list of frequencies of letter beacons, both current and historical. The following locations are stated for cluster beacons:
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (inactive)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Transmissions of the "P" beacon in December 2007, even on medium frequency (420 and 583 kHz) indicate the Russian Naval Base of Kaliningrad as a possible source.<ref name="RConnolly">Template:Cite journal</ref> Kaliningrad officially uses the ITU registered callsign RMP.
Types of letter beacons
The single letter beacons can be classified in two groups, the "Cluster beacons" and the "Channel markers". A beacon "P" exists in both groups. A third group, the FSK beacons, is now extinct. The following sections list the beacons currently (December 2007) active, according to published listeners’ reports.
Cluster beacons
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", "A", "M" and "K") have been regularly reported near 3594, 4558, 5154, 7039, 8495, 10872, 13528, 16332 and 20048 kHz. The term "cluster beacons" is frequently used for them, as these beacons transmit in parallel on frequencies only 0.1 kHz apart. These beacons transmit only their single-letter identifier in standard CW (A1A) using morse code.
ID letter Frequencies (kHz)
D 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7
P 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8
S 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9
C 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0
A 3595.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 <ref>Template:Cite web</ref>
F 7039.2
K 5154.3, 7039.3, 8495.3
M 5154.4, 7039.4, 8495.4, 10872.4, 13528.4, 16332.4
The majority of solitary beacons, however, and most notably "P" on various MF and HF frequencies, most of the time they are active transmit their single-letter identifier in morse code. However, sometimes the routine transmission is interrupted and brief messages are sent in fast morse code or in an FSK digital mode. Therefore, the proper term for these beacon-like single-letter transmissions is "channel markers" <ref name="Poundstone"/><ref name="Orr1984"/>, as their purpose is to occupy and identify a particular HF transmission channel when no traffic is transmitted. There is no evidence that the cluster beacon "P" and the solitary beacon "P" are directly related.
It was reported in Numbers and Oddities, issue 142, that beacon C on 8000 kHz also transmitted messages under the regular callsign RIW, which is allocated to a Russian naval communicatios station in Khiva, Uzbekistan.<ref>Template:Cite web</ref>
R 4325.9, 5465.9
V 3658.0, 5141, 5342, 6430.7, 6809, 7027.5, 8103.5, 10202
P <ref>Some transmission are in FSK morse code (F1A) instead of CW (A1A), but other beacon characteristics classify it as a solitary "P" beacon.</ref> 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079
C 8000
FSK beacons
This group includes the "K" and "U" beacons, which are no longer active. They transmitted their morse code single letter identification by shifting the frequency of the carrier by approximately 1000 Hz. This mode of "FSK-CW" is designated F1A. The use of FSK indicated that the transmitter was suitable for FSK data transmissions, like Radioteletype.
ENIGMA designation
ENIGMA devised a naming scheme for all stations in their sphere of interest. In the original scheme, the following identifications were issued to letter beacons: <ref>Template:Cite journal</ref>
ENIGMA ID Description
MX Cluster beacons
ENIGMA-2000, the internet based ENIGMA successor group, revised the original ENIGMA designators. The current designations for letter beacons are the following (since 2007):<ref>Template:Cite web</ref>
The purpose of the letter beacons is not known yet with certainty. Many theories have appeared in specialized publications but none is based on documentary evidence. They have been postulated to be radio propagation beacons, channel markers, used in tracking satellites, or used for civil defense purposes. <ref name="Poundstone">Template:Cite book</ref> Some stations of this family, in particular the “U” beacon, have been implicated in deliberate jamming.<ref>Template:Cite book</ref>
According to ENIGMA the cluster beacons are used by the Russian Navy (and especially the submarine branch) to find the most suitable radio frequency for contact based on current radio propagation conditions.<ref name="ENIGMA18"/>
Connolly also links "P" channel marker with communications facilities at the Russian naval base of Kaliningrad <ref name="RConnolly"/>. "P" transmissions carrying Russian Navy "XXX" (flash priority) morse code messages with callsigns RPM and RDL further support this view.
Similar systems
A few aero navigation Non Directional Beacons also transmit single letter identification codes. They can be easily distinguished from Letter beacons as they transmit in the allocated low frequency and medium frequency bands, most of them are listed in appropriate aviation handbooks and their transmission mode is A2A (full carrier with audio modulation).
Notes & References
  1. E.N.I.G.M.A. stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s. They issued a printed bulletin every few months, which was mailed to subscribers. The 18 in total issues of the ENIGMA bulletin contained a lot of interesting information about odd and mysterious high frequency transmissions, contributed from radio listeners worldwide. The reception logs were organized, collated and analyzed by the core ENIGMA staff. The coverage was mostly about the so-called Numbers stations, but there was also some coverage of letter beacons. Those bulletins were not archived in libraries and it is difficult to obtain copies today. The major achievement of ENIGMA was the systematic classification and naming of the numerous radio oddities, which were previously described by different and conflicting names in various publications. The original ENIGMA group was disbanded in 2000. In his farewell letter, ENIGMA co-founder Mike G. wrote that all ENIGMA publications and research material would be deposited at the British Library (Boston Spa).
  4. Spooks mailing list.
An article from Wikipedia, published under Creative Commons CC-BY-SA-3.0 free license.
