Letter beacon
- Cluster beacons
Location of letter beacons
The leter beacon radio transmissions were discovered in the late 1960s. Their presence became known to the wider amateur radio community in 1978, when beacon “W” started transmitting on 3584 kHz, in the 80 meters band. There is indirect evidence that this particular transmitter was located in Cuba. (3)
In 1982 there were also reports, supposedly based on HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at 48° 30' N - 134° 58' E, near the city of Khabarovsk in the USSR. (4), (5) A few years later, it was suggested that the "K" beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the "U" beacons were located at the Barents Sea coast, between Murmansk and Amderma. (6)
| ID letter | Location |
| C | Moscow, RUS |
| D | Odessa, UKR |
| O | Moscow, RUS |
| P | Kaliningrad, RUS |
| S | Arkhangelsk, RUS |
| Z | Mukachevo, UKR |
| C | Moscow, RUS |
| D | Sevastopol, UKR |
| F | Vladivostok, RUS |
| M | Magadan, RUS |
| S | Severomorsk, RUS |
| L | Tirana, ALB (inactive) |
| V | Khiva, UZB |
Types of letter beacons
The single letter beacons can be classified in two groups, the "Cluster beacons" and the "Channel markers". A beacon "P" exists in both groups. A third group, the FSK beacons, is now extinct. The following sections list the beacons currently (December 2007) active, according to published listeners’ reports.
Cluster beacons
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", "A", "M" and "K") have been regularly reported near 3594, 4558, 5154, 7039, 8495, 10872, 13528, 16332 and 20048 kHz. The term "cluster beacons" is frequently used for them, as these beacons transmit in parallel on frequencies only 0.1 kHz apart. These beacons transmit only their single-letter identifier in standard CW (A1A) using morse code.
| ID letter | Frequencies (kHz) |
| D | 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
| P | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8 |
| S | 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
| C | 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
| A | 3595.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 (10) |
| F | 7039.2 |
| K | 5154.3, 7039.3, 8495.3 |
| M | 5154.4, 7039.4, 8495.4, 10872.4, 13528.4, 16332.4 |
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier.
| R | 4325.9, 5465.9 |
| V | 3658.0, 5141, 5342, 6430.7, 6809, 7027.5, 8103.5, 10202 |
| P (12) | 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079 |
| C | 8000 |
FSK beacons
This group includes the "K" and "U" beacons, which are no longer active. They transmitted their morse code single letter identification by shifting the frequency of the carrier by approximately 1000 Hz. This mode of "FSK-CW" is designated F1A. The use of FSK indicated that the transmitter was suitable for FSK data transmissions, like Radioteletype.
ENIGMA designation
| ENIGMA ID | Description |
| MX | Cluster beacons |
According to ENIGMA the cluster beacons are used by the Russian Navy (and especially the submarine branch) to find the most suitable radio frequency for contact based on current radio propagation conditions. (7)
Similar systems
A few aero navigation Non Directional Beacons also transmit single letter identification codes. They can be easily distinguished from Letter beacons as they transmit in the allocated low frequency and medium frequency bands, most of them are listed in appropriate aviation handbooks and their transmission mode is A2A (full carrier with audio modulation).
Notes & References
- E.N.I.G.M.A. stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
- ENIGMA-2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
- Poundstone Willian: Big Secrets, Quill, New York, 1983, ISBN 0688048307, pages 191-193
- Spooks mailing list.
- William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications,CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
