Ionosonde
![]() | This article or section is under construction. |
A ionosonde, or chirpsounder, is a special radar for the examination of the ionosphere.
Description
An ionosonde consists of:
The transmitter sweeps all or part of the HF frequency range, transmitting short pulses. These pulses are reflected at various layers of the ionosphere, at heights of 100–400 km, and their echos are received by the receiver and analyzed by the control system. The result is displayed in the form of an ionogram, a graph of reflection height (actually time between transmission and reception of pulse) versus carrier frequency.
The basic ionosonde technology was invented in 1925 by Gregory Breit and Merle A. Tuve <ref name="Judd1988">Template:Cite book</ref> and further developed in the late 1920s by a number of prominent physicists, including Edward Victor Appleton. The term ionosphere and hence, the etymology of its derivatives, was proposed by Robert Watson-Watt.
An ionosonde is used for finding the optimum operation frequencies for broadcasts or two-way communications in the high frequency range.
- http://www.ngdc.noaa.gov/ionosonde/ : NOAA Ionosonde portal to information and data services
- http://www.ngdc.noaa.gov/stp/IONO/Dynasonde/ : NOAA Dynasonde: Real-time Ionospheric Explorer by advanced and prototype analysis methods.
- http://ulcar.uml.edu/digisonde.html : Lowell Center for Atmospheric Research, MA, USA
- http://ulcar.uml.edu/stationlist.html : Ionosonde (partial) station list by location
- http://www.iono.noa.gr : National Observatoy of Athens, Greece
- http://www.sil.sk.ca/cadi.html : Canadian Advanced Digital Ionosonde (CADI)
