High Frequency Beacon
Revision as of 03:49, 15 June 2011 by Strange Attractor (Talk | contribs)
Description
PRV (6852 kHz) under test
Freq (kHz) Station ID Location Operation Notes
3450 OK OK (Youtube video)
3579.7 "HPY NEW YEAR 2010 DE PIRATE BEACON” & dashes. December 28, 2010. (4)
3810 SV1TEST Athens, Greece
(KM18VB)
4096 ......_ VA 6 dots 1 dash
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie')
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie')
4097.2 Dasher Inyo County, CA
near DVNP
5484 SD San Diego, CA
5499.13 Dasher WA
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST Athens, Greece
(KM18VB)
Active, no further info. (Source: UDXF) (Youtube video)
6815 X9Q S.E. Europe or
Middle East
No further info. (Source: UDXF)
6852 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. Former website [1] closed.
6994.8 - Norfolk, UK "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS
8001.5 S S.W. Arizona sun-only, 1 watt. strong signal daytimes. Recently reported on 8000.6 kHz (Source: UDXF).
8211.7 OR
8350 Dasher North Carolina
10236.7 FL Dasher
13168.1 dasher N. America No further info. (Source: UDXF)
  3. "PRV" was often reported during the past few months and was unid until Linkz submitted a link to websites about this station. Linkz writes: I have no idea if this station is legit or a pirate. It's operator is Eystathios Karastathis (SW6HMU) from Preveza, Greece. He writes on his blog "PRV - 6852 kHz 15w cw BEACON with Dipole Ant on the air 17.30 pm- 8.00 am". According to his blog there is also a MF beacon "PRV beacon 500-531 khz am/cw 400 Watt" and a local AM broadcasting station "Studio 421" on 1655 kHz”. This beacon was last reported to UDXF on April 18, 2011.
External Links
