High Frequency Beacon
Description
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 | April 6, 2009 |
| | WV | | ||
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') | July 2011 |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') | July 2011 |
| 5499.13 | Dasher | WA | ||
| X9Q | S.E. Europe or Middle East | No further info. (Source: UDXF) | June 2011 | |
| 6816 | FU | N. America | Active June 2011, no further info. (Source: A*C*E [1], [2]) (MP3 audio recording) | September 11, 2011 |
| HA | N. America | Active July 2011, no further info. (Source: A*C*E [3], HF Underground Forum [4]) . Sometimes the frequency is reported as "6815 kHz USB". (MP3 audio recording) | July 9, 2011 | |
| 6852 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. Former website [5] closed. | 2011 |
| 6900 | Beeper | 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [6]) | October 12, 2011 | |
| 8211.7 | OR | |||
| 10236.7 | Dasher | FL | ||
- HiFER
External Links
