High Frequency Beacon
Revision as of 15:23, 23 December 2011 by Kendurx6 (Talk | contribs)
Description
PRV (6852 kHz) under test
2097 A Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 April 6, 2009
3450 OK OK (Youtube video)
3810 SV1TEST Athens, Greece
(KM18VB)
4096 ......_ VA 6 dots 1 dash
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') July 2011
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') July 2011
4097.2 Dasher Inyo County, CA
near DVNP
5484 SD San Diego, CA
5499.13 Dasher WA
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST Athens, Greece
(KM18VB)
X9Q S.E. Europe or
Middle East
No further info. (Source: UDXF) June 2011
6816 FU N. America Active June 2011, no further info. (Source: A*C*E [1], [2]) (MP3 audio recording) September 11, 2011
HA N. America Active July 2011, no further info. (Source: A*C*E [3], HF Underground Forum [4]) .
July 9, 2011
6852 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. Former website [5] closed. 2011
6900 Beeper 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [6]) October 12, 2011
6947.1 13 dits and 1 dah No further info (Source: HF Underground Forum [7]) October 24, 2011
6961 TR Mojave desert, CA (Source: HF Underground Forum [8]) October 23, 2011
6994.8 - Norfolk, UK
(JO02)
2011
8193.8 (Source: HF Underground Forum [9]) October 23, 2011
8211.7 OR
8350 Dasher North Carolina
8519.7 (dasher) N. America Active skin care products August 2011, no further info. (Source: HF Underground Forum) August 10, 2011
10236.7 Dasher FL
semenax
acne skin products
capsiplex
proactol plus
slimming pills
Phen375
slimming reviews
hgh advanced supplement
unique hoodia diet
phen375 review
meratol
  3. "PRV" was often reported during the past teeth whitener reviews few months and was unid until Linkz submitted a link to websites about this station. Linkz writes: I have no idea if this station is legit or a pirate. It's operator is Eystathios Karastathis (SW6HMU) from Preveza, Greece. He writes on his blog "PRV - 6852 kHz 15w cw BEACON with Dipole Ant on the air 17.30 pm- 8.00 am". According to his blog there is also a MF beacon "PRV beacon 500-531 khz am/cw 400 Watt" and a local AM broadcasting station "Studio 421" on 1655 kHz”. This beacon was last reported to UDXF on April 18, 2011.
External Links
