Pirate shortwave broadcasts tend to be on well-known frequencies. This allows listeners to quickly find a pirate station when it comes on the air, as they only have a relatively few number of fixed places to look. Some of the locations on the HF band that are in frequent use as of September 2007 include:
(Updated September 2018)
| 3465 kHz | AM - reported used in 2017 |
| 4020 kHz | AM/USB |
| 4025 kHz | AM/USB |
| 4060 kHz | AM/USB |
| 4065 kHz | AM/USB |
| 4080 kHz | AM/USB |
| 4085 kHz | AM/USB |
| 6770 kHz | AM - used by Old Time Radio |
| 6780 kHz | AM/USB - including nearby frequencies 6777 kHz, 6777.7 kHz and 6778 kHz |
| 6840 kHz | AM |
| 6850 kHz | usually AM |
| 6855 kHz | usually AM |
| 6870 kHz | AM/USB |
| 6915 kHz | AM/USB |
| 6920 kHz | AM/USB |
| 6930 kHz | AM/USB |
| 6935 kHz | AM/USB - Latin American pirates can also be heard here |
| 6945 kHz | AM/USB |
| 6950 kHz | AM/USB |
| 6955 kHz | AM/USB |
| 6965 kHz | AM/USB |
| 6969 kHz | LSB - Used by Cold Country Canada |
| 6970 kHz | AM |
| 6975 kHz | AM/USB - often used by XFM (also heard on 6970) |
| 7465 kHz | AM - noted use by YHWH religious pirate (September 2018) |
The 43 meter band (6765-7000 kHz) is where most US-based pirates are found, generally clustered around 6925 kHz. Because many pirates use older-generation transmitters, it is not uncommon to find stations on "6925" actually using 6924 kHz to 6926 kHz. AM transmissions operating in the 6924.5 kHz to 6925.9 kHz area are often logged.
Euro-Pirate Radio Frequencies
- 3920-3950 (75 meters)
- 6250 - Used in the 1980s
