11 meter
11 meter is often used by freebanders or CB operators using the "freeband" frequencies from between 25 MHz and CB channel 1 (26.965 MHz) and CB channel 40 (27.405 MHz) and the bottom edge of the 10 meter amateur band (28.000 MHz).  Common freeband frequencies include:
 - 26.515-26.955 MHz - Band C - "low band" or "lowers" all sorts of users, AM in the Americas, mixture of AM and FM elsewhere
 - 26.965-27.405 MHz - Band D - CB#US_.22FCC.22_.22CEPT.22_or_.22mid_band.22_CB_Frequencieslegal CB band - "mid band", "FCC band" or "CEPT" band
 - 27.405-27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
 - 27.415 MHz LSB - US calling/working frequencies (channels +5 kHz, 27.420 MHz, 27.425 MHz, 27.430 MHz, and so on in LSB mode)
