Pescadores
Revision as of 15:29, 16 January 2019 by R4002 (Talk | contribs)
Pescadores, Spanish and Portuguese for "fishermen" (also perscatori in Italian), is a term used to refer to voices on the pirate bands speaking non-English languages, often Spanish or Spanish-sounding. The original assumption was that these were fishermen from Mexico, the Caribbean, and points south, on boats in the Gulf of Mexico, talking to each other or to bases on land, but this has never been proven. Normally these stations are a random annoyance to pirates and pirate DXers, but occasionally they seem to be making an effort to interfere with pirate broadcasts. Vice versa, pirate stations will sometimes attempt to interfere with the pescadores' conversations.
Several English speaking fishing fleets have been logged in the 6-7 MHz region as well, especially those with New England or Boston accents, which have been logged on 6095 kHz, 6212 kHz, 6215 kHz, 6953 kHz, 6985 kHz, 6993 kHz and other frequencies, all in USB mode.
One of the most common frequencies to hear "peskies" is 6925 kHz LSB, followed by 6900 kHz USB/LSB and many others. Peskies are known to use "cute" or "easy to remember" frequencies such as 6969.6 kHz, 6666 kHz, 6666.6 kHz, 6777.7 kHz, 6789 kHz, 6888 kHz, 15151.5 kHz, etc. Peskies don't follow rules relating to use of USB vs. LSB or frequency steps. As a result, it is not uncommon to hear peskies interfering with each other during good propagation. In the Eastern Hemisphere, peskies are Asian fishermen (and possibly also land based transmissions) found all over the 3-30 MHz range. There is some overlap between legal HF marine communications and pescadores, as fishing fleet communications are found in the 6200 kHz to 6525 kHz 6 MHz marine band as well as the higher frequencies (and lower frequencies!) above and below the MF/HF maritime bands.
Freebanders on HF
  • 14654.5 kHz USB - Spanish
  • 10400 kHz USB - UNID unknown language
  • 10222.2 kHz USB - Spanish
  • 10022.2 kHz USB - Spanish
  • 10008.8 kHz USB - Spanish
  • 9779 kHz USB - Spanish speaking fishing fleets using frequencies in the 31 meter shortwave broadcast band
  • 9373 kHz USB - Spanish speaking fishing fleets using frequencies in the 31 meter shortwave broadcast band
  • 9182 kHz USB - Spanish language
  • 9055.5 kHz USB - Spanish
  • 9015 kHz USB/LSB - Portuguese heard
  • 8989 kHz USB - Spanish, busy
  • 8959 kHz USB - Spanish
  • 7000 kHz - 6200 kHz - USB/LSB, mix of Spanish, Portuguese, English and Italian have been heard
  • 7000 kHz LSB - often used (sometimes 7000 kHz USB as well)
  • 6980 kHz USB - "Island Peskies" - possibly out of Jamaica mon
  • 6970 kHz USB - "Island Peskies" - possibly out of Jamaica mon
  • 6966 kHz USB - "Island Peskies" - possibly out of Jamaica mon
  • 6925 kHz LSB - Portuguese
  • 6919 kHz LSB - Portuguese
  • 6900 kHz LSB - Spanish - North American "home channel" (also 6895 kHz, 6905 kHz, 6910 kHz, 6915 kHz, 6920 kHz, 6890 kHz)
  • 6900 kHz USB - Spanish
  • 6885 kHz USB - Spanish
  • 6868 kHz USB or LSB - Spanish/Portuguese
  • 6858 kHz USB or LSB - Spanish/Portuguese
  • 6838 kHz USB or LSB - Spanish/Portuguese
  • 6800 kHz USB or LSB - Spanish - usually
  • 6790 kHz USB and LSB, as well as nearby frequencies such as 6789 kHz USB/LSB
  • 6780 kHz USB and LSB - Spanish, Portuguese and English speakers have been logged here
  • 6695.5 kHz USB and 6696.6 kHz USB - Spanish (similar to 6666.6 kHz)
  • 6670 kHz USB - alternate to 6666.6 USB
  • 6666.6 kHz USB - 45 metros calling frequency - home channel similar to 6900 LSB
  • 6612 kHz USB - English language heard here, appears to be Caribbean fishermen or marine operators (with QRM from Spanish on 6610 kHz USB)
  • 6548.5 kHz USB - English language heard here, appears to be Caribbean fishermen or marine operators
  • 6400 kHz USB and LSB - 6400 kHz is used by PBS Pyongyang out of North Korea but is also a favorite of fishing fleets
  • 6095 kHz USB - Fishing boats out of Gloucester, MA have been logged here (see also: 6212 kHz, 6953 kHz, 6959 kHz and others)
  • 5555.5 kHz USB - Spanish
  • 5515 kHz USB - Spanish
  • 5500 kHz USB - Spanish
  • 5430 kHz USB - Spanish
  • 5000 kHz USB - Pescadores noted in January 2019, mixing with WWV, Spanish, Portuguese or Italian speaking
  • 4438 kHz - 6200 kHz - fixed mobile and broadcasting allocations, pescadores have been found on all these frequencies
  • 4000 kHz - 4438 kHz - heavily used, 4000-4063 kHz is fixed mobile shared with marine, 4063 kHz to 4438 kHz is a legit marine band
Updated January 2019
