11 meter
Revision as of 23:46, 23 January 2019 by R4002 (Talk | contribs)
27.430 MHz to 27.540 MHz 27410 kHz to 27540 kHz Business/Industrial Radio Service (20 kHz steps, FM mode)
27.540 MHz to 28.000 MHz 27540 kHz to 28000 kHz Government and Fixed/Mobile
11 meter is often used by freebanders or CB operators using the "freeband" frequencies from between 25 MHz and CB channel 1 (26.965 MHz) and CB channel 40 (27.405 MHz) and the bottom edge of the 10 meter amateur band (28.000 MHz). Common freeband frequencies include:
  • 25.615 MHz - 26.055 MHz - Band A - often used by taxi cabs and trucking companies (AM mode in the Americas, AM or FM elsewhere)
  • 26.065 MHz - 26.505 MHz - Band B - often used by taxi cabs, trucking companies and hunting clubs
  • 26.515 MHz - 26.955 MHz - Band C - "low band" or "lowers" all sorts of users, AM in the Americas, mixture of AM and FM elsewhere
  • 26.565 MHz - 26.955 MHz - German CB channels 41-80, FM mode only, heavily used in Europe
  • 26.965 MHz - 27.405 MHz - Band D - legal CB band - "mid band", "FCC band" or "CEPT" band
  • 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
  • 27.405 MHz - 27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
  • 27.60125 MHz - 27.99125 MHz - UK FM 27/81 CB (UK only) also CADS/WPAS Channels LW01-LW40 UK, Ireland (AM/FM modes, Church broadcasts) straight 10 kHz channel steps
  • 27.605 MHz - 27.995 MHz - CADS/WPAS Channels UW01-UW40 UK, Ireland and elsewhere straight 10 kHz channel steps
  • 27.635 MHz AM - CB channel 19 "up one band" - truckers are often heard here (see also 26.735 MHz)
  • 27.855 MHz - 28.305 MHz - Band F - up to 27.995 MHz (channel 11A) popular with taxicabs and truckers, although truckers are often heard above 28.000 MHz it is strongly advised that freebanders stay below 28 MHz
