This is a work in progress as part of the VHF/UHF radio subpages.
VHF low band VHF-low
VHF high band VHF band
- 155.7525 MHz - VCALL10 - Calling, simplex only (156.7 Hz CTCSS)
- 155.1600 MHz - NATSAR - Search and Rescue - simplex 127.3 Hz or 156.7 Hz (CSQ recommended)
- 155.3400 MHz - HEAR340/VMED28 - Ambulance to Hospital/Hospital to Hospital, medical interop
UHF band
800 MHz band
