Law enforcement, fire/EMS, medical and general public safety interoperability frequencies.  Most states, regions and even cities will have additional frequencies or dedicated talkgroups on their trunking systems.  Some areas include provisions to patch trunking systems to analog repeaters on the interop frequencies below.
VHF low band VHF-low
VHF high band VHF band
UHF band
800 MHz band
 - 40.5000 MHz - US Military FM Guard Channel - CSQ or 150.0 Hz military CTCSS tone
UHF band
Oil Spill Cleanup
- 36.2500 MHz - Oil spill cleanup/interop (simplex or repeater input/output, paired with 36.25 MHz)
 - 41.7100 MHz - Oil spill cleanup/interop (simplex or repeater input/output, paired with 41.71 MHz)
 - 150.9800 MHz - Oil spill cleanup interop (simplex or repeater input/output)
 - 154.5850 MHz - Oil spill cleanup interop (simplex or repeater input/output)
 - 454.0000 MHz - Oil spill cleanup interop (simplex or repeater output, paired with 459.0 MHz)
 - 459.0000 MHz - Oil spill cleanup interop (simplex or repeater input, paired with 454.0 MHz)
