Pescadores
Pescadores, Spanish and Portuguese for "fishermen" (also perscatori in Italian), is a term used to refer to voices on the pirate bands speaking non-English languages, often Spanish or Spanish-sounding. The original assumption was that these were fishermen from Mexico, the Caribbean, and points south, on boats in the Gulf of Mexico, talking to each other or to bases on land, but this has never been proven. Normally these stations are a random annoyance to pirates and pirate DXers, but occasionally they seem to be making an effort to interfere with pirate broadcasts. Vice versa, pirate stations will sometimes attempt to interfere with the pescadores' conversations.
One of the most common frequencies to hear "peskies" is 6925 kHz LSB, followed by 6900 kHz USB/LSB and many others. Peskies are known to use "cute" or "easy to remember" frequencies such as 6969.6 kHz, 6666 kHz, 6666.6 kHz, 6777.7 kHz, 6789 kHz, 6888 kHz, 15151.5 kHz, etc. Peskies don't follow rules relating to use of USB vs. LSB or frequency steps. As a result, it is not uncommon to hear peskies interfering with each other during good propagation. In the Eastern Hemisphere, peskies are Asian fishermen (and possibly also land based transmissions) found all over the 3-30 MHz range. There is some overlap between legal HF marine communications and pescadores, as fishing fleet communications are found in the 6200 kHz to 6525 kHz 6 MHz marine band as well as the higher frequencies (and lower frequencies!) above and below the MF/HF maritime bands.
Freebanders on HF
- 70 meters: 4000-4100 kHz
- 45 meters: 6400-6700 kHz - 6.6 MHz band or 45 metros
- 43 meters: 6765-7000 kHz
- 41 meters/39 meters: 7300 kHz + up into the 8195-8815 kHz marine band
- 22 meters: 13500-14000 kHz
- 14654.5 kHz USB - Spanish
- 10222.2 kHz USB - Spanish
- 10022.2 kHz USB - Spanish
- 10008.8 kHz USB - Spanish
- 9055.5 kHz USB - Spanish
- 8959 kHz USB - Spanish
- 6980 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6970 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6966 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6925 kHz LSB - Portuguese
- 6919 kHz LSB - Portuguese
- 6900 kHz USB - Spanish
- 6885 kHz USB - Spanish
- 6695.5 kHz USB and 6696.6 kHz USB - Spanish (similar to 6666.6 kHz)
- 6670 kHz USB - alternate to 6666.6 USB
- 6666.6 kHz USB - 45 metros calling frequency - home channel similar to 6900 LSB
- 6516 kHz USB - English language heard here, US based fishing trawlers (ITU HF marine channel 606)
- 6095 kHz USB - Fishing boats out of Gloucester, MA have been logged here - 49m broadcast band - (see also: 6212 kHz, 6953 kHz, 6959 kHz, etc)
- 5555.5 kHz USB - Spanish
- 5515 kHz USB - Spanish
- 5500 kHz USB - Spanish
- 5430 kHz USB - Spanish
Updated January 2019
