SINCGARS
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
It is important to note that in SC mode or single channel mode, SINCGARS radios allow for -5 kHz / +5 kHz or -10 kHz / +10 kHz offsets, effectively changing the 25 kHz frequency step to 5 kHz frequency step, allowing for use of non-standard frequencies in single-channel mode. In FH mode or frequency hopping mode channels are 25 kHz frequency steps. US government (and some older-generation military) land mobile systems use 10 kHz or 20 kHz channel steps in the above-listed bands as well. Use of standard land mobile CTCSS or PL tones have been reported (cf. the TVA's 40 MHz land mobile system uses 203.5 Hz PL and 250.3 Hz PL with 20 kHz channel spacing, even though the same band is used for military communications. The TVA channels naturally avoid use of 40.500 MHz - the VHF FM emergency channel.)
Background and History
