SINCGARS
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
Background and History
The SCR-300 and similar high-HF/low-VHF radios developed in WWII and the Korean War revolutionized small unit tactics. First the capability for a platoon or similar level unit to communicate with its headquarters or commanding elements and then the capability for each man in a squad for fireteam to communicate with each other in addition to the longer-range communications capability for platoon-to-commander and platoon-to-platoon communications using FM radio have changed the battlespace forever. The basic military backpack radio (and now handheld radio) concept has been copied endlessly, to the point where even militias and guerrilla forces use similar VHF/UHF radios for similar purposes. For example, see Ukraine militia forces using Baofengs (UV-5R, UV-82 and similar VHF/UHF handheld Chinese radios) and fighters in Afghanistan using Icom IC-V8s and other 2 meter / VHF handheld radios for battlefield tactical purposes, often in conjunction with 26-28 MHz CB type equipment or other similar radios/bands.
Communist Bloc countries, including the Soviet Union (and former Soviet Union, now Russia), Poland, as well as Western and Central European military forces also use similar frequency ranges (for example, 26 MHz - 70 MHz is/was a popular frequency split for tactical radios, instead of 30-76 MHz). Various handheld and manpack radios covering these bands have been manufactured and used in various countries. Captured radios from Iraq in the first and second Gulf Wars (Iraq War) indicate the 30-76 MHz (in 25 kHz steps, FM mode) band was used heavily by the Iraqi Army for tactical communications. As discussed in previous paragraphs, there is a move to COTS equipment, including non-standard radios such as amateur radios, VHF marine band radios, CB/11 meter radios and other land mobile radios in the VHF/UHF band for tactical purposes. Unfortunately, VHF low and VHF mid band does not work well in heavily built up areas (i.e. urban warfare radios). High band VHF and UHF work considerably better in these environments. It is because of this that the modern PRC-148 and PRC-152 radios cover 30-512 MHz instead of just 30-76 MHz or 30-88 MHz.
