High Frequency Beacon
Revision as of 13:49, 20 June 2019 by R4002 (Talk | contribs)
High Frequency Beacon is a colloquial term for an unlicensed radio beacon that does not follow government regulations for operation (such as Part 15), and is technically illegal. Unlicensed HF beacons which operate legally, according to rules for low power transmissions are classified as HiFERs. See also: data link networks and RC systems in the 26-28 MHz region that operate as de facto beacons.
Description
PRV (6852 kHz) under test
1654.95 PRV Preveza, Greece Op: SW6HMU, QSL via [email protected] (Source: ndblist). April 15, 2012
2097 A Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 10 second repetition, 24/7 [2] September 14, 2018
3450 OK OK (Source: HF Underground Forum [3]) (Youtube video) January 5, 2012
3810 SV1TEST Athens, Greece
(KM18VB)
4079.7 TMPnnn SW Arizona The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [4] March 4, 2012
4096 ......_ VA 6 dots 1 dash March 24, 2012
4096.1 Dasher Joshua Tree N.P. 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 March 24, 2012
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [5] [6] April 6, 2013
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [7] March 24, 2012
4097.2 Dasher Inyo County, CA
near DVNP
4102.8 W... southeast California desert Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 September 12, 2018
5484 SD San Diego, CA
5499.13 Dasher WA
6547.0 PRV Preveza, Greece Op: SW6HMU, QSL via [email protected] (Source: UDXF). Also reported on 6852.1 January 22, 2012
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST Athens, Greece
(KM18VB)
X9Q S.E. Europe or
Middle East
6816 FU N. America Active June 2011, no further info. (Source: A*C*E [8], [9]) (MP3 audio recording) January 20, 2012
HA N. America Active July 2011, no further info. (Source: A*C*E [10], HF Underground Forum [11]) .
July 9, 2011
6852.1 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via [email protected] Former website [12] closed. Reported also on 6547.0 and 1654.95 kHz April 24, 2012
6900 Beeper 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [13]) October 12, 2011
6947.1 13 dits and 1 dah No further info (Source: HF Underground Forum [14]) October 24, 2011
6961 TR Mojave desert, CA (Source: HF Underground Forum [15]) October 23, 2011
6994.8 - Norfolk, UK
(JO02)
2011
7542 55555 W Europe or NE USA (Source: [16], N&O-173(5), UDXF) March 1, 2012
8193.7 Ditter Western USA 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) August 26, 2018
8193.8 (Source: HF Underground Forum [17]) October 23, 2011
8211.7 OR
8350 Dasher North Carolina (Source: HF Underground Forum [18]) December 31, 2011
10236.7 Dasher FL
11428 CZ  ? (Source: HF Underground Forum [19]) January 3, 2012
26510 Common and Precious 3 Berlin, Germany Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) Jule 19, 2017
26598 Dasher SW US ~1/2 second dash every 29-31 seconds. 24/7.
26995 FSK Various locations in Canada FSK data link networks in Canada (generally 4 watt TX power)
27125 AOH California 16mW QRP beacon CW ID "AOH"
27141.6 14RS000 France 200 mW power 27.141.6 MHz CW ID 14RS000 + long tone burst 27.140 MHz USB
27175 153SD101 Thailand CW ID 153SD101
27255 FSK Various locations in USA FSK data link networks throughout US (generally 10 watt TX power)
27405 1 dot/minute Germany 1 watt power 1 pip per minute
27499.6 50KS00 Moscow, Russia 2 watt power CW ID 50KS00
27501 2KP Kansas 25 watt power CW ID 2KP
27550 69BY Costa Rica CW ID 69BY [also on 27500 and 27610]
27610 69BY Costa Rica CW ID 69BY [also on 27500 and 27550]
Telemetry Pirate Beacon
Windy Beacon
