High Frequency Beacon
High Frequency Beacon is a colloquial term for an unlicensed radio beacon that does not follow government regulations for operation (such as Part 15), and is technically illegal. Unlicensed HF beacons which operate legally, according to rules for low power transmissions are classified as HiFERs. See also: data link networks and RC systems in the 26-28 MHz region that operate as de facto beacons.
Description
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 10 second repetition, 24/7 [2] | September 14, 2018 |
| 3450 | OK | OK | (Source: HF Underground Forum [3]) (Youtube video) | January 5, 2012 |
| 4079.7 | TMPnnn | SW Arizona | The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [4] | March 4, 2012 |
| | WV | | ||
| 4096 | ......_ | VA | 6 dots 1 dash | March 24, 2012 |
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [5] [6] | April 6, 2013 |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [7] | March 24, 2012 |
| 4102.8 | W... | southeast California desert | Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 | September 12, 2018 |
| 5499.13 | Dasher | WA | ||
| 6547.0 | PRV | Preveza, Greece | Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: UDXF). Also reported on 6852.1 | January 22, 2012 |
| 6816 | FU | N. America | Active June 2011, no further info. (Source: A*C*E [8], [9]) (MP3 audio recording) | January 20, 2012 |
| HA | N. America | Active July 2011, no further info. (Source: A*C*E [10], HF Underground Forum [11]) . Sometimes the frequency is reported as "6815 kHz USB". (MP3 audio recording) | July 9, 2011 | |
| 6852.1 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via sw6hmu@yahoo.gr Former website [12] closed. Reported also on 6547.0 and 1654.95 kHz | April 24, 2012 |
| 6900 | Beeper | 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [13]) | October 12, 2011 | |
| 6947.1 | 13 dits and 1 dah | No further info (Source: HF Underground Forum [14]) | October 24, 2011 | |
| 6961 | TR | Mojave desert, CA | (Source: HF Underground Forum [15]) | October 23, 2011 |
| 7542 | 55555 | W Europe or NE USA | (Source: [16], N&O-173(5), UDXF) | March 1, 2012 |
| 8193.7 | Ditter | Western USA | 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
| 8193.8 | (Source: HF Underground Forum [17]) | October 23, 2011 | ||
| 8211.7 | OR | |||
| 8350 | Dasher | North Carolina | (Source: HF Underground Forum [18]) | December 31, 2011 |
| 10236.7 | Dasher | FL | ||
| 11428 | CZ | ? | (Source: HF Underground Forum [19]) | January 3, 2012 |
| 26510 | Common and Precious 3 | Berlin, Germany | Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 26598 | Dasher | SW US | ~1/2 second dash every 29-31 seconds. 24/7. | |
| 26995 | FSK | Various locations in Canada | FSK data link networks in Canada (generally 4 watt TX power) | |
| 27125 | AOH | California | 16mW QRP beacon CW ID "AOH" | |
| 27141.6 | 14RS000 | France | 200 mW power 27.141.6 MHz CW ID 14RS000 + long tone burst 27.140 MHz USB | |
| 27175 | 153SD101 | Thailand | CW ID 153SD101 | |
| 27255 | FSK | Various locations in USA | FSK data link networks throughout US (generally 10 watt TX power) | |
| 27255 | CW | Switzerland | 10w power CW ID : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN | |
| 27405 | 1 dot/minute | Germany | 1 watt power 1 pip per minute | |
| 27499.6 | 50KS00 | Moscow, Russia | 2 watt power CW ID 50KS00 | |
| 27501 | 2KP | Kansas | 25 watt power CW ID 2KP | |
| 27550 | 69BY | Costa Rica | CW ID 69BY [also on 27500 and 27610] | |
| 27610 | 69BY | Costa Rica | CW ID 69BY [also on 27500 and 27550] |
Telemetry Pirate Beacon
Windy Beacon
- HiFER
