SINCGARS
Revision as of 13:14, 24 March 2020 by R4002 (Talk | contribs)
Two handheld VHF-FM tactical radios Datron HH7700 30-88 MHz (30.000 MHz to 87.975 MHz) in 25 kHz steps, with no frequency hopping capability, the radio below is a vehicle-mounted VHF-FM military tactical radio
Most radios include repeater capability (called RETRANS or retransmit in military usage). Compatible with previous-generation FM radios such as the PRC-25, PRC-77, PRC-1077, HH7700 and dozens of other similar tactical handheld, manpack and vehicle-mounted radios operating in the 30-76 MHz (30.00 to 75.95 MHz in the original PRC-25/PRC-77 and VRC-12 channeling) or 30-88 MHz range. NATO military forces and many other military forces use similar frequencies for tactical purposes, almost always with FM voice. The US military fields radios that operate in the 30-174 MHz and 30-512 MHz ranges to support SINCGARS, regular VHF-FM, 136-174 MHz VHF-high band services like VHF marine, aircraft radios, SATCOM and interoperability with other radio systems that use VHF/UHF.
The 46.6 MHz - 47.0 MHz and 49.6 MHz - 50.0 MHz bands are shared with low power devices such as cordless phones, low power walkie-talkies and R/C devices. The 46.600 MHz, 46.625 MHz, 46.650 MHz, 46.675 MHz, 46.700 MHz, 46.725 MHz, 46.750 MHz, 46.775 MHz, 46.800 MHz, 46.825 MHz, 46.850 MHz, 46.875 MHz, 46.900 MHz, 46.925 MHz, 46.950 MHz, 46.975 MHz, 47.000 MHz, 49.825 MHz, 49.850 MHz, 49.875 MHz and 49.900 MHz channels overlap with the SINCGARS (or VHF FM aka FM) tactical frequency plan.
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
It should be noted that military operations in single channel mode are found on any frequency between 30.000 and 87.975 MHz outside the government/military exclusive use bands on a non-interference basis. Use of the 150.0 Hz CTCSS or PL tone squelch allows for frequency sharing with other users. This, combined with the fact that civilian allocations in the 30-50 MHz band use 20 kHz channel steps, compared to the 25 kHz channeling used by military VHF-FM or SINCGARS systems. The 150 Hz tone squelch is close enough to the civilian 151.4 Hz CTCSS tone that many scanners or communications receivers will decode military VHF FM traffic as having 151.4 Hz CTCSS when in reality they are transmitting 150 Hz. Use of 150 Hz also permits the operation of "relay" (repeater) setups using two radios, the appropriate cables and filters and a high elevation location. Relay functionality has been included in FM tactical radios since the SCR-300 (BC-1000) series. It was not, however, heavily used until the Vietnam war. Most single channel battlefield relay sites use RC-292 (20-70 MHz) or similar high performance antennas. FH retrans sites use the more modern OE-294 broadband antenna system. The wide frequency range of modern FM radios allows for maximum flexibility in choosing frequency pairs.
Background and History
Evolution of military FM radio tactical radio bands
27.200 MHz to 33.300 MHz German Armor Tank Radio Panzer Radio Band - sometimes listed as 27.0 MHz - 33.4 MHz or 27.2 MHz - 33.4 MHz 50 kHz channels - AM voice
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.000 MHz - 47.8 MHz) 50 kHz channels - AM voice, close air support and tank command nets
32.000 MHz to 38.000 MHz German Infantry Band (portable radios) 50 kHz channels - Feldfu d and KL.Fuspr.d manpack portable infantry radios
60.000 MHz to 80.000 MHz TBS Series "Talk Between Ships" - Ship-to-Ship voice radio 60-80 MC radio - US Navy Crystal controlled 20 kHz steps - TBS crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only)
40.000 MHz to 48.000 MHz American Infantry Band (partial) 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
