SINCGARS
Revision as of 14:02, 27 May 2020 by R4002 (Talk | contribs)
Single channel mode, also known as fixed frequency, is referred to as VULOS, or VHF UHF Line Of Sight. It is a catch-all term for VHF-FM 30-88 MHz, VHF-AM 108-150 MHz, VHF-FM 136-174 MHz, UHF-AM 225-399.975 MHz and UHF-FM 400-512 MHz fixed frequency clear (plaintext, or PT) or encrypted (ciphertext, or CT) simplex communications nets. Duplex or half-duplex repeaters (relay, retrans) or retransmission facilities may be used for VULOS nets. Frequencies in the 30.000 to 87.975 MHz range may be used for these nets in conjunction with SINCGARS, UHF SATCOM and UHF aircraft HAVE QUICK nets. PRC-148, PRC-152 and similar radios make reference to the VULOS radio net type. See also: PRC-150 HF/VHF radio (1.5-30 MHz SSB and various digital modes, 30-60 MHz [59.999 MHz] FM only. FM radios often have a "deviation" (bandwidth) setting. SINCGARS and fixed channel mode is generally set to 8 kHz deviation (36 kHz bandwidth) at 25 kHz steps. Land mobile settings include 5 kHz deviation (20 kHz bandwidth) and 2.5 kHz deviation (10 kHz bandwidth, regular narrow FM).
For example:
  • Relay Operation:
  • Repeater Operation:
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
It should be noted that military operations in single channel mode are found on any frequency between 30.000 and 87.975 MHz outside the government/military exclusive use bands on a non-interference basis. Use of the 150.0 Hz CTCSS or PL tone squelch allows for frequency sharing with other users. This, combined with the fact that civilian allocations in the 30-50 MHz band use 20 kHz channel steps, compared to the 25 kHz channeling used by military VHF-FM or SINCGARS systems. The 150 Hz tone squelch is close enough to the civilian 151.4 Hz CTCSS tone that many scanners or communications receivers will decode military VHF FM traffic as having 151.4 Hz CTCSS when in reality they are transmitting 150 Hz. Use of 150 Hz also permits the operation of "relay" (repeater) setups using two radios, the appropriate cables and filters and a high elevation location. Relay functionality has been included in FM tactical radios since the SCR-300 (BC-1000) series. It was not, however, heavily used until the Vietnam war. Most single channel battlefield relay sites use RC-292 (20-70 MHz) or similar high performance antennas. FH retrans sites use the more modern OE-294 broadband antenna system. The wide frequency range of modern FM radios allows for maximum flexibility in choosing frequency pairs.
Tennessee Valley Authority 40 MHz VHF low band system
TVA operates a 40 MHz FM system, in addition to a VHF high band system (analog FM voice and Project 25 P25 APCO-25 digital voice) and a UHF-low (406-420 MHz) Project 25 digital trunking system. The 40 MHz VHF low system is used for Transmission and Customer Service (TCS) purposes. With the adoption of the VHF high band and UHF trunking systems the low band system will not be dismantled.
  • 40.610 MHz - 250.3 Hz CTCSS TVA TCS CH-01
  • 40.430 MHz - 250.3 Hz CTCSS TVA TCS CH-02
  • 40.530 MHz - 250.3 Hz CTCSS TVA TCS CH-03
  • 40.570 MHz - 250.3 Hz CTCSS TVA TCS CH-04
  • 40.310 MHz - 250.3 Hz CTCSS TVA TCS CH-05
  • 40.650 MHz - 250.3 Hz CTCSS TVA TCS CH-06
  • 40.370 MHz - 250.3 Hz CTCSS TVA TCS CH-07
  • 40.770 MHz - 250.3 Hz CTCSS TVA TCS CH-08
  • 40.370 MHz - 203.5 Hz CTCSS TVA TCS CH-09
  • 40.430 MHz - 203.5 Hz CTCSS TVA TCS CH-10
  • 40.730 MHz - 250.3 Hz CTCSS TVA TCS CH-11
  • 40.690 MHz - 250.3 Hz CTCSS TVA TCS CH-12
  • 40.830 MHz - 250.3 Hz CTCSS TVA TCS CH-13
  • 40.610 MHz - 203.5 Hz CTCSS TVA TCS CH-14
  • 40.730 MHz - 203.5 Hz CTCSS TVA TCS CH-15
  • 40.490 MHz - 250.3 Hz CTCSS TVA TCS CH-16
  • 40.870 MHz - 250.3 Hz CTCSS TVA TCS CH-17
Background and History
60.000 MHz to 80.000 MHz TBS Series "Talk Between Ships" - Ship-to-Ship voice radio 60-80 MC radio - US Navy Crystal controlled 20 kHz steps - TBS crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) 100 kHz (channels 380-549), PRC-10, PRC-10A
40.000 MHz to 48.000 MHz American Infantry Band - portable tactical radios - WWII vintage 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) 50 kHz channels - AM voice, close air support and tank command nets
