Law enforcement, fire/EMS, medical and general public safety interoperability frequencies.  Most states, regions and even cities will have additional frequencies or dedicated talkgroups on their trunking systems.  Some areas include provisions to patch trunking systems to analog repeaters on the interop frequencies below.
| Contents |
VHF low band VHF-low
Since the input and output frequencies are reversed for LLAW1/LLAW3 and for LFIRE2/LFIRE4, only one set repeaters should operate in a given geographical area. If all four frequencies are used for simplex purposes, then all four frequencies 39.46 MHz, 39.48 MHz, 45.86 MHz and 45.88 MHz may be used in the same geographical area. 39.460 MHz and 45.880 MHz are considerably more likely to be used nationwide. Many states will use these frequencies in conjunction with their own statewide interoperability frequency (for states that still maintain and use lowband radio systems). The lowband frequencies should be programmed with regular 20K0F3E or 16K0F3E emission (regular 20 kHz / 25 kHz bandwidth FM), not narrow band FM (11K3F3E, 11K2F3E, 11K0F3E, etc.).
VHF high band VHF band
- 155.3700 MHz - INTERCITY Law Enforcement Point-to-Point Interop (only used in some areas)
UHF band
Many metro areas that operate large UHF (450-470 MHz) and UHF-T (470-512 MHz) public safety systems have infrastructure in place for the UCALL/UTAC interoperability channels. Many, including Los Angeles, Boston, New York and Chicago, have their own regional/metro UHF interoperability systems as well - eg. BAPERN in Boston, NYMAC in New York City, etc.
700 MHz / 800 MHz band
- In areas where the 700 MHz/800 MHz bands are used, these are the most commonly used interoperability frequencies. The 800 MHz frequencies are assigned for analog only (simplex/talkaround or repeated). In some areas, these channels may be linked together and/or linked to interoperability frequencies on other bands or patched to talkgroups on local/regional trunking systems.
- 700 MHz Nationwide Interoperability Channels:
- 800 MHz Nationwide Interoperability Channels:
- 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 807.5125 MHz) both with 156.7 Hz CTCSS
- 47.8000 MHz - Military NATO Combat Scene of Action Common
UHF band
Oil Spill Cleanup
