Militia Radio Frequencies
Militia portable handheld tactical radios - VHF/UHF dualbanders such as the Baofeng series UV-5R, UV-82, VHF/UHF mobile radios, single-band mobile radios, etc.
Transmit CTCSS tones are recommended, but not required. Receive must be set for carrier squelch (no receive CTCSS or PL tone).
- Channel 001 - MURS 1 - 151.8200 MHz - Tone: 88.5Hz Mode: NFM - display channel name: MURS 1
- Channel 002 - MURS 2 - 151.8800 MHz - Tone: 88.5Hz Mode: NFM - display channel name: MURS 2
- Channel 003 - MURS 3 - 151.9400 MHz - Tone: 88.5Hz Mode: NFM - display channel name: MURS 3
- Channel 004 - MURS 4 - 154.5700 MHz - Tone: 88.5Hz Mode: FM - display channel name: MURS 4
- Channel 005 - MURS 5 - 154.6000 MHz - Tone: 88.5Hz Mode: FM - display channel name: MURS 5
- Channel 011 - FRS 1 - 462.5625 MHz Mode: NFM - Tone 67.0 Hz - display channel name: FRS 1
- Channel 012 - FRS 2 - 462.5875 MHz Mode: NFM - Tone 67.0 Hz - display channel name: FRS 2
- Channel 013 - FRS 3 - 462.6125 MHz Mode: NFM - Tone 127.3 Hz - display channel name: FRS 3
- Channel 014 - FRS 4 - 462.6375 MHz Mode: NFM - Tone 77.0 Hz - display channel name: FRS 4
- Channel 015 - FRS 5 - 462.6625 MHz Mode: NFM - Tone 136.5 Hz - display channel name: FRS 5
- Channel 016 - FRS 6 - 462.6875 MHz Mode: NFM - Tone 141.3 Hz - display channel name: FRS 6
- Channel 017 - FRS 7 - 462.7125 MHz Mode: NFM - Tone 146.2 Hz - display channel name: FRS 7
- Channel 018 - FRS 8 - 467.5625 MHz Mode: NFM - Tone 88.5 Hz - display channel name: FRS 8
- Channel 019 - FRS 9 - 467.5875 MHz Mode: NFM - Tone 97.4 Hz - display channel name: FRS 9
- Channel 010 - FRS 10 - 467.6125 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 10
- Channel 011 - FRS 11 - 467.6375 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 11
- Channel 012 - FRS 12 - 467.6625 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 12
- Channel 013 - FRS 13 - 467.6875 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 13
- Channel 014 - FRS 14 - 467.7125 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 14
- Channel 015 - FRS 15 - 462.5500 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 15
- Channel 016 - FRS 16 - 462.5750 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 16
- Channel 017 - FRS 17 - 462.6000 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 17
- Channel 018 - FRS 18 - 462.6250 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 18
- Channel 019 - FRS 19 - 462.6500 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 19
- Channel 020 - FRS 20 - 462.6750 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 20
- Channel 021 - FRS 21 - 462.7000 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 21
- Channel 022 - FRS 22 - 462.7250 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 22
- 151.9400 MHz - Militia/Patriot VHF Primary/Calling MURS 3 - AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
- 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
- 154.6000 MHz - Militia/Patriot VHF MURS 5
- 467.5625 MHz - Militia/Patriot UHF FRS 8 - Tactical
- 467.5875 MHz - Militia/Patriot UHF FRS 9
- 467.6125 MHz - Militia/Patriot UHF FRS 10
- 467.6375 MHz - Militia/Patriot UHF FRS 11
- 467.6625 MHz - Militia/Patriot UHF FRS 12
- 467.6875 MHz - Militia/Patriot UHF FRS 13
- 467.7125 MHz - Militia/Patriot UHF FRS 14
- 462.5500 MHz - Militia/Patriot UHF FRS 15 - Tactical
- 462.5750 MHz - Militia/Patriot UHF FRS 16 - Patriot Tactical, Vehicle Coordination
- 462.6000 MHz - Militia/Patriot UHF FRS 17 - Tactical
- 467.5875 MHz - FRS9 - Militia/Patriot UHF FRS Channel 9
- 467.6125 MHz - FRS10 - Militia/Patriot UHF FRS Channel 10
- 467.6375 MHz - FRS11 - Militia/Patriot UHF FRS Channel 11
- 467.6625 MHz - FRS12 - Militia/Patriot UHF FRS Channel 12
- 467.6875 MHz - FRS13 - Militia/Patriot UHF FRS Channel 13
- 467.7125 MHz - FRS14 - Militia/Patriot UHF FRS Channel 14
- 151.880 MHz - MURS 2
- 154.570 MHz - MURS 4
- 154.600 MHz - MURS 5
- 151.655 MHz - VHF Business
- 151.685 MHz - VHF Business
- 151.715 MHz - VHF Business
- 151.745 MHz - VHF Business
- 151.775 MHz - VHF Business
- 151.805 MHz - VHF Business
- 151.835 MHz - VHF Business
- 151.865 MHz - VHF Business
- 151.895 MHz - VHF Business
- 151.925 MHz - VHF Business
- 151.955 MHz - VHF Business
- 152.870 MHz - VHF Business
- 152.885 MHz - VHF Business
- 152.900 MHz - VHF Business
- 152.915 MHz - VHF Business
- 152.930 MHz - VHF Business
- 152.945 MHz - VHF Business
- 152.960 MHz - VHF Business
- 152.975 MHz - VHF Business
- 152.990 MHz - VHF Business
- 153.005 MHz - VHF Business
- 154.4825 MHz - VHF Business
- 154.490 MHz - VHF Business
- 154.4975 MHz - VHF Business
- 154.505 MHz - VHF Business
- 154.515 MHz - VHF Business
- 154.5275 MHz - VHF Business Itinerant
- 154.540 MHz - VHF Business
- 154.5475 MHz - VHF Business
- 154.555 MHz - VHF Business
- 154.625 MHz - VHF Business
- 154.655 MHz - VHF Business
- 158.4075 MHz - VHF Business Itinerant
