Militia Radio Frequencies
Revision as of 13:51, 21 August 2020 by R4002 (Talk | contribs)
Militia portable handheld tactical radios - VHF/UHF dualbanders such as the Baofeng series UV-5R, UV-82, VHF/UHF mobile radios, single-band mobile radios, etc.
Transmit CTCSS tones are recommended, but not required. Receive must be set for carrier squelch (no receive CTCSS or PL tone). Users may simply turn all tones off (no transmit tone or receive tone) if they prefer. Transmit tones are recommended to facilitate interoperability with commonly used tones and default radio channel/tone settings. For example, the Baofeng BF-888S [[series radios use 127.3 Hz CTCSS on 462.625 MHz (BF-888S channel 6, FRS channel 18) and 136.5 Hz CTCSS on 462.725 MHz (BF-888S channel 7, FRS channel 22). The Retevis FRS handheld radios use the CTCSS tones indicated for FRS channels 1-7, 15, 18 and 22. For more information on default factory out of the box Baofeng Retevis etc. CTCSS tone settings and frequencies/channel plans, see this page.
  • Channel 001 - MURS 1 - 151.8200 MHz - Mode: NFM Tone: 88.5Hz Mode: NFM - display channel name: MURS 1
  • Channel 002 - MURS 2 - 151.8800 MHz - Mode: NFM Tone: 88.5Hz Mode: NFM - display channel name: MURS 2
  • Channel 003 - MURS 3 - 151.9400 MHz - Mode: NFM Tone: 88.5Hz Mode: NFM - display channel name: MURS 3
  • Channel 004 - MURS 4 - 154.5700 MHz - Mode: FM Tone: 88.5Hz Mode: FM - display channel name: MURS 4
  • Channel 005 - MURS 5 - 154.6000 MHz - Mode: FM Tone: 88.5Hz Mode: FM - display channel name: MURS 5
  • Channel 011 - FRS 1 - 462.5625 MHz Mode: NFM - Tone 67.0 Hz - display channel name: FRS 1
  • Channel 012 - FRS 2 - 462.5875 MHz Mode: NFM - Tone 67.0 Hz - display channel name: FRS 2
  • Channel 013 - FRS 3 - 462.6125 MHz Mode: NFM - Tone 127.3 Hz - display channel name: FRS 3
  • Channel 014 - FRS 4 - 462.6375 MHz Mode: NFM - Tone 77.0 Hz - display channel name: FRS 4
  • Channel 015 - FRS 5 - 462.6625 MHz Mode: NFM - Tone 136.5 Hz - display channel name: FRS 5
  • Channel 016 - FRS 6 - 462.6875 MHz Mode: NFM - Tone 141.3 Hz - display channel name: FRS 6
  • Channel 017 - FRS 7 - 462.7125 MHz Mode: NFM - Tone 146.2 Hz - display channel name: FRS 7
  • Channel 018 - FRS 8 - 467.5625 MHz Mode: NFM - Tone 88.5 Hz - display channel name: FRS 8
  • Channel 019 - FRS 9 - 467.5875 MHz Mode: NFM - Tone 97.4 Hz - display channel name: FRS 9
  • Channel 010 - FRS 10 - 467.6125 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 10
  • Channel 011 - FRS 11 - 467.6375 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 11
  • Channel 012 - FRS 12 - 467.6625 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 12
  • Channel 013 - FRS 13 - 467.6875 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 13
  • Channel 014 - FRS 14 - 467.7125 MHz Mode: NFM - Tone - 67.0 Hz - display channel name: FRS 14
  • Channel 015 - FRS 15 - 462.5500 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 15
  • Channel 016 - FRS 16 - 462.5750 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 16
  • Channel 017 - FRS 17 - 462.6000 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 17
  • Channel 018 - FRS 18 - 462.6250 MHz Mode: NFM - Tone - 127.3 Hz - display channel name: FRS 18
  • Channel 019 - FRS 19 - 462.6500 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 19
  • Channel 020 - FRS 20 - 462.6750 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 20
  • Channel 021 - FRS 21 - 462.7000 MHz Mode: NFM - Tone - 141.3 Hz - display channel name: FRS 21
  • Channel 022 - FRS 22 - 462.7250 MHz Mode: NFM - Tone - 136.5 Hz - display channel name: FRS 22
  • 151.9400 MHz - Militia/Patriot VHF Primary/Calling MURS 3 - AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
  • 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
  • 154.6000 MHz - Militia/Patriot VHF MURS 5
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business
  • 154.505 MHz - VHF Business
  • 154.515 MHz - VHF Business
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business
  • 154.625 MHz - VHF Business
  • 154.655 MHz - VHF Business
