Contents[hide] |
By far the most active ranges are 43 meters (6765-7000 kHz), 49 meters (6100-6400 kHz) and 70 meters (4000-4100 kHz), with some activity in the 60 meter band (4700-5300 kHz) as well.
Last updated: August 2020
1610-1700 kHz | AM - Mediumwave pirates (see also 1710 kHz and 1720 kHz) |
1710 kHz | AM - Mediumwave pirates |
1720 kHz | AM - Mediumwave pirates - known as the "AM pirate clear channel" |
3375 kHz | AM/USB - used by Amphetamine Radio |
3390 kHz | AM/USB - used by Old Time Radio in February 2019 and March 2019 |
3425 kHz | AM - used by The Crystal Ship (also reported on 3430) |
3440 kHz | AM/USB - reported use in 2018 |
3465 kHz | AM - reported use in 2017 |
4015 kHz | AM/USB |
4020 kHz | AM/USB |
4025 kHz | AM/USB |
4060 kHz | AM/USB |
4065 kHz | AM/USB |
4080 kHz | AM/USB |
4085 kHz | AM/USB - used by X-FM in late 2018 |
4140 kHz | AM/USB - used by Mix Radio International |
4145 kHz | AM/USB - used by Mix Radio International |
5010 kHz | AM - used by Relay Station |
5015 kHz | AM - used by Relay Station |
5100 kHz | AM - reported in use June 2019 |
5150 kHz | AM - used by Relay Station |
5200 kHz | AM - used by Relay Station |
6150 kHz | AM - used by European Pirates |
6220 kHz | Used by Mystery Radio in Europe and other European Pirates (see 49 meters below) |
6750 kHz | AM/SSB - reported in use August 2017 |
6770 kHz | AM - used by Old Time Radio or OTR, considered to be OTR's "home channel" |
6780 kHz | AM/USB - including nearby frequencies 6777 kHz, 6777.7 kHz, 6778 kHz and 6779 kHz |
6790 kHz | AM/USB - including nearby frequency 6789 kHz |
6805 kHz | AM/SSB (repored use by UNID Europirates) |
6815 kHz | AM (repored use by UNID Europirates) |
6840 kHz | AM |
6850 kHz | usually AM |
6855 kHz | usually AM |
6868 kHz | AM/USB - noted use by Mix Radio International (May 2019) |
6870 kHz | AM/USB |
6875 kHz | usually AM - noted use by The Crystal Ship (often 6876 kHz or similar close frequencies) |
6880 kHz | usually AM - used by Relay Station (noted use in late 2018) |
6885 kHz | AM/USB |
6886 kHz | AM/USB |
6888 kHz | usually AM - noted use by Unknown Name Radio Network |
6890 kHz | AM/USB |
6900 kHz | usually AM, although 6900 LSB and 6900 USB are both heavily used by Spanish-speaking "peskies" |
6905 kHz | AM - noted use by Unknown Name Radio Network, another commonly use pescadore frequency in LSB mode |
6910 kHz | AM/USB - Used by Seven Trees Radio and Clever Name Radio |
6915 kHz | AM/USB |
6920 kHz | AM/USB |
6923 kHz | AM/USB - used by Amphetamine Radio, Fess Parker Radio, Yeah Man Radio and others |
6925 kHz | most common frequency - virtually all modes have been heard +/- 1-2 kHz Many pirate radio listeners park receivers on 6925 kHz. |
6927 kHz | AM - noted use by Yeti Radio in 2018 |
6930 kHz | AM/USB |
6935 kHz | AM/USB - Latin American pirates can also be heard here (i.e. AD149 on 6934.8 kHz or 6934.9 kHz AM) |
6940 kHz | AM/USB - noted use by Clever Name Radio |
6945 kHz | AM/USB |
6950 kHz | AM/USB |
6955 kHz | AM/USB |
6960 kHz | AM/USB - noted use by Radio Illuminati |
6965 kHz | AM/USB |
6969 kHz | LSB/USB - Used by Cold Country Canada and others |
6970 kHz | AM |
6973 kHz | AM - Latin American pirates can also be heard here, specifically Lupo Radio |
6975 kHz | AM/USB - often used by X-FM (also heard on 6970) |
6985 kHz | AM - Latin American pirates |
6995 kHz | AM/SSB - noted used by KUNT |
7415 kHz | historically, an extremely active frequency, more recently occupied by WBCQ |
7425 kHz | historically, an extremely active frequency prior to the movement down to 43 meters |
7465 kHz | AM - noted use by YHWH religious pirate |
7470 kHz | AM - noted use by YHWH religious pirate (June 2019) |
7480 kHz | AM - noted use by YHWH religious pirate (May 2019) |
13560 kHz | AM - Old Time Radio daytime frequency - logged June 2019 |
15070 kHz | active in the early 1990's by Europirates and pirates in North America, but recently quiet due to the solar cycle low |
Euro-Pirate Radio Frequencies
- 3900-3950 (75 meters)
- 9500-10200 kHz
- 7400-8100 kHz
- 6765-7000 kHz
- 5000-6300 kHz
- 8000 kHz - Radio Casa
- 6925.1 kHz - RCW Chile
- 6250 - Used in the 1980s
- Return to Pirate Radio New Listener Guide and FAQ
- Return to Where Can I Find Pirate Activity
- Go to Pirate radio stations
- Go to A Brief Survey of HF Receiving Equipment
