VHF LADD
While these frequencies were originally intended only for use by logging companies, oil exploration and drilling equipment delivery companies, remote base station dispatch (think 'Ice Road Truckers') and other specialized use, the proliferation of inexpensive VHF-FM equipment means their usage has become more widespread and these frequencies have become de facto "interoperability" frequencies in remote areas of Canada. The LADD channels in particular are used by natural resources officers to communicate with logging companies as well as for truck-to-truck, handheld radios for flaggers at loading sites and for other specialized purposes.
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth or 16K0F3E emission) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth - also known as 11K3F3E emission, 11K2F3E emission or 11K0F3E emission). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
| Channel | Frequency | Remarks/Usage | |
| LADD 1 | 154.1000 MHz | LADD channel 1 - trucking and logging companies, natural resource agencies | |
| LADD 2 | 158.9400 MHz | LADD channel 2 - trucking and logging companies, natural resource agencies | |
| LADD 3 | 154.3250 MHz | LADD channel 3 - trucking and logging companies, natural resource agencies | |
| LADD 4 | 173.3700 MHz | LADD channel 4 - trucking and logging companies, natural resource agencies | |
| LD-1 | 151.7000 MHz | Loading channel 1 | |
| LD-2 | 151.7450 MHz | Loading channel 2 | |
| LD-3 | 151.7900 MHz | Loading channel 3 | |
| LD-4 | 151.8050 MHz | Loading channel 4 | |
| LD-5 | 151.8500 MHz | Loading channel 5 | |
| RR-01 | 150.0800 MHz | Resource Road channel 1 | |
| RR-02 | 150.1100 MHz | Resource Road channel 2 | |
| RR-03 | 150.1400 MHz | Resource Road channel 3 | |
| RR-04 | 150.1850 MHz | Resource Road channel 4 | |
| RR-05 | 150.2000 MHz | Resource Road channel 5 | |
| RR-06 | 150.2450 MHz | Resource Road channel 6 | |
| RR-07 | 150.2600 MHz | Resource Road channel 7 | |
| RR-08 | 150.3200 MHz | Resource Road channel 8 | |
| RR-09 | 150.3650 MHz | Resource Road channel 9 | |
| RR-10 | 150.4100 MHz | Resource Road channel 10 | |
| RR-11 | 150.4400 MHz | Resource Road channel 11 | |
| RR-12 | 150.5000 MHz | Resource Road channel 12 | |
| RR-13 | 150.5300 MHz | Resource Road channel 13 | |
| RR-14 | 150.5450 MHz | Resource Road channel 14 | |
| RR-15 | 150.5600 MHz | Resource Road channel 15 | |
| RR-16 | 150.5900 MHz | Resource Road channel 16 | |
| RR-17 | 150.6800 MHz | Resource Road channel 17 | |
| RR-18 | 150.7100 MHz | Resource Road channel 18 | |
| RR-19 | 150.7700 MHz | Resource Road channel 19 | |
| RR-20 | 150.8300 MHz | Resource Road channel 20 | |
| RR-21 | 151.0100 MHz | Resource Road channel 21 | |
| RR-22 | 151.1300 MHz | Resource Road channel 22 | |
| RR-23 | 151.1900 MHz | Resource Road channel 23 | |
| RR-24 | 151.2200 MHz | Resource Road channel 24 | |
| RR-25 | 151.3100 MHz | Resource Road channel 25 | |
| RR-26 | 151.3400 MHz | Resource Road channel 26 | |
| RR-27 | 151.3700 MHz | Resource Road channel 27 | |
| RR-28 | 151.4300 MHz | Resource Road channel 28 | |
| RR-29 | 151.4600 MHz | Resource Road channel 29 | |
| RR-30 | 151.4900 MHz | Resource Road channel 30 | |
| RR-31 | 151.5200 MHz | Resource Road channel 31 | |
| RR-32 | 151.5800 MHz | Resource Road channel 32 | |
| RR-33 | 151.6100 MHz | Resource Road channel 33 | |
| RR-34 | 151.6400 MHz | Resource Road channel 34 | |
| RR-35 | 151.6400 MHz | Resource Road channel 34 | |
| MURS1 | 151.6400 MHz | Resource Road channel 34 | |
| MURS2 | 151.6400 MHz | Resource Road channel 34 | |
| MURS3 | 151.6400 MHz | Resource Road channel 34 | |
| MURS4 | 151.6400 MHz | Resource Road channel 34 | |
| MURS5 | 151.6700 MHz | Resource Road channel 35 |
LADD and Resource Road VHF radio system base stations can range from 50 watts to 300 watts and may be remotely operated via landline telephone or VoIP technology. Mobile radios with transmit power ranging from 25 watts to 110 watts are used, with 45 watt, 50 watt and 60 watt mobiles commonly found in trucks (for example, the Icom IC-2100, IC-2200H, IC-V8000, Kenwood 2 meter amateur radios, the Alinco DR-135 series, as well as open-band 136-174 MHz Chinese mobiles such as the TYT TH-9000D and similar radios). 1/4 wave NMO antennas are often used when space consideration and rugged heavy duty antennas are needed but 1/2 wave and 5/8 wave VHF antennas are also used for improved gain on the VHF frequencies. Portable radios are also used for flagmen, wide load safety and other purposes on these frequencies.
