Wi-Fi
Revision as of 13:59, 14 May 2021 by R4002 (Talk | contribs)
Wireless LAN / Wi-Fi WiFi frequency bands UHF and higher.
900 MHz (802.11ah)
802.11ah operates in sub-gigahertz unlicensed bands. Each world region supports different sub-bands, and the channels number depends on the starting frequency of the sub-band it belongs to. Thus, there is no global channels numbering plan, and the channels numbers are incompatible between world regions (and even between sub-bands of a same world region).
Region Subband
(MHz)
Bandwidths
(MHz)
Australia 915–920 1, 2, 4
920–928 1, 2, 4, 8
China 755–779 1
779–787 1, 2, 4, 8
Europe 863–868 1, 2
Japan 916.5–927.5 1
Korea 917.5–923.5 1, 2, 4
New
Zealand
915–924 1, 2, 4, 8
924–928 1, 2, 4
Singapore 866–869 1, 2
920–925 1, 2, 4
Taiwan 839–848.5 1, 2, 4
United
States<ref>Template:Cite web</ref>
902–904 1, 2
904–920 1, 2, 4, 8, 16
920–928 1, 2, 4, 8
2.4 GHz (802.11b/g/n/ax)
The 2.4 GHz band is extremely congested with numerous devices using this frequency band, including ISM devices, cordless telephones, Bluetooth, analog and digital wireless video link systems (video senders), baby monitors, wireless intercoms and dozens of other uses.
Channel F0 (MHz) Frequency
Range
(MHz)
North
America
<ref name=t18-9>IEEE 802.11-2007 — Table 18-9</ref>
<ref name=t18-9/>
Most of
world
<ref name="t18-9" /><ref>Template:Cite web</ref><ref>France: Template:Cite web</ref><ref>Template:Cite web</ref>
<ref name="israel" /><ref name="Australia-F2015L01438">Template:Cite web</ref><ref name="Brazil">Template:Cite web</ref><ref name="Switzerland">Template:Cite web</ref>
Template:01 2412 2401–2423 Template:Yes Template:Yes Template:Yes
Template:02 2417 2406–2428 Template:Yes Template:Yes Template:Yes
Template:03 2422 2411–2433 Template:Yes Template:Yes Template:Yes
Template:04 2427 2416–2438 Template:Yes Template:Yes Template:Yes
Template:05 2432 2421–2443 Template:Yes Template:Yes Template:Yes
Template:06 2437 2426–2448 Template:Yes Template:Yes Template:Yes
Template:07 2442 2431–2453 Template:Yes Template:Yes Template:Yes
Template:08 2447 2436–2458 Template:Yes Template:Yes Template:Yes
Template:09 2452 2441–2463 Template:Yes Template:Yes Template:Yes
10 2457 2446–2468 Template:Yes Template:Yes Template:Yes
11 2462 2451–2473 Template:Yes Template:Yes Template:Yes
12 2467 2456–2478 Template:NoTemplate:Ref except CAN Template:Yes Template:Yes
13 2472 2461–2483 Template:NoTemplate:Ref Template:Yes Template:Yes
14 2484 2473–2495 Template:No Template:YesTemplate:Ref Template:No
To guarantee no interference in any circumstances the Wi‑Fi protocol requires 16.25 to 22 MHz of channel separation (as shown below). The remaining 2 MHz gap is used as a guard band to allow sufficient attenuation along the edge of the band. This guardband is mainly used to accommodate older routers with modem chipsets prone to full channel occupancy, as most modern Wi‑Fi modems are not prone to excessive channel occupancy. In 22 MHz channel width situations, there is 3 MHz free/unused spectrum between NON-overlapping channels, this is not called guard band but channel spacing.
File:2.4 GHz Wi-Fi channels (802.11b,g WLAN).svg
Graphical representation of overlapping 20 MHz channels within the 2.4 GHz band
Template:Multiple image
However, the exact spacing required when the transmitters are not colocated depends on the protocol, the data rate selected, the distances and the electromagnetic environment where the equipment is used.<ref name="adjacentchannels"/>
The overall effect is that if there is considerable overlap between adjacent channels transmitters they will often interfere with each other. However, using every fourth or fifth channel by leaving three or four channels clear between used channels can cause less interference than sharing channels, and narrower spacing still can be used at further distances.<ref name="compnetworking.about.com">Template:Cite web</ref><ref name="adjacentchannels">Template:Cite conference</ref>
Template:-
3.65 GHz (802.11y)
This range is documented as only being allowed as a licensed band in the United States.
Designation Center
(MHz)
Span
5 MHz 10 MHz 20 MHz
131 3657.5 3655–3660
3660 3655–3665
132 3662.5 3660–3665
3665 3655–3675
133 3667.5 3665–3670
3670 3665–3675
134 3672.5 3670–3675
135 3677.5 3675–3680
3680 3675–3685
136 3682.5 3680–3685
3685 3675–3695
137 3687.5 3685–3690
3690 3685–3695
138 3692.5 3690–3695
Template:Anchor 5 GHz (802.11a/h/j/n/ac/ax)
Template:Anchor
Channel Center
Frequency
(MHz)
Frequency
Range
(MHz)
10
MHz
20
MHz
40
MHz
80
MHz
160
MHz
United
States
FCC
U-NII Band(s)
United
States
Canada
Europe
Russia
India
Template:Citation needed
Singa-
pore
Mainland China
Israel
Korea
Turkey
South Africa
Brazil
<ref name=Brazil/>
Taiwan
New
Zealand
Bahrain
Vietnam
Channel Center
Frequency
(MHz)
Frequency
Range
(MHz)
10
MHz
20
MHz
40
MHz
80
MHz
160
MHz
FCC
U-NII Band(s)
Notes: Template:Notefoot
Caption
Text Meaning
Notes: Template:Citation
Source:<ref>IEEE 802.11-2007 Annex J modified by amendments k, y and n.</ref>
In 2007, the FCC (United States) began requiring that devices operating in the bands of 5.250–5.350 GHz and 5.470–5.725 GHz must employ dynamic frequency selection (DFS) and transmit power control (TPC) capabilities. This is to avoid interference with weather-radar and military applications.<ref name="FCC2011">Template:Cite web</ref> In 2010, the FCC further clarified the use of channels in the 5.470–5.725 GHz band to avoid interference with TDWR, a type of weather radar system.<ref name="FCC.DFS.Interim">Template:Cite web</ref> In FCC parlance, these restrictions are now referred to collectively as the "Old Rules". On 10 June 2015, the FCC approved a "new" ruleset for 5 GHz device operation (called the "New Rules"), which adds 160 and 80 MHz channel identifiers, and re-enables previously prohibited DFS channels, in Publication Number 905462.<ref name="fcc-905462">Template:Cite web</ref> This FCC publication eliminates the ability for manufacturers to have devices approved or modified under the Old Rules in phases; the New Rules apply in all circumstances Template:As of.<ref name="fcc-905462" />
Source:<ref>FCC MODERNIZES 5.9 GHz BAND FOR WI-FI AND AUTO SAFETY New Plan Makes Additional Spectrum Available Immediately for Improved Indoor Wi-Fi Connectivity While Authorizing Market-Driven Transportation Safety Services</ref> "To help meet the increasing demand for Wi-Fi and other unlicensed services, the FCC’s new rules will make 45 megahertz of the 5.9 GHz band available for unlicensed use. This spectrum’s impact will be further amplified by the fact that it is adjacent to an existing Wi-Fi band which, when combined with the 45 megahertz made available today, will support cutting edge broadband applications. These high-throughput channels—up to 160 megahertz wide—will enable gigabit Wi-Fi connectivity for schools, hospitals, small businesses, and other consumers. The Report and Order adopts technical rules to enable full-power indoor unlicensed operations in the lower 45 megahertz portion of the band immediately, as well as opportunities for outdoor unlicensed use on a coordinated basis under certain circumstances. Under the new rules, ITS services will be required to vacate the lower 45 megahertz of the band within one year."
Germany requires DFS and TPC capabilities on 5.250–5.350 GHz and 5.470–5.725 GHz as well; in addition, the frequency range 5.150–5.350 GHz is allowed only for indoor use, leaving only 5.470–5.725 GHz for outdoor and indoor use.<ref name="Germany">Template:Cite web</ref>
Since this is the German implementation of EU Rule 2005/513/EC, similar regulations must be expected throughout the European Union.<ref name="eur-lex1">Template:Cite web</ref><ref name="eur-lex2">Template:Cite web</ref>
European standard EN 301 893 covers 5.15–5.725 GHz operation, and Template:As of v2.1.1 has been adopted.<ref>Template:Cite web</ref>
Austria
Austria adopted Decision 2005/513/EC directly into national law.<ref name="Austria">Template:Cite web</ref> The same restrictions as in Germany apply, only 5.470–5.725 GHz is allowed to be used outdoor and indoor.
South Africa
Source for South Africa: <ref name="South-Africa" />
Japan's use of 10 and 20 MHz-wide 5 GHz wireless channels is codified by Association of Radio Industries and Businesses (ARIB) document STD-T71, Broadband Mobile Access Communication System (CSMA).<ref>Template:Cite web</ref> Additional rule specifications relating to 40, 80, and 160 MHz channel allocation has been taken on by Japan's Ministry of Internal Affairs and Communications (MIC).<ref name="auto">Template:Cite web</ref>
Brazil
In Brazil, the TPC use in 5.150–5.725 GHz band is optional. DFS is required only in the 5.470–5.725 GHz band.<ref name="Brazil-DFS">Template:Cite web</ref>
Template:As of, some of the Australian channels require DFS to be utilised (a significant change from the 2000 regulations, which allowed lower power operation without DFS).<ref name="Australia-F2015L01438" /> As per AS/NZS 4268 B1 and B2, transmitters designed to operate in any part of 5250–5350 GHz and 5470–5725 GHz bands shall implement DFS in accordance with sections 4.7 and 5.3.8 and Annex D of ETSI EN 301 893 or alternatively in accordance with FCC paragraph 15.407(h)(2). Also as per AS/NZS 4268 B3 and B4, transmitters designed to operate in any part of 5250–5350 MHz and 5470–5725 MHz bands shall implement TPC in accordance with sections 4.4 and 5.3.4 of ETSI EN 301 893 or alternatively in accordance with FCC paragraph 15.407(h)(1).
New Zealand regulation differs from Australian.<ref name="rsm.govt.nz">Template:Cite web</ref>
Singapore
Singapore regulatory – IMDA requires DFS and TPC capabilities on 5.250–5.350 GHz above 100 mW EIRP and below or equal to 200 mW EIRP, requires DFS capability on 5.250–5.350 GHz below or equal to 100 mW EIRP, and requires DFS and TPC capabilities on 5.470–5.725 below or equal to 1000 mW EIRP. Operating 5.725–5.850 GHz above 1000 mW and below or equal to 4000 mW EIRP shall be approved on exceptional basis.<ref name="Singapore IDA" />
South Korea
In South Korea, the Ministry of Science and ICT has public notices. 신고하지 아니하고 개설할 수 있는 무선국용 무선설비의 기술기준, Technical standard for radio equipment for radio stations that can be opened without reporting. They allowed 160 MHz channel bandwidth from 2018-6-27. <ref>Template:Cite web</ref>
China MIIT expanded allowed channels Template:As of to add UNII-1, 5150–5250 GHz, UNII-2, 5250–5350 GHz (DFS/TPC), similar to European standards EN 301.893 V1.7.1.<ref>Template:Cite press release</ref>
Indonesia
Indonesia allows use of frequency of 5.150–5.250 GHz and 5.250–5.350 GHz for indoors use with maximum EIRP of 200 mW and frequency of 5.725–5.825 GHz with maximum EIRP of 4000 mW for outdoors and 200 mW for indoors.<ref name=":0" />
Template:Anchor 5.9 GHz (802.11p)
The 802.11p amendment published on 15 July 2010, specifies WLAN in the licensed band of 5.9 GHz (5.850–5.925 GHz).
Template:Anchor 6 GHz (802.11ax)
On 23 April 2020, the FCC voted on and ratified a Report and Order<ref name="wifi6e">Template:Cite web</ref><ref name="FCC-363490A1">Template:Cite web</ref> to allocate 1.2 GHz of unlicensed spectrum in the 6 GHz band (5.925–7.125 GHz) for Wi-Fi use.
U-NII-5 24 12 6 3
U-NII-6 5 2.5 1.25 0.5
U-NII-7 17.5 8.75 4.25 2.25
U-NII-8 12.5 5.75 2.5 1.25
TOTAL 59 29 14 7
For use in indoor environments, access points are limited to a maximum EIRP of 30 dBm and a maximum power spectral density of 5 dBm/MHz. They can operate in this mode on all four U-NII bands (5,6,7,8) without the use of automatic frequency coordination. To help ensure they are used only indoors, these types of access points are not permitted to be connectorized for external antennas, weather-resistant, or run on battery power.Template:R
Standard power
U-NII-5 24 12 6 3
U-NII-6 Not allowed
U-NII-7 17 8 3 1
U-NII-8 Not Allowed
TOTAL 41 20 9 4
Very-low-power devices
Client devices
Clients are limited to 24 dB below the power of the access point.Template:Cn
Europe
The European Commission is expected to rule on 6 GHz in early 2021. It is currently expected that EU regulations will permit operation only in the band from 5925 to 6425 MHz (corresponding to the US U-NII-5 band) by low-power indoor and very-low-power devices. <ref>Template:Cite web</ref>
EU 6 GHz Channels
5925–6425 MHz 24 12 6 3
60 GHz (802.11ad/ay)
The 60 GHz band 802.11ad / 802.ay also known as WiGig.This operates in the 60 GHz V band ISM band.
Template:60 GHz WiGig channels Most original 802.11ad based chipset products only use channels 1–4.
