High Frequency Beacon
Description
| 1654.95 | PRV | Preveza, Greece | Op: SW6HMU, QSL via [email protected] (Source: ndblist). | April 15, 2012 |
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 10 second repetition, 24/7 [2] | September 14, 2018 |
| 3450 | OK | OK | (Source: HF Underground Forum [3]) (Youtube video) | January 5, 2012 |
| 4079.7 | TMPnnn | SW Arizona | The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [4] | March 4, 2012 |
| | WV | | ||
| 4096 | ......_ | VA | 6 dots 1 dash | March 24, 2012 |
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [5] [6] | April 6, 2013 |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [7] | March 24, 2012 |
| 4102.8 | W... | southeast California desert | Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 | September 12, 2018 |
| 5499.13 | Dasher | WA | ||
| 6547.0 | PRV | Preveza, Greece | Op: SW6HMU, QSL via [email protected] (Source: UDXF). Also reported on 6852.1 | January 22, 2012 |
| 6816 | FU | N. America | Active June 2011, no further info. (Source: A*C*E [8], [9]) (MP3 audio recording) | January 20, 2012 |
| HA | N. America | Active July 2011, no further info. (Source: A*C*E [10], HF Underground Forum [11]) . Sometimes the frequency is reported as "6815 kHz USB". (MP3 audio recording) | July 9, 2011 | |
| 6852.1 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via [email protected] Former website [12] closed. Reported also on 6547.0 and 1654.95 kHz | April 24, 2012 |
| 6900 | Beeper | 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [13]) | October 12, 2011 | |
| 6947.1 | 13 dits and 1 dah | No further info (Source: HF Underground Forum [14]) | October 24, 2011 | |
| 6961 | TR | Mojave desert, CA | (Source: HF Underground Forum [15]) | October 23, 2011 |
| 7542 | 55555 | W Europe or NE USA | (Source: [16], N&O-173(5), UDXF) | March 1, 2012 |
| 8193.7 | Ditter | Western USA | 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
| 8193.8 | (Source: HF Underground Forum [17]) | October 23, 2011 | ||
| 8211.7 | OR | |||
| 8350 | Dasher | North Carolina | (Source: HF Underground Forum [18]) | December 31, 2011 |
| 10236.7 | Dasher | FL | ||
| 11428 | CZ | ? | (Source: HF Underground Forum [19]) | January 3, 2012 |
| 26510 | Common and Precious 3 | Berlin, Germany | 26.510 MHz Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 26598 | Dasher | SW US | ~1/2 second dash every 29-31 seconds. 24/7. | |
| 27125 | AOH | California | 16mW QRP 11m beacon CW ID "AOH" CB Channel 14 27.125 MHz Beacon | |
| 27140.8 | 50RS497 | Russia | 27.141 MHz 27.140 MHz USB 27.142 MHz LSB CW ID 50RS497 | |
| 27141.6 | 14RS000 | France | JN38 200 mW power 27.1416 MHz 27.142 MHz beacon CW ID 14RS000 + long tone burst 27.140 MHz USB 27.143 MHz LSB | |
| 27175 | 153SD101 | Thailand | CB Channel 18 27.175 MHz CW ID 153SD101 | |
| 27185 | CW ID in FM mode | Poland | Morse code modulated FM CB Channel 19 | |
| 27205 | FM voice 11m CB repeater beacon | Sweden | simplex repeater - DTMF mid band CB channel 20 27.205 MHz | |
| 27255 | CW | Switzerland | CB Channel 23 27.255 MHz - 10w power CW ID : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN | |
| 27405 | 1 dot/minute | Germany | 1 watt power 1 pip per minute CB Channel 40- 27.405 MHz | |
| 27499.6 | 50KS00 | Moscow, Russia | 2 watt power beacon 27.500 MHz LSB 27.4996 MHz CW ID 50KS00 | |
| 27500 | 1 kHz tone | Virginia | 100mw 1000 Hz modulated AM signal, carriers on 27499, 27500 and 27501 | |
| 27500 | 153RT007 | Thailand | CW QRP Beacon 27.5 MHz 27.500 MHz 11m beacon frequency | |
| 27501 | 2KP | Kansas | 25 watt power CW ID 2KP | |
| 27550 | 69BY | Costa Rica | CW ID 69BY [also on 27500 and 27610] | |
| 27596 | Pips | UNID | One beep every second - 27600 LSB 27598 USB 27.600 MHz 27.595 MHz | |
| 27610 | 69BY | Costa Rica | CW ID 69BY [also on 27500 and 27550] |
Telemetry Pirate Beacon
Windy Beacon
- HiFER
