Emission Designator
Revision as of 22:37, 24 August 2021 by R4002 (Talk | contribs)
Often just the last 3 characters are used. For example, A3E or A3 to indicate AM voice or AM telephony, F3E or F3 to indicate FM voice or FM telephony.
  • Analog voice and data
  • 12K0F3E - 3 kHz deviation, narrow FM voice - cf. PRC-1177, HH7700, PRC1077, PRC1060, PRC1080 and other more modern military FM tactical radios
  • 22K0D1D - TETRA data
  • 22K0D7D - TETRA data
  • 20K0F1D - wireless control and telemetry systems operating on the 154 MHz MURS channels 154.57 MHz or 154.6 MHz
  • 19K6F1D - FFSK - GMSK data link radios, including Maxon VHF 136-174 MHz and UHF 450-490 MHz data radios telemetry radios
  • 16K0F1D - FSK telemetry, telecommand and data links (used on various VHF/UHF bands)
  • 2K80J2D - PACTOR-III
