High Frequency Beacon
Revision as of 17:17, 27 August 2021 by Teotwaki (Talk | contribs)
Description
PRV (6852 kHz) under test
1654.95 PRV Preveza, Greece Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: ndblist). April 15, 2012
2097 A Arizona - 15 watts max., 10 second repetition, 24/7 [2] Off the air
3810 SV1TEST Athens, Greece
(KM18VB)
4079.7 TMPnnn SW Arizona The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [3] March 4, 2012
4095.650 DW SW Desert Desert Whooper - (1 Watt) 30 Whoops & ID - After 6 cycles sends Bat-Outside Temp -Inside Temp - Solar Panel current 24/7/365 https://www.hfunderground.com/board/index.php?topic=85047.0 Feb 21,2021
4096 ......_ VA 6 dots 1 dash March 24, 2012
4096.1 Dasher Joshua Tree N.P. 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 March 24, 2012
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [4] [5] April 6, 2013
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [6] March 24, 2012
4097.2 Dasher Inyo County, CA
near DVNP
4102.8 W... southeast California desert Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 September 12, 2018
5484 SD San Diego, CA
5499.13 Dasher WA
6547.0 PRV Preveza, Greece Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: UDXF). Also reported on 6852.1 January 22, 2012
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST Athens, Greece
(KM18VB)
X9Q S.E. Europe or
Middle East
6816 FU N. America Active June 2011, no further info. (Source: A*C*E [7], [8]) (MP3 audio recording) January 20, 2012
HA N. America Active July 2011, no further info. (Source: A*C*E [9], HF Underground Forum [10]) .
July 9, 2011
6852.1 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via sw6hmu@yahoo.gr Former website [11] closed. Reported also on 6547.0 and 1654.95 kHz April 24, 2012
6900 Beeper 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [12]) October 12, 2011
6947.1 13 dits and 1 dah No further info (Source: HF Underground Forum [13]) October 24, 2011
6961 TR Mojave desert, CA (Source: HF Underground Forum [14]) October 23, 2011
6994.8 - Norfolk, UK
(JO02)
2011
7542 55555 W Europe or NE USA (Source: [15], N&O-173(5), UDXF) March 1, 2012
8193.7 Ditter Western USA 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) August 26, 2018
8193.8 (Source: HF Underground Forum [16]) October 23, 2011
8211.7 OR
8350 Dasher North Carolina (Source: HF Underground Forum [17]) December 31, 2011
10236.7 Dasher FL
11428 CZ  ? (Source: HF Underground Forum [18]) January 3, 2012
26510 Common and Precious 3 Berlin, Germany 26.510 MHz Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) Jule 19, 2017
26598 Dasher SW US ~1/2 second dash every 29-31 seconds. 24/7.
27125 AOH California 16mW QRP 11m beacon CW ID "AOH" CB Channel 14 27.125 MHz Beacon
27141.6 14RS000 France JN38 200 mW power 27.1416 MHz 27.142 MHz beacon CW ID 14RS000 + long tone burst 27.140 MHz USB 27.143 MHz LSB
27175 153SD101 Thailand CB Channel 18 27.175 MHz CW ID 153SD101
27185 CW ID in FM mode Poland Morse code modulated FM CB Channel 19
27205 FM voice 11m CB repeater beacon Sweden simplex repeater - DTMF mid band CB channel 20 27.205 MHz
27255 CW Switzerland CB Channel 23 27.255 MHz - 10w power CW ID  : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN
27405 1 dot/minute Germany 1 watt power 1 pip per minute CB Channel 40- 27.405 MHz
27499.6 50KS00 Moscow, Russia 2 watt power beacon 27.500 MHz LSB 27.4996 MHz CW ID 50KS00
27500 153RT007 Thailand CW QRP Beacon 27.5 MHz 27.500 MHz 11m beacon frequency
27501 2KP Kansas 25 watt power CW ID 2KP
27550 69BY Costa Rica CW ID 69BY [also on 27500 and 27610]
27596 Pips UNID One beep every second - 27600 LSB 27598 USB 27.600 MHz 27.595 MHz
27610 69BY Costa Rica CW ID 69BY [also on 27500 and 27550]
Telemetry Pirate Beacon
Windy Beacon
