Emission Designator
Revision as of 19:21, 28 January 2022 by R4002 (Talk | contribs)
See also: Signal Identification
Often just the last 3 characters are used. For example, A3E or A3 to indicate AM voice or AM telephony, F3E or F3 to indicate FM voice or FM telephony. Other sources will omit characters. For example, 8K5F3E instead of 8K50F3E or 20KF3E or 12K F3E instead of 20K0F3E,12K0F3E etc. Some radio communications equipment manufacturers interchange designators for interoperable designators (for example, 16K0F3E and 20K0F3E).
  • Analog voice and data
  • 40K0F3E - military FM 10 kHz deviation - AN/VRC-12, AN/PRC-77 "WIDEBAND" mode for "X-mode" (see 36K0F1D and 40K0F1D)
  • 20K0F3E - Regular 5 kHz deviation "wideband" FM voice - used for land mobile systems below 150 MHz, including VHF low band 25-50 MHz
  • 18K0F3E - FM voice - 4.5 kHz FM deviation (similar to 16K0F3E 4 kHz FM deviation and 20K0F3E 5 kHz FM deviation) - cf. HTX-202 and HTX-404
  • 16K0F3E - military FM 30-88 MHz Datron HH7700, PRC1077 PRC-1077, PRC1060 PRC1080 25 kHz bandwidth mode - "wide band FM" 25 kHz channel spacing
  • 16K0F3E - 25 kHz "25K" wide FM channel spacing +/- 5kHz deviation FM voice (per Alinco land mobile literature)
  • 15K8F3E - MURS mobile radio (154.57 MHz and 154.6 MHz only) FM voice, considered functionally the same as 20K0F3E or 16K0F3E
  • 14K0F3E - 20 kHz "20K" medium FM channel spacing +/- 4kHz deviation FM voice (per Alinco land mobile literature)
  • 12K0F3E - 3 kHz deviation, narrow FM voice - cf. HH7700, PRC1077, PRC1060, PRC1080 and other more modern military FM tactical radios
  • 11K0F3E - 12.5 kHz "12K" or 12.5K narrow FM channel spacing +/- 2.5kHz deviation FM voice (per Alinco land mobile literature)
  • 10K6F3E - Portable GMRS walkie talkies (Baofeng) based on the UV-82 and UV-5R radios - 10.59 kHz bandwidth, called 11K0F3E by manufacturer
  • 8K50F3E - Narrow mode on Alinco VHF and UHF FM transceivers
  • 6K00A3E - AM voice, double side band with carrier (6 kHz bandwidth) - used for CB and VHF aircraft band airband
  • 40K0F1D - military FM 10 kHz secure voice X-MODE AN/VRC-12, AN/PRC-77 "WIDEBAND" mode for "X-mode" (see 36K0F3E and 40K0F3E)
  • 36K0F1D - military FM 8 kHz secure voice X-MODE AN/VRC-12, AN/PRC-77 "WIDEBAND" mode for "X-mode" (see 36K0F3E and 40K0F3E)
  • 25K0F2D - Wideband "FM" paging systems 26/27 MHz and 40 MHz bands - UK and European wideband on-site pagers
  • 22K0D1D - TETRA data
  • 22K0D7D - TETRA data
  • 20K0F1D - FSK data, regular 5 kHz deviation - used for 72 MHz wireless clock systems, callboxes and other operational fixed purposes
  • 20K0F1D - wireless control and telemetry systems operating on the 154 MHz MURS channels 154.57 MHz or 154.6 MHz
  • 20K0F2D - general use for packet data - on amateur radio VHF/UHF bands for example
  • 20K0G3D - PSK - phase shift keying, 20 kHz bandwidth remote control RC radio control systems, various VHF/UHF bands
  • 19K6F1D - FFSK - GMSK data link radios, including Maxon VHF 136-174 MHz and UHF 450-490 MHz data radios telemetry radios
  • 19K0D1W - P25 Project 25 2-slot TDMA P25 Phase II true TDMA, appearing on Phase II P25 licenses
  • 16K0F1D - FSK telemetry, telecommand and data links (used on various VHF/UHF bands, including RC services in Europe
  • 16K0G2D - AIS on VHF marine band 161.975 MHz and 162.025 MHz
  • 11K3F2D - Data links on VHF/UHF land mobile bands, including IFLOWS fixed point to point hydrologic data systems
  • 11K0F2D - Data links on VHF/UHF land mobile bands, including IFLOWS fixed point to point hydrologic data systems
  • 10K4F2D - SCADA link telemetry radios (narrowband radio links) 146-174 MHz, 154-174 MHz, 406-470 MHz (CW ID 10K4F3E)
  • 10K0F1D - FSK remote control FM RC systems, 10 kHz bandwidth
  • 9K36F7W - Yaesu System Fusion YSF combined C4FM (Voice Wide * Voice Narrow + Data * Data Wide)
  • 9K20F3D - DTMF selective calling, ANI - automatic number identification, including end of transmission DTMF bursts
  • 9K10F3D - DTMF selective calling, ANI - automatic number identification, including end of transmission DTMF bursts
  • 8K50F2D - Packet radio - narrow band mode per Alinco amateur radio documentation (8K50F3E data mode)
  • 8K00A1D - 8 kHz AFSK - AM remote control, 26-28 MHz band, 72-76 MHz band, 49 MHz band/27 MHz band
  • 6K00F7W - Mixed analog/digital use, technically incorrect per FCC rules, but widely found on licenses 6.0 kHz bandwidth
  • 6K00F1D - SCADA, data links, carrier FSK, telecommand (R/C, remote control and radio control systems 25 MHz and above)
  • 2K80J2D - PACTOR-III
