SINCGARS
Revision as of 19:25, 21 April 2022 by R4002 (Talk | contribs)
Military tactical radio - FM tactical radio system Single Channel Air-Ground Radio System, commonly known as SINCGARS "sink-gars", FM or Fox Mike radio. SINCGARS and FM are used in conjunction with HF-SSB systems, UHF/SHF/EHF SATCOM and other communications systems for tactical military communications purposes. See also: militia radio frequencies.
For example:
  • Relay Operation:
  • Repeater Operation:
Background and History
60.000 MHz to 80.000 MHz TBS Series "Talk Between Ships" - Ship-to-Ship voice radio 60-80 MC radio - US Navy Crystal controlled 20 kHz steps - TBS crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) 100 kHz (channels 380-549), PRC-10, PRC-10A
40.000 MHz to 48.000 MHz American Infantry Band - portable tactical radios - WWII vintage 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) 50 kHz channels - AM voice, close air support and tank command nets
30 MHz to 512 MHz Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands, REMBASS 138.025 MHz to 152.975 MHz (25 kHz steps) 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
  • 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
