HF pagers
Revision as of 16:49, 21 July 2022 by R4002 (Talk | contribs)
See also the Remote Control FCC Part 95 Class C Page - Remote Control Radio Service (RCRS), FCC Rules Part 95, Personal Radio Services, Subpart C—Radio Control Radio Service 95.701-95.899, previously 95.201-95.225
Frequency List
Note: This list is a dynamic list and will never be complete. Many of these systems - especially the paging systems and telemetry or data link systems, act as de facto 11 meter beacons and de facto high frequency beacons. Included FSK data signals and pager signals - 25 to 30 MHz, included 29.7 MHz to 30 MHz portion above the 10 meter ham radio allocation 28 to 29.7 MHz but below the official beginning of VHF at 30.000 MHz
Frequency Remarks
25.775 MHz On-site and hospital paging, FM voice and data (Western Europe) - confirmed active July 2022
26.100 MHz Hospital pagers - Europe FM mode
26.115 MHz FSK data link
26.145 MHz Marine Instruments Radio Buoys
26.150 MHz Marine Instruments Radio Buoys
26.150 MHz Hospital pagers - Europe - FM mode - confirmed active October 2021
26.155 MHz Marine Instruments Radio Buoys
26.160 MHz Marine Instruments Radio Buoys
26.165 MHz Marine Instruments Radio Buoys
26.170 MHz Marine Instruments Radio Buoys
26.175 MHz Marine Instruments Radio Buoys
26.200 MHz On site paging systems - UK
26.250 MHz UK Paging on-site pager - confirmed active October 2021
26.300 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.350 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.400 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.450 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.500 MHz Paging, heard in Europe, noted use in Holland - FM mode - confirmed active June 2022
26.550 MHz POCSAG pager - Europe and UK
26.555 MHz POCSAG pager - Europe
26.605 MHz POCSAG Pager - UK and Western Europe
26.650 MHz Hospital pagers - Europe and UK
26.695 MHz Offset frequency for 26.700 MHz, heard in Western Europe and UK - confirmed active June 2022
26.700 MHz European on-site paging systems - confirmed active July 2022
26.703 MHz Offset frequency for 26.7025 MHz, heard in Western Europe and UK
26.707 MHz UK Paging, often slightly offset (26.7065 MHz, etc.)
26.710 MHz UK Paging, often slightly offset (26.709 MHz, etc.)
26.713 MHz UK Paging, offset 26.7125 MHz
26.735 MHz European paging systems, possibly also used in UK
26.739 MHz FSK data links (narrowband bursts) - dial frequency 26.737 MHz USB or 26.740 MHz LSB
26.750 MHz Hospital pagers Europe - POCSAG - confirmed active July 2022
26.751 MHz Pager - offset frequency 26.7505 or 26.751 MHz - Western Europe
26.835 MHz UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.8350 MHz
26.850 MHz Hospital pagers - Europe FM mode - FSK - confirmed active October 2021
26.855 MHz Hospital pagers - Europe FM mode - FSK - confirmed active October 2021
26.859 MHz FSK data links (narrowband bursts) - dial frequency 26.857 MHz USB or 26.860 MHz LSB
26.885 MHz POCSAG pager - Europe
26.920 MHz UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.9200 MHz
26.935 MHz Data link or telemetry system, unknown origin or source, possibly Middle East - FM mode
26.935 MHz POCSAG pager - Europe
26.940 MHz POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system
26.945 MHz Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK
26.950 MHz Hospital pagers on-site paging systems Europe - confirmed active October 2021
26.950 MHz POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system
26.955 MHz Paging heard on several Russian SDRs, possible alternate to 26.945 MHz, 26.95 MHz and 26.96 MHz frequencies?
26.960 MHz Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK
26.995 MHz Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4 watt PTDFM FSK (FM) 27MHz transmitter
26.995 MHz Remote Control Technology Medium Range Wireless Switch System MRWSS model # 01214 2 watt FSK (FM) 27MHz transmitter
27.000 MHz Russian data link or telemetry system, 10-12 kHz, MFSK
27.007 MHz POCSAG paging signal, heard in Finland (unknown source), possibly offset 27.005 MHz or 27.0075 MHz
27.069 MHz FSK data links (narrowband bursts) - dial frequency 27.067 MHz USB or 27.070 MHz LSB
27.070 MHz POGSAG Pager FM - Russian origin - 27 MHz Russian paging system frequency
27.090 MHz European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz)
27.095 MHz European standardized Eurobalise train telemetry system 27,095 MHz +/- 500 kHz 26.695 MHz - 27.595 MHz
27.100 MHz European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz)
27.100 MHz FSK data links (narrowband bursts) - dial frequency 27.097 MHz USB or 27.103 MHz LSB
27.120 MHz POCSAG Pager Signals heard in UK - unknown origin
27.129 MHz FSK data links (narrowband bursts)
27.145 MHz THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 44 output version
27.179 MHz FSK data links (narrowband bursts) - dial frequency 27.177 MHz USB or 27.180 MHz LSB
27.195 MHz Remote Control Technology Short Range Wireless Switch System SRWSS model # 01215 1 watt PTDFM FSK (FM) 27MHz transmitter
27.220 MHz POCSAG Pager Signals heard in UK - unknown origin
27.233 MHz POCSAG Paging signals, narrowband (center frequency 27.233, tune 27.230 MHz USB)
27.250 MHz POCSAG pager - heard in UK, 8-10 kHz wide signal
27.255 MHz Radio Control RC Service Part 95 25 watt power limit, 8.5 kHz bandwidth limit in USA
27.255 MHz Multiple-site FSK 27 MHz data link system noted near Highland Falls, NY USA, nearly constant FSK data bursts - off the air?
27.255 MHz Multiple-site FSK 27 MHz data link system noted near Rockport, Maine - FSK data bursts identical to those seen on Highland Falls NY SDR
27.255 MHz Data link system located in rural Virginia, roughly 20 miles north of Richmond, VA (data bursts on 27.255 MHz)
27.255 MHz RadioShack 7 watt FSK paging transmitter on-site system model PG-99 17-6020 - 100 unique receiver (pager) IDs supported
27.255 MHz RadioShack 4 watt FSK paging transmitter on-site system model 17-6023 - 1000 unique receiver (pager) IDs supported
27.255 MHz Linear Controls XT-1 1-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-4 4-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-1H 1-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-2H 2-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 12w output version
27.259 MHz FSK data links (narrowband bursts) - dial frequency 27.257 MHz USB or 27.260 MHz LSB
27.319 MHz FSK data links (narrowband bursts) - dial frequency 27.317 MHz USB or 27.320 MHz LSB
27.450 MHz Paging, heard in several parts of Europe, sometimes an unmodulated FM carrier transmitted - 27.45 MHz
27.450 MHz Alarm system datalinks - UK - 500mW power limit (considered a SRD or RC device)
27.505 MHz POCSAG Paging Signals 8-12 kHz wide
27.510 MHz Paging, voice and data - possibly offset 27.5125 MHz or 27.513 MHz
27.650 MHz Data link/Carrier signal, FM/FSK, possible military, Norfolk, VA - confirmed active again March 2019
27.845 MHz POCSAG Pager - UK and/or Europe
27.850 MHz POCSAG paging signals - Europe
27.950 MHz POCSAG Paging - Heard in UK (June 2022)
27.970 MHz FSK data links
27.980 MHz FSK data links
27.990 MHz FSK data links
27.992 MHz FSK data links - 27.992 MHz 27.993 MHz
27.995 MHz FSK data links
29.750 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.75 MHz POCSAG
29.800 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.8 MHz POCSAG
29.850 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.85 MHz POCSAG
29.900 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.9 MHz POCSAG
29.950 MHz POCSAG Paging Pager - Heard in UK, likely European origin 29.95 MHz POCAG
Frequency List - Europe and UK
Frequency Remarks
26.100 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.150 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.200 MHz Hospital and on-site paging systems, Italy, Holland, UK and others - very active frequency
26.250 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.300 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.350 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.400 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.450 MHz European standard hospital and on-site on-campus paging - Europe and UK
26.500 MHz European standard hospital and on-site on-campus paging
26.500 MHz Italy Paging on-site pager (wide signal, 12-13 kHz bandwidth)
26.510 MHz European POCSAG paging signal
26.550 MHz European standard hospital and on-site on-campus paging
26.600 MHz European standard hospital and on-site on-campus paging
26.605 MHz UK Paging Frequency, also European systems
26.635 MHz UK Paging on-site systems
26.650 MHz European standard hospital and on-site on-campus paging
26.750 MHz European standard hospital and on-site on-campus paging
26.800 MHz European standard hospital and on-site on-campus paging
26.835 MHz POCSAG pager - Eastern Europe or Russia source
26.850 MHz European standard hospital and on-site on-campus paging
26.855 MHz Hospital pagers - European source
26.900 MHz European standard hospital and on-site on-campus paging - very active frequency
26.938 MHz POCSAG pager - Europe - offset frequency 26.937 MHz 26.9375 MHz
26.950 MHz European standard hospital and on-site on-campus paging
26.950 MHz International fixed service allocation
26.955 MHz International fixed service allocation
27.100 MHz POCSAG Pager heard in UK and Europe - unknown source
27.150 MHz POCSAG Pager heard in UK and Europe - unknown source
27.200 MHz POCSAG Pager heard in UK and Europe - unknown source
27.500 MHz Hospital pagers (Holland) FM mode - POCSAG signals noted on frequency
27.847 MHz POCSAG Pager - UK and/or Europe offset frequency 27.8465 MHz
27.848 MHz POCSAG Pager - UK and/or Europe offset frequency 27.8475 MHz
Keywords:
