High Frequency Beacon
Description
Freq (kHz) | Station ID | Location | Operation Notes | Last reported |
2008.4 | Dits | Nevada USA | (CW ditter 130 mW) N/S dipole, battery power, night only. Approximate CW timing: 191 millisecond dit duration, 1.55 second repetition, 1.5 minute ON cycle, 3 minute OFF cycle [1] | December 27, 2018 |
2097 | A | Arizona | - 15 watts max., 10 second repetition, 24/7 [2] | Off the air |
4094 | UFO | unknown | id's UFO TMP three times, after TMP two numbers are sent then back to dashes. On the air around Nov 2020 | 2021 |
4095.650 | DW | SW Desert | Desert Whooper - (1 Watt) 30 Whoops & ID - After 6 cycles sends Bat-Outside Temp -Inside Temp - Solar Panel current 24/7/365 https://www.hfunderground.com/board/index.php?topic=85047.0 | 2021 |
4096.1 | Dasher | Joshua Tree N.P. | 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 | 2021 |
4096.2 | Buddha | -Calif Desert | Slow dasher called Buddha, was "Phallaxy" was "Viking". About 30 mW, daytime only. On for 3 seconds, off for 3 seconds | 2021 |
4096.85 | "Marin Ditter" | Marin County | 24/7 5-10 mW, 2nd harmonic of 8193.77 radiates better | 2021 |
4097.08 | Dasher | unknown | Slow Dasher, 2secs on and 2 secs off. Discovered Nov. 2020, it does appear to be related to 7997.2 kHz. The two dashers appear to be in sync. | 2021 |
4097.1 | Dasher | unknown | Fast Ditter. New in 2021 | 2021 |
4098.2 ~ 4104+ | ZN | Western USA | Drifts up to 4104+ kHz during daylight hours, drifts down to 4098 kHz just after sunset, ZN sometimes heard run together like a prosign with an extra dash between the Z and N: "dah-dah-di-di-dah-dah-dit" or --..--. | September 08, 2018 |
4100.1 | H | Unknown | "H" repeated ID only, Source: HF Underground, 4 MHz Western USA Beacons | September 10, 2018 |
4102.8 | W... | southeast California desert | Windy beacon - see section on this page about the telemetry. Sends Morse code 'W' and series of dits - each dit correlating to a turn of its anemometer wind sensor, so if it is windy in the vicinity, it sends lots of dits; and no wind, no dits. TMP temperature (Fahrenheit), B battery voltage (decivolts). 24/7/365 | 2021 |
6700.4 | Dasher | Joshua N.P. | About 62 dashes per min., 24/7 (Hexy2k) | 2021 |
7998.1 | HI | Western USA | Morse CW beacon. Approximate timing: 9.64 seconds repetition, dit duration 128 milliseconds | 27 December, 2018 |
8191.7 | Dasher | Southwestern USA | 4 second dash (somewhat variable), likely 2nd harmonic of Viking on 4095.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
8192.7 | Dasher | Southwestern USA | 2.3 second dash, likely 2nd harmonic of Haystack on 4096.38 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | August 26, 2018 |
8193.7 | Ditter | Western USA | 1.1 dits per second, MarinDit, also may be heard on 4096.86 kHz (Source: HF Underground Forum, 8 MHz Western USA Beacons) | 2021 |
8200.1 | D | Unknown | (Source: HF Underground Forum) | September 08, 2018 |
1654.95 | PRV | Preveza, Greece | Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: ndblist). | April 15, 2012 |
3810 | SV1TEST | Athens, Greece (KM18VB) | no further info. (Source: UDXF) | |
409*.** | Common and Precious 5 | Berlin, Germany | CW + RTTY alternating. Grid powered. 50W into shortened Groundplane. | Work in Progress |
4194 | MX | Europe | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. | |
4608 | MXC | Europe | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX. | |
6,375.00 | Common and Precious 4 | Berlin, Germany | CW only. Solar powered with Battery backup. 1,5W into a short vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 17, 2018 |
6,398.5 | Common and Precious 2 | Berlin, Germany | CW only. Grid powered. 25W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
6547.0 | PRV | Preveza, Greece | Op: SW6HMU, QSL via sw6hmu@yahoo.gr (Source: UDXF). Also reported on 6852.1 | January 22, 2012 |
6815 | SV1TEST | Athens, Greece (KM18VB) | Active 2010-2011, no further info. (Source: UDXF) (Youtube video) | |
X9Q | S.E. Europe or Middle East | Sporadic operation, no further info. (Source: UDXF) | April 2012 | |
6852.1 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via sw6hmu@yahoo.gr Former website [3] closed. Reported also on 6547.0 and 1654.95 kHz | April 24, 2012 |
6994.8 | - | Norfolk, UK (JO02) | "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS RRR RRR RRR REPORTS TO UKBEACON _ GMAIL.COM" (Source: UDXF) | 2011 |
7542 | 55555 | W Europe or NE USA | (Source: [4], N&O-173(5), UDXF) | March 1, 2012 |
8000.0 | QRP | W. Europe | reported on UDXF by european monitors | February 9, 2014 |
10,237.74 | Common and Precious | Berlin, Germany | Grid powered. 5W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
26510 | Common and Precious 3 | Berlin, Germany | 26.510 MHz Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
27140.8 | 50RS497 | Russia | 27.141 MHz 27.140 MHz USB 27.142 MHz LSB CW ID 50RS497 | |
27141.6 | 14RS000 | France | JN38 200 mW power 27.1416 MHz 27.142 MHz beacon CW ID 14RS000 + long tone burst 27.140 MHz USB 27.143 MHz LSB | |
27175 | 153SD101 | Thailand | CB Channel 18 27.175 MHz CW ID 153SD101 | |
27185 | CW ID in FM mode | Poland | Morse code modulated FM CB Channel 19 | |
27205 | FM voice 11m CB repeater beacon | Sweden | simplex repeater - DTMF mid band CB channel 20 27.205 MHz | |
27245 | siren-like "whoop" | UK | 1 watt power 1 pip per minute CB Channel 25 Solar Powered Beacon 27.245MHz 27MHz UK CB beacon | |
27255 | CW | Switzerland | CB Channel 23 27.255 MHz - 10w power CW ID : VVV VVV DE 15BS061 15BS061 10 WATT 11M BEACON LOC. JN37TN JN37TN | |
27405 | 1 dot/minute | Germany | 1 watt power 1 pip per minute CB Channel 40- 27.405 MHz | |
27499.6 | 50KS00 | Moscow, Russia | 2 watt power beacon 27.500 MHz LSB 27.4996 MHz CW ID 50KS00 | |
27500 | 69BY | Costa Rica | CW ID 69BY [also on 27550 and 27610] | |
27500 | Pips | Mexico City | CW pips (unknown TX power) | |
27500 | 38 Voice | Greenland | USB voice ID "38 voice beacon" | |
27500 | 153RT007 | Thailand | CW QRP Beacon 27.5 MHz 27.500 MHz 11m beacon frequency | |
27500 | 19/27MHZDX | Netherlands | CW ID VVV 19/27MHZDX JO21BU 20W 11MTRBEACONATGMAIL.COM | |
27550 | 69BY | Costa Rica | CW ID 69BY alternate freq | |
27610 | 69BY | Costa Rica | CW ID 69BY primary 27.610 MHz 27609.9 27.609.9 MHz | Sept 8, 2021 |
Telemetry Pirate Beacon
Windy Beacon
Desert Whooper
This telemetry beacon broadcasts on 4095.70 and has been logged widely on the West Coast, up into Canada, as far west as Hawaii and as far east as Maryland. It sends a Morse Code ID of DW, then thirty upward 150 Hz sweeps (whoops), repeats 6 times then sends telemetry: BAT is in volts DC. oTMP is in degrees F with a calibrated outdoor thermistor, iTMP is in degrees F using a digital two wire sensor within the weathertight box and PV is in milliAmps to monitor solar panel performance.
QSL Card
- HiFER 22 meter band 13.56 MHz 13560 kHz band Part 15 beacons
- 11m beacons 11 meter band/27 MHz CB beacons
