SINCGARS
Revision as of 17:13, 17 April 2023 by R4002 (Talk | contribs)
For example:
  • Relay Operation:
  • Repeater Operation:
Background and History
60.000 MHz to 80.000 MHz TBS "Talk Between Ships" - VHF 60-80 MC 60-80 MHz Ship to Ship voice radio 60-80 MC radio - US Navy AM mode 50w output VHF Crystal controlled 60-80 MHz AM voice unknown channel spacing - TBS radio crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) - note 27.0 MHz, 27.1 MHz, 27.2 MHz up to 27.9 MHz overlap 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) - note 38.0 MHz, 38.1 MHz, 38.2 MHz up to 38.9 MHz overlap 100 kHz (channels 380-549), PRC-10, PRC-10A
40.000 MHz to 48.000 MHz American Infantry Band - portable VHF FM tactical radios - WWII vintage 200 kHz - channel 0 = 40.0 MHz, channel 40 = 48.0 MHz, SCR-300 (BC-1000) manpack backpack radio
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) 50 kHz channels - AM voice with FM characteristics, close air support and tank command nets
20.000 MHz to 52.000 MHz Soviet / Eastern Bloc USSR R-111 (low band: 20-36 MHz, high band: 36-52 MHz) High power (75w) Russian FM tank radio
20.000 MHz to 22.375 MHz Soviet / Eastern Bloc USSR R-113 (25 kHz channel steps, 96 channels) Medium power (16w) Russian FM tank radio
20.000 MHz to 51.500 MHz Soviet / Eastern Bloc USSR R-123 R-123M (low band: 20-35.75 MHz, high band: 35.75-51.5 MHz) Medium power (20w) Russian FM tank radio
20.000 MHz to 69.975 MHz Yugoslavian tank radio - exported widely, 25 kHz channel steps) Medium power (30w) FM tank radio
20.000 MHz to 49.975 MHz Chinese FM tank radio (example Type 889 radio) - widely exported - 25 kHz channel steps Chinese clone of Russian 20-50 MHz tank radios (such as the R-113 or P-113) - FM voice, 25 kHz channels 3w low 20w high RF power
30.000 MHz to 75.950 MHz Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 family using the RT-246/VRC RT-246A RT-542 RT-542/VRC RT-542A/VRC radio sets - AN/VRC-12, VRC-43, VRC-44, VRC-45, VRC-46, VRC-47, VRC-48, VRC-49 Jeep radios, etc. and dozens of others
30 MHz to 512 MHz Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands, REMBASS 138.025 MHz to 152.975 MHz (25 kHz steps) - sometimes listed as 30-511.99 MHz or 30.000 MHz to 511.995 MHz 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps
2400-2500 MHz (2.4 GHz) Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems - including the Personal Role Radio (PRR) Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
For additional information, see the Business Radio (Business Band) land mobile radio service page - including the VHF low band subsection.
  • 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
Confirmed 30-88 MHz and 30-50 MHz FM Military Frequencies In Use North America USA
Some of these are active enough to operate basically as de facto VHF low band beacons.
Most military bases have a few VHF FM frequencies that are used for range control, aircraft control or advisory and other purposes. These are published frequencies and are not tactical in nature. The tactical frequencies are changed on a regular basis and often either the LMR (UHF P25 trunking systems in the 380-399.9 MHz range), frequency hopping (30-88 MHz range). Aircraft communications will be found in the UHF band, plus the 137-144 MHz and 148-150.8 MHz military VHF AM band (which is shared with military land mobile users). Many military bases will have their control tower simulcast on UHF airband (225-400 MHz) with VHF airband (usually 126.200 MHz) and sometimes a FM frequency (VHF low band).
Work still in progress, list will be forthcoming.
  • 30.0000 MHz FM CSQ - Default frequency (tone OFF) - also used for radio tests and training
  • 30.0000 MHz FM 150 Hz - Default frequency - often used for radio tests, training
  • 30.0000 MHz FM 150.0 Hz - Convoy operations
  • 30.0250 MHz FM 150 Hz - Air to air communications, helicopters - extensive use
  • 30.0500 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Air to air
  • 30.1000 MHz FM 150.0 Hz - Air to air communications, helicopters - New York and New Jersey areas
  • 30.1500 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to ground
  • 30.1500 MHz FM 150.0 Hz - Air to air communications, helicopters, Washington D.C. area
  • 30.3000 MHz FM 150.0 Hz - Air to air communications, helicopters - extensive use
  • 30.3000 MHz FM 150.0 Hz - Fort Hood, Texas operations
  • 30.4500 MHz FM 150.0 Hz - Fort Hood, Texas Range Control Primary 30.45 FM 30.450 MHz FM
  • 30.5000 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Gray Army Airfield - Air Operations
  • 30.5000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Air to air
  • 30.5000 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range Control Alternate
  • 30.7000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 30.8000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 31.7000 MHz FM 150.0 Hz - Convoy operations
  • 32.0500 MHz FM 150.0 Hz - Raptor Net
  • 32.6000 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Gray Army Airfield - Air National Guard Operations 32.600 MHz FM
  • 32.7000 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Washington State
  • 32.7000 MHz FM 150.0 Hz - Convoy operations
  • 32.7500 MHz FM 150.0 Hz - Convoy operations
  • 34.0500 MHz FM 150.0 Hz - Convoy operations
  • 34.1000 MHz FM 150.0 Hz - Fort Belvoir, Virginia - Air Traffic Control
  • 34.1000 MHz FM 150.0 Hz - Fort Pickett, Virginia - Range Control
  • 34.1000 MHz FM 150.0 Hz - Vermont National Guard
  • 34.1500 MHz FM 150.0 Hz - Convoy operations
  • 34.6000 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Washington State
  • 34.8000 MHz FM 150.0 Hz - Fort Eustis, Virginia - Aircraft Advisory
  • 34.9000 MHz FM 150.0 Hz - National Guard - Disaster Response Common
  • 34.9000 MHz FM 150.0 Hz - Virginia National Guard
  • 36.1000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.1000 MHz FM 150.0 Hz - Fort Pickett, Virginia - Range Control
  • 36.5000 MHz FM 150.0 Hz - Butts Army Air Field - Colorado
  • 36.5250 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.6000 MHz FM CSQ - YSD Radio Beacon ("YSD" in Morse Code + long tone burst) Canadian Forces Base Suffield 36.600 MHz FM CFD Suffield
  • 36.6500 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.7000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.8000 MHz FM 150.0 Hz - National Guard Helicopter operations near San Antonio, Texas
  • 36.9000 MHz FM 150.0 Hz - Martindale Army Heliport, San Antonio, Texas 36.900 MHz FM
  • 37.1000 MHz FM CSQ - Fort Pickett, Virginia
  • 37.1000 MHz FM 150.0 Hz - Fort Pickett, Virginia
  • 38.3000 MHz FM 150.0 Fort Hood, Texas Range Control Alternate 38.300 MHz FM (Primary: 30.450 MHz FM)
  • 38.3500 MHz FM 150.0 Hz - Butts Army Air Field - Air Traffic Control
  • 38.4500 MHz FM 150.0 Hz - Joint Base Lewis-McChord - PMSV Metro (also on 134.100 MHz FM)
  • 38.5000 MHz FM 150.0 Hz - Camp Edwards (MA) Range Operations
  • 38.5000 MHz FM 150.0 Hz - Fort McCoy, Wisconson - Tower - Secondary
  • 38.5000 MHz FM 150.0 Hz - Fort A.P. Hill, Virginia Range Control Primary 38.50 MHz FM
  • 38.5000 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range Control Primary
  • 38.7000 MHz FM 150.0 Hz - Fort Eustis, Virginia - Range Control
  • 38.7000 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Range Control
  • 38.9000 MHz FM 150.0 Hz - Medevac
  • 38.9000 MHz FM 150.0 Hz - Camp Shelby, Mississippi Range Control
  • 38.9500 MHz FM 150.0 Hz - Rhode Island National Guard
  • 40.0000 MHz FM 150.0 Hz - Air to air communications, helicopters
  • 40.1000 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to air
  • 40.2000 MHz FM 150.0 Hz - Fort Hood, Texas
  • 40.2000 MHz FM 150.0 Hz - Virginia National Guard
  • 40.3000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 40.3000 MHz FM 150.0 Hz - Fort Gregg-Adams (Fort Lee), Virginia Range Control 40.300 MHz FM
  • 40.3500 MHz FM 150.0 Hz - Fort Eustis, Virginia - Base Operations
  • 40.5000 MHz FM 150.0 Hz - FM Emergency Frequency 40.50 MHz FM 40.500MHz FM
  • 40.5500 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 41.0000 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to ground operations
  • 41.0000 MHz FM 150.0 Hz - Air to air communications, helicopters, Washington D.C. area
  • 41.1000 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to ground operations
  • 41.3500 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Range Control Alternate
  • 41.5000 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Operations (also on 138.600 MHz AM VHF and 395.225 MHz UHF)
  • 41.5250 MHz FM 150.0 Hz - Fort Gregg-Adams (Fort Lee), Virginia Air to Air 41.525MHz FM
  • 41.6000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 41.7000 MHz FM 150.0 Hz - Fort McCoy, Wisconson - Tower Primary
  • 41.9000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Range Control Primary
  • 41.9500 MHz FM 150.0 Hz - Marine Corps Combat Center Twentynine Palms Base Operations - BEARMAT
  • 41.9500 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Tower
  • 45.4500 MHz FM 150.0 Hz - Convoy operations
  • 46.6500 MHz FM 150.0 Hz - Quantico Marine Corps base Virginia
  • 46.7000 MHz FM 150.0 Hz - Quantico Marine Corps base Virginia
  • 46.7500 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia
  • 46.8000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Medical Alternate
  • 46.8000 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia
  • 47.0000 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range Control
  • 47.0000 MHz FM 150.0 Hz - Rhode Island National Guard
  • 49.7000 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range operations
  • 49.7000 MHz FM 150.0 Hz - Rhode Island National Guard
  • 49.7250 MHz FM 150.0 Hz - Virginia Air National Guard Operations - Richmond Virginia Area
  • 49.7250 MHz FM 150.0 Hz - Massachusetts National Guard
  • 49.8000 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 49.8500 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Medical Primary
  • 49.9000 MHz FM 150.0 Hz - Canadian Forces Base Suffield Alberta, Canada - Range Control 49.9 MHz FM 49.900 MHz FM
  • 49.9000 MHz FM 150.0 Hz - Massachusetts National Guard
  • 49.9000 MHz FM 150.0 Hz - Rhode Island National Guard
  • 49.9000 MHz FM 150.0 Hz - Fort Hood, Texas
  • 49.9250 MHz FM 150.0 Hz - Massachusetts National Guard
  • 49.9500 MHz FM 150.0 Hz - Convoy operations
  • 49.9750 MHz FM 150.0 Hz - Massachusetts National Guard
  • 50.7500 MHz FM 150.0 Hz - Butts Army Air Field - Colorado PMSV Metro
  • 52.7500 MHz FM 150.0 Hz - Fort Belvoir, Virginia - Air National Guard Ops
