DDE
- 35 MHz / 36 MHz repeater output (mobile RX)
- 39 MHz / 40 MHz repeater input (mobile TX)
Technical Specifications
12.5 kHz spacing, NFM 11K0F3E, 11K0F1D, 11K0F2D and 11K0F3D emission types. Voice and data. CTCSS (PL) tone squelch and in-band audio-frequency multi-tone selective calling (SELCALL) in extensive use. 35 MHz French PMR radio.
ePMR LMR PMR PLMR VHF low band land mobile radio system. The VHF low band spectrum is used by numerous other services, including other services in France and elsewhere in Europe, military FM, paging networks, public safety two-way radio systems, AM (DSB) 40MHz DSB fishery radiotelephone fishing fleet fishery radio networks, FM radiotelephone fishery radio systems, data link, remote control or "telecommand" and various other uses worldwide.
Band Plan - Channelization Frequency List Channel List Frequency Pairs
- Mobile RX (Repeater Output) / Mobile TX (Repeater Input)
- 36.1625 MHz / 40.5625 MHz - Channel 00
- 36.1750 MHz / 40.5750 MHz - Channel 01
- 36.1875 MHz / 40.5875 MHz - Channel 02
- 36.2000 MHz / 40.6000 MHz - Channel 03
- 36.2125 MHz / 40.6125 MHz - Channel 04
- 36.2250 MHz / 40.6250 MHz - Channel 05
- 36.2375 MHz / 40.6375 MHz - Channel 06
- 35.0000 MHz / 39.4000 MHz - Channel 07
- 35.0125 MHz / 39.4125 MHz - Channel 08
- 35.0250 MHz / 39.4250 MHz - Channel 09
- 35.0375 MHz / 39.4375 MHz - Channel 10
- 35.0500 MHz / 39.4500 MHz - Channel 11
- 35.0625 MHz / 39.4625 MHz - Channel 12
- 35.0750 MHz / 39.4750 MHz - Channel 13
- 35.0875 MHz / 39.4875 MHz - Channel 14
- 35.1000 MHz / 39.5000 MHz - Channel 15
- 35.1125 MHz / 39.5125 MHz - Channel 16
- 35.1250 MHz / 39.5250 MHz - Channel 17
- 35.1375 MHz / 39.5375 MHz - Channel 18
- 35.1500 MHz / 39.5500 MHz - Channel 19
- 35.1625 MHz / 39.5625 MHz - Channel 20
- 35.1750 MHz / 39.5750 MHz - Channel 21
- 35.1875 MHz / 39.5875 MHz - Channel 22
- 35.2000 MHz / 39.6000 MHz - Channel 23
- 35.2125 MHz / 39.6125 MHz - Channel 24
- 35.2250 MHz / 39.6250 MHz - Channel 25
- 35.2375 MHz / 39.6375 MHz - Channel 26
- 35.2500 MHz / 39.6500 MHz - Channel 27
- 35.2625 MHz / 39.6625 MHz - Channel 28
- 35.2750 MHz / 39.6750 MHz - Channel 29
- 35.2875 MHz / 39.6875 MHz - Channel 30
- 35.3000 MHz / 39.7000 MHz - Channel 31
- 35.5000 MHz / 39.9000 MHz - Channel 32
- 35.5500 MHz / 39.9500 MHz - Channel 33
- 35.6000 MHz / 40.0000 MHz - Channel 34
- 35.6500 MHz / 40.0500 MHz - Channel 35
- 35.7750 MHz / 40.1750 MHz - Channel 36
- 35.8000 MHz / 40.2000 MHz - Channel 37
- 35.8500 MHz / 40.2500 MHz - Channel 38
- 35.9500 MHz / 40.3500 MHz - Channel 39
- 35.9875 MHz / 40.3875 MHz - Channel 40
- 36.0000 MHz / 40.4000 MHz - Channel 41
- 36.0500 MHz / 40.4500 MHz - Channel 42
- 36.1000 MHz / 40.5000 MHz - Channel 43
- 36.1500 MHz / 40.5500 MHz - Channel 44
- 35.5125 MHz / 39.9125 MHz - Channel 45
- 35.5250 MHz / 39.9250 MHz - Channel 46
- 35.5375 MHz / 39.9375 MHz - Channel 47
- 35.5625 MHz / 39.9625 MHz - Channel 48
- 35.5750 MHz / 39.9750 MHz - Channel 49
- 35.5875 MHz / 39.9875 MHz - Channel 50
- 35.6125 MHz / 40.0125 MHz - Channel 51
- 35.6250 MHz / 40.0250 MHz - Channel 52
- 35.6375 MHz / 40.0375 MHz - Channel 53
- 35.6625 MHz / 40.0625 MHz - Channel 54
- 35.6750 MHz / 40.0750 MHz - Channel 55
- 35.6875 MHz / 40.0875 MHz - Channel 56
- 35.7000 MHz / 40.1000 MHz - Channel 57
- 35.7125 MHz / 40.1125 MHz - Channel 58
- 35.7250 MHz / 40.1250 MHz - Channel 59
- 35.7375 MHz / 40.1375 MHz - Channel 60
- 35.7500 MHz / 40.1500 MHz - Channel 61
- 35.7625 MHz / 40.1625 MHz - Channel 62
- 35.7875 MHz / 40.1875 MHz - Channel 63
- 35.8125 MHz / 40.2125 MHz - Channel 64
- 35.8250 MHz / 40.2250 MHz - Channel 65
- 35.8375 MHz / 40.2375 MHz - Channel 66
- 35.8625 MHz / 40.2625 MHz - Channel 67
- 35.8750 MHz / 40.2750 MHz - Channel 68
- 35.8875 MHz / 40.2875 MHz - Channel 69
- 35.9000 MHz / 40.3000 MHz - Channel 70
- 35.9125 MHz / 40.3125 MHz - Channel 71
- 35.9250 MHz / 40.3250 MHz - Channel 72
- 35.9375 MHz / 40.3375 MHz - Channel 73
- 35.9625 MHz / 40.3625 MHz - Channel 74
- 35.9750 MHz / 40.3750 MHz - Channel 75
- 36.0125 MHz / 40.4125 MHz - Channel 76
- 36.0250 MHz / 40.4250 MHz - Channel 77
- 36.0375 MHz / 40.4375 MHz - Channel 78
- 36.0625 MHz / 40.4625 MHz - Channel 79
- 36.0750 MHz / 40.4750 MHz - Channel 80
- 36.0875 MHz / 40.4875 MHz - Channel 81
- 36.1125 MHz / 40.5125 MHz - Channel 82
- 36.1250 MHz / 40.5250 MHz - Channel 83
- 36.1375 MHz / 40.5375 MHz - Channel 84
- 35.3125 MHz / 39.7125 MHz - Channel 85
- 35.3250 MHz / 39.7250 MHz - Channel 86
- 35.3375 MHz / 39.7375 MHz - Channel 87
- 35.3500 MHz / 39.7500 MHz - Channel 88
- 35.3625 MHz / 39.7625 MHz - Channel 89
- 35.3750 MHz / 39.7750 MHz - Channel 90
- 35.3875 MHz / 39.7875 MHz - Channel 91
- 35.4000 MHz / 39.8000 MHz - Channel 92
- 35.4125 MHz / 39.8125 MHz - Channel 93
- 35.4250 MHz / 39.8250 MHz - Channel 94
- 35.4375 MHz / 39.8375 MHz - Channel 95
- 35.4500 MHz / 39.8500 MHz - Channel 96
- 35.4625 MHz / 39.8625 MHz - Channel 97
- 35.4750 MHz / 39.8750 MHz - Channel 98
- 35.4875 MHz / 39.8875 MHz - Channel 99
Additional French VHF low 30-50 MHz and VHF mid band 66-88 MHz PMR PLMR LMR spectrum allocations:
12.5 kHz spacing
- 30.8750 MHz - 32.1250 MHz - Simplex
- 32.6000 MHz - 33.0000 MHz - Simplex
- 34.8500 MHz - 34.9000 MHz - Simplex
- 34.9000 MHz - 36.2500 MHz - Repeater outputs (duplex) systems - including DDE PMR
- 36.2500 MHz - 36.6000 MHz - Simplex
- 36.8625 MHz - 39.1000 MHz - Simplex
- 39.3000 MHz - 40.6500 MHz - Repeater inputs (paired with 34.9 MHz - 36.25 MHz) - DDE PMR
- 68.4625 MHz - 69.2500 MHz - Repeater inputs (paired with 72.5125 MHz - 73.3 MHz) - EDF and GDF PMR
- 70.2500 MHz - 70.5250 MHz - Simplex
- 70.9750 MHz - 71.9500 MHz - Simplex
- 72.5125 MHz - 73.3000 MHz - Repeater outputs (duplex) systems - including EDF and GDF
- 75.2000 MHz - 75.3000 MHz - Simplex
- 75.3000 MHz - 77.4750 MHz - Repeater outputs (duplex - paired with 80.3 MHz - 82.475 MHz)
- 80.0000 MHz - 80.3000 MHz - Simplex
- 80.3000 MHz - 82.4750 MHz - Repeater inputs (paired with 75.3 MHz - 77.475 MHz)
