Amphetamine Radio
Amphetamine Radio is a pirate radio station that first appeared in the summer of 2015. It is normally heard on 6925 USB but has been heard on "offset" frequencies 6923 and 6924.7 in addition to 6930, 6950 and 6955 kHz. Amphetamine Radio has also experimented with lower frequencies, including 3375 kHz, 4050 kHz, 4060 kHz, 4065 kHz, 4080 kHz and several others. The primary 90 meter frequency for Amphetamine Radio is 3375 kHz. USB mode is normally used, however Amphetamine Radio has transmitted broadcasts in AM mode, referring to it as "Amphetamine Modulation".
Amphetamine Radio often transmits several SSTV images throughout their broadcasts and appears to be one of the most prolific transmitters of SSTV, along with other frequent users of SSTV including Wolverine Radio and Pee Wee. Some of their broadcasts consist entirely of SSTV images. SSTV is usually transmitted in Scottie 1 mode. In addition to voice IDs, MCW (modulated CW) IDs are usually transmitted, often either before or after SSTV frames are sent. Amphetamine Radio's SSTV content often consists of vintage "pin-up" style erotica, women in fishnet stockings, and occasionally political images. Amphetamine Radio has also transmitted "SSTV requests" made by listeners. Amphetamine Radio often adds the tagline "Pin-Up Pirate Radio" or "High Speed Pirate Radio" to their identification and has claimed to be "the most tweaked out station on the 43 meter band".
Amphetamine Radio has not been heard for quite some time (as of August 2023). The op has indicated that he is currently unable to put up a proper antenna and will attempt to resume broadcasts once that situation changes.
